Clear valve covers on the dyno #3063037
07/27/22 03:27 PM
07/27/22 03:27 PM
AndyF Online content OP
AndyF  Online Content OP
I like using these clear valve covers (clear top anyway) on the dyno so I can verify that everything is working properly before we put the engine under load. Here is a short video of us warming up a big block Mopar with Trick Flow heads and Mancini Racing rocker arms.
https://www.youtube.com/watch?v=OmnN9nl3KsU
Re: Clear valve covers on the dyno [Re: AndyF] #3063046
07/27/22 03:40 PM
07/27/22 03:40 PM
houston texas
gremlinsteve Offline
houston texas
which rockers are you using in that video
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Clear valve covers on the dyno [Re: gremlinsteve] #3063060
07/27/22 04:23 PM
07/27/22 04:23 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Those rocker covers are a really good idea, seems to me.
Re: Clear valve covers on the dyno [Re: AndyF] #3063080
07/27/22 06:15 PM
07/27/22 06:15 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Didn’t you make those several years ago?
Re: Clear valve covers on the dyno [Re: gremlinsteve] #3063084
07/27/22 06:57 PM
07/27/22 06:57 PM
Good question. Those are Mancini Racing rocker arms with a 1.60 ratio. I think they might anodize them blue now but that set was natural.
Re: Clear valve covers on the dyno [Re: justinp61] #3063085
07/27/22 06:59 PM
07/27/22 06:59 PM
I made the valve covers a few years back but I still use them all the time. Actually I sold one and kept one and I use the one I have on most big block Mopar engines that we run. It is just a very simple way to gather a little more data.
Re: Clear valve covers on the dyno [Re: AndyF] #3063096
07/27/22 07:14 PM
07/27/22 07:14 PM
VA
dragon slayer Offline
VA
Can you make a set for the 426 hemi laugh
Re: Clear valve covers on the dyno [Re: dragon slayer] #3063099
07/27/22 07:25 PM
07/27/22 07:25 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Westcot did. a buddy had one of his S/S engines
Re: Clear valve covers on the dyno [Re: dragon slayer] #3063149
07/27/22 10:32 PM
07/27/22 10:32 PM
I can make just about anything.
Re: Clear valve covers on the dyno [Re: AndyF] #3063324
07/28/22 02:37 PM
07/28/22 02:37 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
You ever use a timing light with those while the lights are low to stop motion the valvetrain? I think it would look really cool and informative.
Re: Clear valve covers on the dyno [Re: 375inStroke] #3063353
07/28/22 04:09 PM
07/28/22 04:09 PM
No but we used to do that when I was an engineer. We would use a strobe light with a dial and you could dial in different frequencies to see different things. These days they use high speed cameras since it works a lot better but I don't have one of those.
Re: Clear valve covers on the dyno [Re: AndyF] #3063508
07/29/22 09:20 AM
07/29/22 09:20 AM
Tennessee
CUDASCOTT Offline
CUDASCOTT  Offline
Tennessee
that would be interesting
