2nd Gen Rams wheels #3062303
07/25/22 08:28 AM
07/25/22 08:28 AM
Mo.
racerx Online work OP
racerx  Online Work OP
Mo.
I have the 16" ram wheels looking to go to the 20"s what wheel spindle interchange on the front with the 95 rams? My reason for asking is the rims in question fit the rear just fine but not the front shruggy Not looking to run any spacers.
Re: 2nd Gen Rams wheels [Re: racerx] #3062432
07/25/22 02:03 PM
07/25/22 02:03 PM
moparx Offline
moparx  Offline
why won't the wheels fit on the front ?
beer
Re: 2nd Gen Rams wheels [Re: racerx] #3062443
07/25/22 02:19 PM
07/25/22 02:19 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
A second gen dodge truck would be what year? 1933? I am assuming you actually have some other arbitrarily named "2nd gen" dodge truck.
Are you talking 1/2 ton? 1994-2019 1500 classic with 5 lugs all use the same pattern (even earlier ones too but I never messed with interchangin them) and easily interchange on a 4wd, on a 94-01 2wd you can't run the center caps of the later wheels because of the spindle, I ran mine like this on a 1998 2wd from an 07 1500.
Re: 2nd Gen Rams wheels [Re: moparx] #3062550
07/25/22 07:14 PM
07/25/22 07:14 PM
Mo.
Mo.
beer
They do have the same bolt pattern as the rear, but it seems the wheel's bearing cover won't fit the wheel due to the wheel bearing (Hub) cap protrude pass the surface of the wheel. Stopping the wheel cap from seating.
Re: 2nd Gen Rams wheels [Re: racerx] #3062572
07/25/22 09:02 PM
07/25/22 09:02 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
What year is your truck?
Re: 2nd Gen Rams wheels [Re: HotRodDave] #3062605
07/26/22 06:29 AM
07/26/22 06:29 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
1994-2001 is second gen. Is it 4X4 or 4X2?
Re: 2nd Gen Rams wheels [Re: HotRodDave] #3062610
07/26/22 07:24 AM
07/26/22 07:24 AM
Mo.
Mo.
95
Re: 2nd Gen Rams wheels [Re: Moparite] #3062611
07/26/22 07:25 AM
07/26/22 07:25 AM
Mo.
Mo.
Originally Posted by Moparite
Quote
4x2
Re: 2nd Gen Rams wheels [Re: racerx] #3062617
07/26/22 08:10 AM
07/26/22 08:10 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Anyone know which of the 2nd Gen Ram factory option wheels is lightest weight?
Is any such wheel equal to or lighter than an aluminum Centerline?
Re: 2nd Gen Rams wheels [Re: Moparite] #3062720
07/26/22 12:25 PM
07/26/22 12:25 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Quote
So 1921-1993 is all first gen dodge trucks... got it.
When I ran my 1998 2wd with the later 07 20" wheels I think I put the grease cap on after the wheels and no center cap.
Re: 2nd Gen Rams wheels [Re: racerx] #3062745
07/26/22 01:27 PM
07/26/22 01:27 PM
moparx Offline
moparx  Offline
beer
i understand now.
beer
Re: 2nd Gen Rams wheels [Re: racerx] #3062804
07/26/22 05:37 PM
07/26/22 05:37 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Have you considered 17" rims that came on the 2001 "Off Road" 4X4's (or something similar in size)? They look nice on 2X4's also...
https://www.rockauto.com/en/catalog/dodge,2001,ram+1500+pickup,5.9l+v8,1366590,wheel,wheel,7644
OUCH! They've They've gone up in price...
Re: 2nd Gen Rams wheels [Re: Fat_Mike] #3062810
07/26/22 05:53 PM
07/26/22 05:53 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Don't forget the $40 core charge for reconditioning. Those were easy to find 20 years ago, guys were pulling them off for 15x10's and easy to find tires.
rockauto liinky
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 2nd Gen Rams wheels [Re: HotRodDave] #3062878
07/26/22 11:11 PM
07/26/22 11:11 PM
Mo.
Mo.
And this is what I'm trying not to do. I have seen some second gens(4x2) running around with center caps. Wondering if they did a spindle change work
Re: 2nd Gen Rams wheels [Re: racerx] #3063139
07/27/22 09:52 PM
07/27/22 09:52 PM
N
NITROUSN Offline
NITROUSN  Offline
N
beer
Post some pictures of your truck and the wheels you are trying to put on. The wheels should fit without the center caps.
Re: 2nd Gen Rams wheels [Re: NITROUSN] #3063203
07/28/22 08:16 AM
07/28/22 08:16 AM
Mo.
Mo.
The wheels do fit ,it's just the caps that goes with the wheels will not fit due to the spindle grease caps protrude too far past the base lip of the wheels were the cap rest.
Re: 2nd Gen Rams wheels [Re: racerx] #3063214
07/28/22 09:37 AM
07/28/22 09:37 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Lots of wheel companies offer different center caps just for that reason. What were the wheels on before?
Re: 2nd Gen Rams wheels [Re: NITROUSN] #3063500
07/29/22 07:12 AM
07/29/22 07:12 AM
Mo.
Mo.
They came from a tire shop i would imagine they are somewhere around 2000 Dodge factory ram's rims shruggy
Re: 2nd Gen Rams wheels [Re: racerx] #3063509
07/29/22 09:25 AM
07/29/22 09:25 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Post a picture of the rim. I doubt they are 2000 vintage as 20's came in way later.
Re: 2nd Gen Rams wheels [Re: NITROUSN] #3063647
07/29/22 02:49 PM
07/29/22 02:49 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
That's correct, it would be 2002 or later that 20 inch wheels would be an option.
That's probably when the hub changed happened.
