Re: 2nd Gen Rams wheels
[Re: racerx]
#3062443
07/25/22 02:19 PM
07/25/22 02:19 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
A second gen dodge truck would be what year? 1933? I am assuming you actually have some other arbitrarily named "2nd gen" dodge truck.
Are you talking 1/2 ton? 1994-2019 1500 classic with 5 lugs all use the same pattern (even earlier ones too but I never messed with interchangin them) and easily interchange on a 4wd, on a 94-01 2wd you can't run the center caps of the later wheels because of the spindle, I ran mine like this on a 1998 2wd from an 07 1500.
[Re: HotRodDave]
#3062605
07/26/22 06:29 AM
07/26/22 06:29 AM
Posts: 992 rust belt
Moparite
rust belt
A second gen dodge truck would be what year? 1994-2001 is second gen. Is it 4X4 or 4X2?
[Re: HotRodDave]
#3062610
07/26/22 07:24 AM
07/26/22 07:24 AM
Posts: 4,072 Mo.
racerx
Mo.
[Re: Moparite]
#3062611
07/26/22 07:25 AM
07/26/22 07:25 AM
Posts: 4,072 Mo.
racerx
Mo.
A second gen dodge truck would be what year? 1994-2001 is second gen. Is it 4X4 or 4X2? 4x2
[Re: Moparite]
#3062720
07/26/22 12:25 PM
07/26/22 12:25 PM
HotRodDave
Kalispell Mt.
A second gen dodge truck would be what year? 1994-2001 is second gen. Is it 4X4 or 4X2? So 1921-1993 is all first gen dodge trucks... got it. When I ran my 1998 2wd with the later 07 20" wheels I think I put the grease cap on after the wheels and no center cap.
[Re: Fat_Mike]
#3062810
07/26/22 05:53 PM
07/26/22 05:53 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Have you considered 17" rims that came on the 2001 "Off Road" 4X4's (or something similar in size)? They look nice on 2X4's also...
https://www.rockauto.com/en/catalog/dodge,2001,ram+1500+pickup,5.9l+v8,1366590,wheel,wheel,7644 OUCH! They've They've gone up in price... Don't forget the $40 core charge for reconditioning. Those were easy to find 20 years ago, guys were pulling them off for 15x10's and easy to find tires. rockauto liinky
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: racerx]
#3063139
07/27/22 09:52 PM
07/27/22 09:52 PM
Posts: 18,424 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
why won't the wheels fit on the front ? They do have the same bolt pattern as the rear, but it seems the wheel's bearing cover won't fit the wheel due to the wheel bearing (Hub) cap protrude pass the surface of the wheel. Stopping the wheel cap from seating. Post some pictures of your truck and the wheels you are trying to put on. The wheels should fit without the center caps.
[Re: racerx]
#3063214
07/28/22 09:37 AM
07/28/22 09:37 AM
NITROUSN
The wheels do fit ,it's just the caps that goes with the wheels will not fit due to the spindle grease caps protrude too far past the base lip of the wheels were the cap rest. Lots of wheel companies offer different center caps just for that reason. What were the wheels on before?
[Re: NITROUSN]
#3063500
07/29/22 07:12 AM
07/29/22 07:12 AM
Posts: 4,072 Mo.
racerx
Mo.
The wheels do fit ,it's just the caps that goes with the wheels will not fit due to the spindle grease caps protrude too far past the base lip of the wheels were the cap rest. Lots of wheel companies offer different center caps just for that reason. What were the wheels on before? They came from a tire shop i would imagine they are somewhere around 2000 Dodge factory ram's rims
[Re: racerx]
#3063509
07/29/22 09:25 AM
07/29/22 09:25 AM
NITROUSN
The wheels do fit ,it's just the caps that goes with the wheels will not fit due to the spindle grease caps protrude too far past the base lip of the wheels were the cap rest. Lots of wheel companies offer different center caps just for that reason. What were the wheels on before? They came from a tire shop i would imagine they are somewhere around 2000 Dodge factory ram's rims Post a picture of the rim. I doubt they are 2000 vintage as 20's came in way later.
[Re: NITROUSN]
#3063647
07/29/22 02:49 PM
07/29/22 02:49 PM
Posts: 10,141 A Red State
SNK-EYZ
A Red State
The wheels do fit ,it's just the caps that goes with the wheels will not fit due to the spindle grease caps protrude too far past the base lip of the wheels were the cap rest. Lots of wheel companies offer different center caps just for that reason. What were the wheels on before? They came from a tire shop i would imagine they are somewhere around 2000 Dodge factory ram's rims Post a picture of the rim. I doubt they are 2000 vintage as 20's came in way later. That's correct, it would be 2002 or later that 20 inch wheels would be an option. That's probably when the hub changed happened.
