Need a T&D 1.5 left offset 440-1 intake rocker
#3060846
07/20/22 10:04 AM
07/20/22 10:04 AM
Posts: 2,507 PA
moparacer
PA
One of my friends broke a T&D intake rocker over the weekend and T&D is 6-8 weeks out on a replacement.
I seen the thread awhile back about Automachine in CT and left a message and sent an email.
Anyone else have or know where we might be able to find a rocker?
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: Need a T&D 1.5 left offset 440-1 intake rocker
[Re: moparacer]
#3060872
07/20/22 10:53 AM
07/20/22 10:53 AM
Posts: 20,178 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Anyone else have or know where we might be able to find a rocker? Do some looking around on T&D’s website as I’m about positive the 440-1 heads and 360-1 heads use the exact same rockers. Of course the shafts are different but rockers are the same. I know the rockers Indy sold fit both heads too.
[Re: pittsburghracer]
#3060969
07/20/22 02:39 PM
07/20/22 02:39 PM
Posts: 2,507 PA
moparacer
PA
I would imagine the 360-1's from T&D are the same wait time at the 440-1 but will mention that too them. I run 1.6 rockers and have some spares but naturally they need a 1.5.
[Re: moparacer]
#3060999
07/20/22 03:30 PM
07/20/22 03:30 PM
Posts: 20,178 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I would imagine the 360-1's from T&D are the same wait time at the 440-1 but will mention that too them. I run 1.6 rockers and have some spares but naturally they need a 1.5. As long as they have valve to piston clearance what’s the difference. Just dial it in and race.
#3061000
07/20/22 03:37 PM
07/20/22 03:37 PM
Posts: 2,507 PA
moparacer
PA
I offered, and they didn't want to do that.....He said they are around .700 lift so I if they are .470 on the lobe it might be another .045 on that valve and put them around .750 lift as long as they aren't running close to coil bind on the spring....
I bet its either going to be that or not race for the rest of the summer.....Over a rocker arm....
[Re: HardcoreB]
#3065476
08/05/22 01:23 PM
08/05/22 01:23 PM
Posts: 2,507 PA
moparacer
PA
One other thing worth mentioning is: The rockers i have ARE LABELED WRONG!!! I found that when i built the engine. They are stamped 1.5 and are actually a tick OVER 1.6. So, it's remotely possible that your buddy has a 1.6 ratio and doesnt know. Also if you could give us anything you might know of his valvetrain as described in my previous post Thanks! Sorry guys I get off doing 500 other things and lose track of things on here. Anyways Hardcore now that you mention it, he found a set somewhere then called me the other day and said he needed different length pushrods.... I questioned the ratio of the ones he got because of that but not sure he verified it after I talked to him at the track last week.
[Re: HardcoreB]
#3065489
08/05/22 02:12 PM
08/05/22 02:12 PM
Posts: 2,507 PA
moparacer
PA
Called him a little while ago.....I am going to take a couple of my old 1.6's I have for spares to the track tomorrow for him to compare.
Cant get pushrods for 6 weeks either so he has time to figure this out.
[Re: HardcoreB]
#3065936
08/06/22 10:54 PM
08/06/22 10:54 PM
Posts: 2,507 PA
moparacer
PA
Appreciate the offer Hardcore! Sent you a PM.
