Re: Carb series ? help [Re: terzmo] #3060643
07/19/22 05:47 PM
07/19/22 05:47 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
They make bushing kits for the throttle shafts......I've never done one but it might be worth a shot if the carb otherwise works the way you like:
https://www.google.com/search?q=hol...86j0j15&sourceid=chrome&ie=UTF-8
Re: Carb series ? help [Re: terzmo] #3060662
07/19/22 06:42 PM
07/19/22 06:42 PM
All things that ran good at one time can be fix to run good again, the hard part is figuring out what wore out or went bad to cause the repair issue work
You can fix it, don't GIVE UP tsk You can fix it up wrench
Re: Carb series ? help [Re: terzmo] #3060675
07/19/22 07:57 PM
07/19/22 07:57 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
Originally Posted by terzmo
the throttle shaft was loose when getting to the shop. 23 mile run. Took the carb off and put a race base plate on it (only thing available) and the carb ran at 2000rpm and stalled at 1800. definetely not good. looked at the original base after about an hour and the throttle shaft was solid as concrete. Explains why it stalls after getting to temp. The race base wouldn't work so I have the original back on to get home. Looking to get a new carb as why throw money into parts for a 27 year old carb that has seen better days
The Quick Fuel Brawler carbs are nice for the money. The only thing bad is the IFR is in the top position and the T slot needs restrictors. Everything else is tuneable even the pvcr is threaded with small jets.
America First!
Re: Carb series ? help [Re: Dcuda69] #3060711
07/19/22 09:13 PM
07/19/22 09:13 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Saw that but why waste time and money on a 27 year old carb...Thx
Re: Carb series ? help [Re: Cab_Burge] #3060713
07/19/22 09:14 PM
07/19/22 09:14 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Originally Posted by Cab_Burge
All things that ran good at one time can be fix to run good again, the heard part is figuring out what wore our or went bad to cause the repair issue work
Thanks Coach but I'm tossing in the towel on this one....lol
Re: Carb series ? help [Re: terzmo] #3062368
07/25/22 11:42 AM
07/25/22 11:42 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Installed new proform 850 ...tuned and is ok now. Thanks moparts...thanks to all who contributed
Re: Carb series ? help [Re: terzmo] #3082338
10/01/22 07:14 PM
10/01/22 07:14 PM
North Tonawanda
Checker Offline
Checker  Offline
North Tonawanda
Well...the new carb didn't fix the problem.
I believe I finally found the problem. My alternator belt always was not real tight but I had no problems with the battery charging enough to keep it starting with no problems. So a friend said that possibly at idle the alternator is not putting out enough to support the ECU and it cuts out at idle. This would confirm why it never did during warmup(higher idle) or when in neutral at a high idle. So I start to pull the alternator and get it loose and turn to get a tool off the bench and when turning around I see the interior of My car is full of smoke. Alot . So I now disconnect the battery and see the GM 108 amp alt slid down and grounded the hot wire to My block.
I remove the alt...get it checked and it checks ok. I change the half ass mounting bracket for the alt and install it and get a very tight belt. After changing a few wires under the dash and installing a new amp gauge,the car fires up..(starts) and I take it out for a long run and no stalling at any light. Been out a few times and no stalling. So I assume the belt was not tight enough to supply a good charge at idle and that caused the ECU to quit.
All of this...new carb...fuel pump...fuel filter...for naught. But replacing that 27 year old carb with a new Proform seems like I picked up a bunch of more power. Like that's needed with a 472 Hemi.
I posted this because IF someone has a similar problem...this is something to check. I got a lot of responses to this problem, and I appreciate all and MOPARTS for the help.
Re: Carb series ? help [Re: Checker] #3082355
10/01/22 09:17 PM
10/01/22 09:17 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I'm a bit confused as the OP was "terzmo". You are now saying a loose alternator belt was the cause. That also doesn't make sense as the car should have kept running off the battery confused shruggy
Re: Carb series ? help [Re: TJP] #3082363
10/01/22 09:36 PM
10/01/22 09:36 PM
North Tonawanda
Checker Offline
Checker  Offline
North Tonawanda
I lost My password as TERZMO and got frustrated trying to log in so I started another account under My alternate email. I contacted the administrators but got no where with that. The belt was not right as far as tension...tightening it and I have had no problems with stalling since. Been out 4 to 5 times...sat at lights..idled through parking lots trying to get it to act up and it hasn't. It stalled after warming up during all the conditions just noted. I should of checked alt output at idle before tightening but didn't Now at idle , at the battery. It see 14.1 volts. That's all I did after changing fuel pump..fuel filter and filter placement and carb.
Re: Carb series ? help [Re: Checker] #3082412
10/02/22 07:51 AM
10/02/22 07:51 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
OK...I'm back as terzmo and Checker is temporarily sidelined. Thanks again for all the input
"That also doesn't make sense as the car should have kept running off the battery "confused shruggy I can only assume by interrupting the voltage or running a negitive charge because of loose belt, the ECU would shut down at idle speed.( I have seen meters go to the negitive side at low idles) Electronics have an operating input and output threshold . All's I know is after doing all the other changes, nothing fixed it. Even by shorting the alt and burning wires, the alt checked good at a long time experienced electric shop. ( I was shocked it checked good and still putting out 108 amp-s plus) I have taken the car out about 5 times on decent rides and it has yet to quit.
Re: Carb series ? help [Re: terzmo] #3082468
10/02/22 12:39 PM
10/02/22 12:39 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Strange??? Welcome to the world electronics. one would have to have a complete accurate schematic to figure this one out as in theory it should have run off the battery unless it was too low. But then it wouldn't have started again. Almost sounds like the ignition is getting it's power from the Alt. shruggy thanks for the feedback
Re: Carb series ? help [Re: TJP] #3082471
10/02/22 12:56 PM
10/02/22 12:56 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
1955 work as well ?
https://www.ebay.com/itm/115491061377?hash=item1ae3cdbe81:g:FHwAAOSwNNli9E3t&amdata=enc%3AAQAHAAAAsKk1sDtPwSGytc%2F76Kq0P4RzO9xPwi03NWCaOzvGf6Ho%2Fka7Ud8vyX2%2B8LOsjWNDkWXp6VVNLiCqyteYoPKwIZ3c0OGyW2UZ6i36BccALXZ0FE0Ck8qjunEvpE3V%2FdiIrRrMJOgh7Y2yJlS5evQBShDkVUcCnThHlHDodOF%2BqRJSmHAUERgCtH9H1xmH1v5tIJcIqw%2BMtZHRChTQpmA4O8vuNw6mcK6%2F%2BNVHJMh%2FO7Fs%7Ctkp%3ABk9SR-Dc1pnzYA
another one listed on same page but scroll down further
Re: Carb series ? help [Re: terzmo] #3082586
10/02/22 10:04 PM
10/02/22 10:04 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
1955 work as well ?
confused
Re: Carb series ? help [Re: TJP] #3083330
10/04/22 06:27 PM
10/04/22 06:27 PM
moparx Offline
moparx  Offline
1955 work as well ?
confused
this better ?
beer
well, no, it ain't.............
that link is to a ferd truck [?] script badge....... spank
Last edited by moparx; 10/04/22 06:31 PM. Reason: didn't check link to see what it was before posting !
Re: Carb series ? help [Re: terzmo] #3083371
10/04/22 08:03 PM
10/04/22 08:03 PM
Why does this Mopar Hemiroid motor not look like a BB Mopar?
Probably because it is not BB twocents grin stirthepot devil
Re: Carb series ? help [Re: moparx] #3083416
10/04/22 10:42 PM
10/04/22 10:42 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
1955 work as well ?
confused
shruggy realcrazy
this better ?
beer
confused
