Engine Paint Question ??? #3059400
07/15/22 01:18 PM
07/15/22 01:18 PM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
Hey Guys, were the alternator " Bolts and Brackets " painted black or engine color? I do see a little of the orange on a few of the bolt heads. this is for ' 70 340 T/A engine. Thanks, Kevin
Re: Engine Paint Question ??? [Re: B5TA] #3059563
07/15/22 11:26 PM
07/15/22 11:26 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
painted black brackets,
Black phosphate bolts and spacers
Re: Engine Paint Question ??? [Re: gtx6970] #3059584
07/16/22 02:22 AM
07/16/22 02:22 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The engine plant built and painted the engines without accessories such as alternators and brackets. After the engines arrived at the car assembly plant, various different alternators that were available as options were bolted on using 2 existing water pump bolts. Brackets were hung on hooks or wires and dip painted with black enamel, and as a result had runs that could be discerned on close inspection.
These photos are 1969 340s with different water pumps than 1970, but they do correctly show the 2 water pump bolt heads with engine paint.
1969 340 water pump.JPG1969 340 water pump1.JPG1969 340 water pump2.JPG1969 340.JPG
Re: Engine Paint Question ??? [Re: kentj340] #3059586
07/16/22 02:36 AM
07/16/22 02:36 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
AFAIK the temperature sending unit, heater hose nozzles, and hose clamps should have been painted with engine paint in the last photo above.
Re: Engine Paint Question ??? [Re: kentj340] #3059617
07/16/22 09:22 AM
07/16/22 09:22 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
You might want to mask the threads where the terminal goes on, Just saying.
Re: Engine Paint Question ??? [Re: kentj340] #3059645
07/16/22 11:45 AM
07/16/22 11:45 AM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
Thank You !! that pretty much verifys what I thought . Any thoughts about the fuel pump ? Thanks , Kevin
Re: Engine Paint Question ??? [Re: B5TA] #3059859
07/17/22 08:41 AM
07/17/22 08:41 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Would look to Scott Smith for the correct answer to your question. Small Blocks were done different than Big Blocks. That painted engine above is close but no cigar.
Ron
Re: Engine Paint Question ??? [Re: RJS] #3059887
07/17/22 11:29 AM
07/17/22 11:29 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I would think they would be installed, If not they would have to mask it prior to paint and remove it when installing it and that would take longer.
Re: Engine Paint Question ??? [Re: B5TA] #3060037
07/17/22 09:27 PM
07/17/22 09:27 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
On a small block the fuel pump was installed after paint also the negative battery cable and bolt were unpainted along with wire holders.
Ron
Re: Engine Paint Question ??? [Re: RJS] #3060150
07/18/22 11:30 AM
07/18/22 11:30 AM
VA
dragon slayer Offline
VA
They painted bypass hose completely on small blocks?
Re: Engine Paint Question ??? [Re: dragon slayer] #3060488
07/19/22 09:21 AM
07/19/22 09:21 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Yes By pass and clamps were painted.
Ron
Re: Engine Paint Question ??? [Re: RJS] #3103358
12/18/22 03:21 PM
12/18/22 03:21 PM
PINE VALLEY
Ray S Offline
Ray S  Offline
PINE VALLEY
Ron
After much searching it seems I want the P4120752 turquiose, but is there a consensus on which VHT or Duplicolor numbers?
No one googled has any posts on the 1971 413-1 Hi-Perf truck motors
Re: Engine Paint Question ??? [Re: Ray S] #3103365
12/18/22 04:10 PM
12/18/22 04:10 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Blast from the past with plenty of good pictures. Click on them to download.
https://board.moparts.org/ubbthread.../1971-340-cuda-engine-paint-details.html
Re: Engine Paint Question ??? [Re: Neil] #3103368
12/18/22 04:46 PM
12/18/22 04:46 PM
PINE VALLEY
Ray S Offline
Ray S  Offline
PINE VALLEY
Most of the hi perf car engines were orange, but these year trucks were all turquoise, not the later Chrysler blue either.
The JY 72 below seems like the covers were repainted with the later bluer color.
Re: Engine Paint Question ??? [Re: Ray S] #3121141
02/13/23 01:30 PM
02/13/23 01:30 PM
PINE VALLEY
Ray S Offline
Ray S  Offline
PINE VALLEY
Relying to myself:
I got the VHT SP126 and it matches the intake etc especially after hard cleaning for new paint.
After power cleaning the bottom though I started spraying and noticed that the pan and block were black on top of base metal. I can imagine the pan dropped and painted, but the block seems odd since it was a neglected RV with only 60k miles.
It's all turquoise now.
Re: Engine Paint Question ??? [Re: Ray S] #3121145
02/13/23 01:39 PM
02/13/23 01:39 PM
PINE VALLEY
Ray S Offline
Ray S  Offline
PINE VALLEY
Even in the junkyard pic the heads and intake have traces of green-blue, but oddly the block has none.
