New Oil Pump #3059460
07/15/22 04:35 PM
07/15/22 04:35 PM
Plano, TX
hkestes Offline OP
hkestes  Offline OP
Plano, TX
Have a Magnum 360 in my 37 Plymouth and the oil pressure has been slowly dropping over the past year or so. So, I have purchased a new high volume pump as a precaution.
My question is, I know you need to prime a new pump on a newly built engine to make sure the bearings etc are oiled properly before starting. Do you need to prime the pump on a currently running engine? Would it be best to crank it a few times to build pressure with the coil wire off so that it doesn't start? Seems like something I should know, but don't.
Re: New Oil Pump [Re: hkestes] #3059466
07/15/22 04:53 PM
07/15/22 04:53 PM
I would never use the SB Chevy racer trick of grinding on the starter to spin the motor over long enough to make oil pressure, NEVER tsk
I do prime all my new motors with a 1/2 drill motor and then spin the motor over with all the spark plugs out with oil pressure to ensure all rotating parts get oiled before starting wrench up
On your deal I would pour some oil down the oil pickup while holding it and use the proper size Allen wrench to spin the pump over to suck that oil into the pump and let it squirt out the passage going to the main cap oil passage
Don't forget to use a new gasket and torque both bolts down up
Re: New Oil Pump [Re: Cab_Burge] #3059469
07/15/22 04:58 PM
07/15/22 04:58 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
To simplify things .
You will need to pull the distributor anyway, so bolt up the pump, button up the pan, put oil in it and before you reinstall the distributor use a pump priming tool (length of 5/16 hex stock, spin it CW for a small block and it will prime the engine for you.
The tool
https://www.amazon.com/Genuine-Mopar-P4286800-Priming-Shaft/dp/B000CIZZGY
Only reason to turn the engine over would be to get oil up to the rockers on a NEW build, no real need for what you are doing.
Re: New Oil Pump [Re: Sniper] #3059571
07/16/22 12:19 AM
07/16/22 12:19 AM
WI
Dcuda69 Online content
Dcuda69  Online Content
WI
Doesn't matter if you're going to spin the engine or spin the pump. ALWAYS put some oil in the pump and spin it BEFORE mounting it to the engine. Dry pumps will not pump oil. I usually take the cover off the pump, make sure it's clean inside...then oil it up and bolt it in.
Re: New Oil Pump [Re: Dcuda69] #3059615
07/16/22 09:15 AM
07/16/22 09:15 AM
moparx Online content
moparx  Online Content
way back in the day, we took the pump apart, de-burred and polished the castings, then filled the inside with STP or vaseline.
today, that may not be the stuff to fill the pump with, but that is what we did a long time ago.
beer
Re: New Oil Pump [Re: moparx] #3059635
07/16/22 11:16 AM
07/16/22 11:16 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree I never install a pump right out of the box. Disassemble, clean, lube the inner rotor shaft, and pack with Vaseline.
Re: New Oil Pump [Re: John_Kunkel] #3059674
07/16/22 02:14 PM
07/16/22 02:14 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
iagree
Re: New Oil Pump [Re: 6PakBee] #3059747
07/16/22 09:09 PM
07/16/22 09:09 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
X4
smile
Re: New Oil Pump [Re: TJP] #3059903
07/17/22 12:31 PM
07/17/22 12:31 PM
On a side note bolt up the pump to the cap barely snug then install the intermediate gear shaft then torque the pump bolts. this gives you dead on hex shaft alignment. Just my OCD talking!
Re: New Oil Pump [Re: RapidRobert] #3059916
07/17/22 01:09 PM
07/17/22 01:09 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
If the long snout on the pump doesn't give you proper alignment, the shaft sure as hell isn't. Not to mention torquing the pump to the block !!
Re: New Oil Pump [Re: Stanton] #3059938
07/17/22 02:35 PM
07/17/22 02:35 PM
when installing the pump to the block, i like to use a priming rod [just a length of 5/16" hex rod or long reach t-handle allen key] to check for binding. try the rod with the pump just snug, then torqued up. you can tell immediately if it binds. if so, you need to find out where and why it's doing so.
this doesn't happen all the time, but i have run into this a time or two. so for as long as it takes to check this, it's well worth doing [in my opinion]
beer
Re: New Oil Pump [Re: moparx] #3059978
07/17/22 04:35 PM
07/17/22 04:35 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
I've never had a stock pump bind. I've never had an aluminum pump that didn't bind !!!
Re: New Oil Pump [Re: Stanton] #3060001
07/17/22 05:43 PM
07/17/22 05:43 PM
A727Tflite Offline
A727Tflite  Offline
Originally Posted by Stanton
Quote
Did you run a red Road Runner/GTX at Grand Bend back in the late 90’s - early 2001 time frame?
Re: New Oil Pump [Re: hkestes] #3060117
07/18/22 08:55 AM
07/18/22 08:55 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Unless I missed it, no one has mentioned the tank based pre-lube setups yet.
Allstar Performance Oil Pressure Primer Tanks ALL10535
I picked up a used EL05 (which is a lot like this Melling Prelube Engine Oiler Tank Kits MPL-201 part) when a local machine shop was closing down. I haven't used it yet, although it appears to be literaly child's play easy!
So my point being: once you have it all assembled and on the SB the pump to distributor drive is all aligned (and you do not want to touch it anymore) you could certainly take the tank based approach.
I've used the hex-shaft before during on-stand engine assembly, and that was great. However, you are tied up spinning the drill and that means you are not turning the engine, and/or observing the oil-flow. For that reason I picked up this tank and the intent is to plumb-it-up (tank feeds into the block oil pressure sensor passage), turn the valve to start the flow and go inspecting things as the pressure drains out of the tank and eventually the oil flow stops.
Heck, taking that a step further one could argue that this would be a good way to prep for the season's start as you take your ride out of the garage and get it road ready...I have never done that before, and the old 360 motor did not seem to suffer for it...but heck, an extra 1/2 hr. of care would seem to go a long way to get the oil up into all the necessary passages, so why not?
Re: New Oil Pump [Re: A727Tflite] #3060126
07/18/22 09:44 AM
07/18/22 09:44 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Nope, not me.
Re: New Oil Pump [Re: Diplomat360] #3060260
07/18/22 03:03 PM
07/18/22 03:03 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You could make one out of a garden sprayer for a heck of a lot less.
Re: New Oil Pump [Re: Sniper] #3060293
07/18/22 05:02 PM
07/18/22 05:02 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I picked up a used EL05 (which is a lot like this Melling Prelube Engine Oiler Tank Kits MPL-201 part) when a local machine shop was closing down. I haven't used it yet, although it appears to be literaly child's play easy!...
Absolutely you could...I bought mine used for under $50 so it fit my budget perfectly, but as you said, this is not a complex setup: tank, couple of valves, etc...when I got mine, having looked it over I thought: "hmm...old propane tank would do just fine"!!! lol
Re: New Oil Pump [Re: Diplomat360] #3061511
07/21/22 09:00 PM
07/21/22 09:00 PM
you might consider some porting/deburring on the new pump. there are some major obstructions that you can improve on with minimal effort
Re: New Oil Pump [Re: RapidRobert] #3061547
07/22/22 03:18 AM
07/22/22 03:18 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I did that
Re: New Oil Pump [Re: autoxcuda] #3061614
07/22/22 12:12 PM
07/22/22 12:12 PM
that looks good. up
beer
