Page 3 of 3 1 2 3
Re: vapor locking [Re: Dcuda69] #3059320
07/14/22 10:04 PM
07/14/22 10:04 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Originally Posted by Dcuda69
Originally Posted by TJP
The one method that does work but is a PITA to implement is to run a return line to the tank with a restricted ID that will keep the unused fuel moving back to the tank while maintaining adequate pressure at WOT.
This is why the fuel injected vehicles don't have issues. beer
The reason fuel injected engines don't suffer vapor lock issues is because of pressure...not the return line. Most late model injected stuff is returnless fuel injection.
valid point bow wink But one cannot put 45+ PSI to a carbonmaker beer
Re: vapor locking [Re: TJP] #3059402
07/15/22 01:22 PM
07/15/22 01:22 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
If any of my cars sit long enough for evaporation to empty the carburetor I spray brake cleaner into the carb before cranking. Fires right up. Might have to spray it twice but it saves the starter.
I think its good to crank a while to get oil pressure anyway if the engine has been sitting for a year.
Re: vapor locking [Re: lewtot184] #3059404
07/15/22 01:24 PM
07/15/22 01:24 PM
NW Illinois
NW Illinois
Originally Posted by lewtot184
another thing to think about is adequate venting of the fuel tank. i did some tests on some pumps and an original hipo 440 pump pulled 19" of vacuum. in fact it pulled more vacuum than any pump i tested. if the fuel supply system isn't properly vented high vacuum in the lines can contribute to the fuel flashing.
Agree, tank venting is important.
I've seen several cars over the years that had the factory fuel tank venting altered and it caused the tank to pull a vacuum causing the car to stall.
Re: vapor locking [Re: TJP] #3059406
07/15/22 01:26 PM
07/15/22 01:26 PM
NW Illinois
NW Illinois
Hot fuel at high pressure in the fuel line will be hot fuel at atmospheric pressure soon as it enters the float bowl where it can boil.
Re: vapor locking [Re: MoonshineMattK] #3059518
07/15/22 08:23 PM
07/15/22 08:23 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
I sure would not recommend spraying brake cleaner into a motor. Brake cleaner produces poisonous gas when it burns.
Re: vapor locking [Re: poorboy] #3059590
07/16/22 03:37 AM
07/16/22 03:37 AM
NW Illinois
NW Illinois
I've heard that before. We've always used non chlorinated brake cleaner. Must be why I've never had a problem. Evidently chlorinated brake cleaner can produce phosgene gas.
Page 3 of 3 1 2 3
