Re: New Power-Lok Clutches?
[Re: 500ciDuster]
#3058016
07/10/22 05:16 PM
07/10/22 05:16 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Power-Lock units don't have friction material on them like the Trac-loc units do. I've rebuilt a bunch of Power-Lock units with the current plain coated plates with good results. Make sure you coat each disc and plate with friction modifier when you re-assemble it. Remember to use red Lock-Tite on the threads and I use a spot of ARP lube under the head of the bolts so they don't gall. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 500ciDuster]
#3058891
07/13/22 01:33 PM
07/13/22 01:33 PM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
I would love to find an OEM Dana 70 Power Lok for my 1993 W250. I agree with Gus, all of the Dana and 8.75 power loks I have done hade uncoate steels and black coated Bellevue springs. I usually add .100 to the shim pack reusing the original thin shim. https://www.doctordiff.com/powr-lok-clutch-pack.html.I'd be interested in seeing pictures if you have a different style clutch pack.
[Re: 500ciDuster]
#3059476
07/15/22 05:30 PM
07/15/22 05:30 PM
Jeremiah
Rogue River, OR
Interesteing. I have never seen a Dodge unit come apart with those in 8.75 or a 60. I would imagine they are interchangeable? I might try a set like that with more than .100" added and see if it turn easier at low speeds. It seems that once I go .100 over the stock shim pack turning gets "tight" for lack of better words.
