Re: Pushrod oiling
[Re: FastmOp]
#3058563
07/12/22 12:52 PM
07/12/22 12:52 PM
Posts: 4,690 On the parachute mount
n20mstr
Looking to upgrade lifters from Comp to BAM. I was told BAM lifters need bushings. I run an Indy block with no bushings. I'm just trying to see what some of yall have done to upgrade. I currently run cup pushrods , do they make a cup with oil hole? Or do you got to convert to ball and ball and change adjusters
Thanks. How is your Indy block oiling the lifters???
....BAD A$$ STREET CAR.....
Re: Pushrod oiling
[Re: FastmOp]
#3058615
07/12/22 03:26 PM
07/12/22 03:26 PM
Posts: 8,902 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I was told BAM lifters need bushings Who told you and what is their reasoning ?? You can get ball/cup oil-through pushrods - quite common.
Re: Pushrod oiling
[Re: Stanton]
#3058632
07/12/22 04:05 PM
07/12/22 04:05 PM
Posts: 43,263 Bend,OR USA
Cab_Burge
I was told BAM lifters need bushings Who told you and what is their reasoning ?? You can get ball/cup oil-through pushrods - quite common. I have Manton make them for me for customers all the time I use AMC solid roller lifters for pushrod oiling
Re: Pushrod oiling
[Re: FastmOp]
#3058641
07/12/22 04:57 PM
07/12/22 04:57 PM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
do they make a cup with oil hole? Yep, they do.
Rich H.
Esse Quam Videri
Re: Pushrod oiling
[Re: FastmOp]
#3058683
07/12/22 07:39 PM
07/12/22 07:39 PM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Consider reading the post on rocker arm geometry before investing in cup type pushrods. There is a reason Jesel only uses ball and ball pushrods. I gather from B3 racings article it gets more critical as the performance level rises.
Re: Pushrod oiling
[Re: FastmOp]
#3058822
07/13/22 10:32 AM
07/13/22 10:32 AM
Posts: 16,929 NC
440Jim
NC
I got the BAM lifters in yesterday. They look decent. I need to get it mocked up and check pushrod length. Let us know how much different the lifter pushrod seat height is from the Comp lifters. My notes say the Comp 892 (pushrod oiling, not 829) have a seat height of 1.91", and the BAM 1.93". But I don't know if the companies measure it the same way. Comp defines seat height as top of a 5/16" ball in the pushrod seat. I have Comp 892 lifters and this picture shows what I measured. And it agrees with Comp's definition.
Re: Pushrod oiling
[Re: FastmOp]
#3058863
07/13/22 12:23 PM
07/13/22 12:23 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
I don't have a bunch of lift in it. About .650 lift I got the BAM lifters in yesterday. They look decent. I need to get it mocked up and check pushrod length. Get those ordered and see if it will work. I'll probably be the only guy oiling both ways lmfao
Can't wait to launch it again on my 512 I have stock & pushrod oiling, SO you are not alone lol
Re: Pushrod oiling
[Re: Stanton]
#3058935
07/13/22 03:34 PM
07/13/22 03:34 PM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
FWIW you can get away with pretty small restrictors especially using both oiling methods Id think. I have .029" at the lifters the last few engines with no ill affects.
Re: Pushrod oiling
[Re: CSK]
#3059141
07/14/22 10:24 AM
07/14/22 10:24 AM
ZIPPY
S.E. Michigan
Can't wait to launch it again on my 512 I have stock & pushrod oiling, SO you are not alone lol Pretty common to use both on Hemis with street intentions these days. Nedbal recommends it in his book. I did it to my 572.
Rich H.
Esse Quam Videri
