Pushrod oiling #3058562
07/12/22 12:49 PM
07/12/22 12:49 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Looking to upgrade lifters from Comp to BAM. I was told BAM lifters need bushings. I run an Indy block with no bushings. I'm just trying to see what some of yall have done to upgrade. I currently run cup pushrods , do they make a cup with oil hole? Or do you got to convert to ball and ball and change adjusters
Thanks.
Re: Pushrod oiling [Re: FastmOp] #3058563
07/12/22 12:52 PM
07/12/22 12:52 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Thanks.
How is your Indy block oiling the lifters???
....BAD A$$ STREET CAR.....
Re: Pushrod oiling [Re: n20mstr] #3058581
07/12/22 02:08 PM
07/12/22 02:08 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
It has pushrod oiling feature but I blocked them off
just run the oil lines in the back previously
Re: Pushrod oiling [Re: FastmOp] #3058615
07/12/22 03:26 PM
07/12/22 03:26 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Who told you and what is their reasoning ??
You can get ball/cup oil-through pushrods - quite common.
Re: Pushrod oiling [Re: Stanton] #3058632
07/12/22 04:05 PM
07/12/22 04:05 PM
Originally Posted by Stanton
Quote
iagree I have Manton make them for me for customers all the time up
I use AMC solid roller lifters for pushrod oiling scope
Re: Pushrod oiling [Re: FastmOp] #3058641
07/12/22 04:57 PM
07/12/22 04:57 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yep, they do.
Rich H.
Esse Quam Videri
Re: Pushrod oiling [Re: ZIPPY] #3058664
07/12/22 07:00 PM
07/12/22 07:00 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
What is the smallest hole in the cup you have ran.
Re: Pushrod oiling [Re: FastmOp] #3058683
07/12/22 07:39 PM
07/12/22 07:39 PM
gregsdart Offline
gregsdart  Offline
Consider reading the post on rocker arm geometry before investing in cup type pushrods. There is a reason Jesel only uses ball and ball pushrods. I gather from B3 racings article it gets more critical as the performance level rises.
Re: Pushrod oiling [Re: gregsdart] #3058774
07/13/22 06:56 AM
07/13/22 06:56 AM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
I don't have a bunch of lift in it. About .650 lift
I got the BAM lifters in yesterday. They look decent. I need to get it mocked up and check pushrod length. Get those ordered and see if it will work.
I'll probably be the only guy oiling both ways lmfao
Can't wait to launch it again
Re: Pushrod oiling [Re: FastmOp] #3058801
07/13/22 09:12 AM
07/13/22 09:12 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I liked the way Manton treated me and they have a nice pushrod. you can order down to .030 orifice in the pushrod last i saw. What ever you are using for rockers may need fulcrum oiling, typically a pushrod oiling system has pathways thru the adjuster to oil here. .060 is plenty orifice for the lifter body in a bushing often less. I havent seen any BAM lifters but some other brands axle oil thru an edm'd orifice. (this may be the reason pressurized oiling is requested to the lifter body) I suppose you can oil the rockers conventionally including the pushrod cup area. The lifter doesnt HAVE TO send oil upwards.
Re: Pushrod oiling [Re: FastmOp] #3058822
07/13/22 10:32 AM
07/13/22 10:32 AM
NC
440Jim Offline
440Jim  Offline
NC
Let us know how much different the lifter pushrod seat height is from the Comp lifters.
My notes say the Comp 892 (pushrod oiling, not 829) have a seat height of 1.91", and the BAM 1.93".
But I don't know if the companies measure it the same way. Comp defines seat height as top of a 5/16" ball in the pushrod seat.
I have Comp 892 lifters and this picture shows what I measured. And it agrees with Comp's definition.
Re: Pushrod oiling [Re: 440Jim] #3058830
07/13/22 10:46 AM
07/13/22 10:46 AM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
I use indy black rockers. I restrict oil to those as well.
I'll measure them this weekend Jim. I'm moving a CNC and Bridgeport to my new garage this week so no time to mess with it till then .
I'd like a smaller hole then .030 but that might work.
Re: Pushrod oiling [Re: FastmOp] #3058838
07/13/22 11:00 AM
07/13/22 11:00 AM
NC
440Jim Offline
440Jim  Offline
NC
Another picture just to help explain how I measured the pushrod seat height.
Re: Pushrod oiling [Re: FastmOp] #3058863
07/13/22 12:23 PM
07/13/22 12:23 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
on my 512 I have stock & pushrod oiling, SO you are not alone lol
Re: Pushrod oiling [Re: CSK] #3058926
07/13/22 03:05 PM
07/13/22 03:05 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Do the Indy rockers squirt oil towards the pushrod? If so, and the pushrods or adjusters aren't showing signs of heat or wear, why switch to pushrod oiling? Regardless of what you do, the rockers still need oil.
Re: Pushrod oiling [Re: Stanton] #3058935
07/13/22 03:34 PM
07/13/22 03:34 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW you can get away with pretty small restrictors especially using both oiling methods Id think. I have .029" at the lifters the last few engines with no ill affects.
Re: Pushrod oiling [Re: Al_Alguire] #3059101
07/14/22 06:50 AM
07/14/22 06:50 AM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
I put small holes in setscrews I had tapped into the lifter galleys when I 1st built it. I wanted a little oil in there to help lkeep the Comp rollers lubricated. I'm going to run it like that as long as the lifters don't uncover .
Re: Pushrod oiling [Re: CSK] #3059141
07/14/22 10:24 AM
07/14/22 10:24 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Pretty common to use both on Hemis with street intentions these days. Nedbal recommends it in his book. I did it to my 572.
Rich H.
Esse Quam Videri
