Hydraulic roller lifters on a solid roller cam #3058049
07/10/22 08:20 PM
07/10/22 08:20 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
I got a solid roller cam with a bunch of other parts recently and I have found a good deal on a set of hydraulic roller lifters. Now I'm not revving this engine over 6500 as this is a basic street/strip deal. I'm running a solid flat cam right now that is a little too rowdy on the street and low speed operation is not the best. The "gurus" on this site old me it might be too much when I installed it but I was going to go racing weekly but then Covid hit and everything changed. Now I only race it a few times a year with more weekly driving than I used to.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Hydraulic roller lifters on a solid roller cam [Re: fourgearsavoy] #3058074
07/10/22 09:43 PM
07/10/22 09:43 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
A short article about this very subject written by Marlan Davis at Motortrend
how-to/hydraulic-lifters-on-mechanical-cam
Posts on YellowBullit that say yes/no/maybe. Base circle of cam and location of oil band on hydraulic roller lifter need to be compatible.
https://www.yellowbullet.com/threads/hydraulic-roller-lifters-on-solid-roller-cam.279854/
Personally I would stick to a solid roller cam with solid roller lifters or hydraulic roller cam with hydraulic roller lifters unless the cam company says the cam profile is compatible with both types of lifters.
