Max Wedge 440RB Intake #3057095
07/07/22 12:07 PM
07/07/22 12:07 PM
California
GTXMEX Offline OP
GTXMEX  Offline OP
California
Can an Edlelbrock RPM intake be ported to Max Wedge size? My Trickflow intake that I will have ported to match my 270 heads keeps getting pushed out. Edelbrock Super Victor required a domanitor and I don't have space for a plate convertor. And I'm not knocking them but I don't see great, consistent feedback on Indy. So was hoping I could use an Edelbrock of some type and have ported.
Re: Max Wedge 440RB Intake [Re: GTXMEX] #3057098
07/07/22 12:18 PM
07/07/22 12:18 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Nothing wrong with INDY's intake. Don't confuse INDY of OLD vs. INDY and the new owners. Completely different.
69 GTX 68 Road Runner
Re: Max Wedge 440RB Intake [Re: JERICOGTX] #3057114
07/07/22 12:46 PM
07/07/22 12:46 PM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
Was at Indy on Tuesday and they have a boat load of intakes in house and I watched them machine the intake you are looking for.
Re: Max Wedge 440RB Intake [Re: GTXMEX] #3057128
07/07/22 01:18 PM
07/07/22 01:18 PM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
You must have missed the recent discussions on Edelbrock's quality issues, lol
Indy has gotten better, Edelbrock gotten worse.
Re: Max Wedge 440RB Intake [Re: GTXMEX] #3057204
07/07/22 04:22 PM
07/07/22 04:22 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
No.
Indy's dual-plane RB intake can be, if you're hoping to stay with that stye of intake.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Max Wedge 440RB Intake [Re: usp4u] #3057206
07/07/22 04:26 PM
07/07/22 04:26 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Edelbrock just moved their factilites and by all accounts are having casting issues.
'63 Dodge 330
11.19 @ 121 mph
Re: Max Wedge 440RB Intake [Re: GY3] #3057208
07/07/22 04:38 PM
07/07/22 04:38 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
the trick flow intake cannot be ported to match the 270 head without welding up the top. Todd
Re: Max Wedge 440RB Intake [Re: sasquatch] #3057792
07/09/22 09:28 PM
07/09/22 09:28 PM
California
GTXMEX Offline OP
GTXMEX  Offline OP
California
How certain are you about needing to weld up to port to max wedge size? I called Trickflow after your response and they said that is not the case.
Re: Max Wedge 440RB Intake [Re: GTXMEX] #3057816
07/09/22 11:02 PM
07/09/22 11:02 PM
AndyF Offline
AndyF  Offline
They'll tell you that it isn't the case since they don't sell a MW intake. If they sold a MW intake then they would tell you that you needed it.
If you want to make power then you need a MW intake. If you are okay giving up some power then a std port intake will work on a MW head as long as you have enough material to keep the gasket sealed up. I've tested this on the dyno before and there is a difference in power in a race engine. In a street engine it might not make any difference at all.
https://www.motortrend.com/how-to/dyno-day-trick-flow-270-mopar-heads/
Re: Max Wedge 440RB Intake [Re: AndyF] #3058029
07/10/22 06:24 PM
07/10/22 06:24 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
This I all I got. I have a standard port tunnel ram that was used on factory max Wedge heads. It was welded. I also have what looks like a CH4B with a dominator carb flange. It was also modified to fit Max Wedge heads. It has been welded to raise the ports. Hope it helps.
Getting old just means you were smarter than some and luckier than others.
Re: Max Wedge 440RB Intake [Re: dannysbee] #3058046
07/10/22 08:14 PM
07/10/22 08:14 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I don’t know how extensively TF “port matched” the manifold for this test, but they got pretty good results using their manifold.
https://static.trickflow.com/global/images/chartsguides/t/tfs-61617801-c01_wj.pdf
The cam doesn’t have tons of duration, and combined with the std port window......the combo peaks pretty early, and looks like the curve is dropping off.
Re: Max Wedge 440RB Intake [Re: fast68plymouth] #3058060
07/10/22 09:04 PM
07/10/22 09:04 PM
AndyF Offline
AndyF  Offline
Yeah I can see close to 700 hp on a 505 with a "ported" TF intake. That is roughly in the range we would expect that engine to make. This 505 made about 20 hp more than the TF engine and some of that could be due to the use of an Indy intake with the correct MW port size.
Re: Max Wedge 440RB Intake [Re: AndyF] #3058119
07/11/22 07:18 AM
07/11/22 07:18 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Andy, whose headers are those, they look efficient?
Is the K-frame and other support parts stock?
Thanks, Joe
Re: Max Wedge 440RB Intake [Re: jlatessa] #3058149
07/11/22 09:23 AM
07/11/22 09:23 AM
an8sec70cuda Offline
Thanks, Joe
They look like 5209 Hooker Super Comps.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Max Wedge 440RB Intake [Re: an8sec70cuda] #3058341
07/11/22 05:57 PM
07/11/22 05:57 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Trick Flow developed an RB MW 4500 intake a couple of years ago and never put it into production. It was on display at SEMA and PRI shows in fall of 2019 ==> HERE
Re: Max Wedge 440RB Intake [Re: Brad_Haak] #3058473
07/12/22 12:26 AM
07/12/22 12:26 AM
AndyF Offline
AndyF  Offline
Interesting that they never put that 4500 MW intake into production. Perhaps they figured that it was nothing more than a Super Victor clone so why bother.
Re: Max Wedge 440RB Intake [Re: AndyF] #3058549
07/12/22 11:40 AM
07/12/22 11:40 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Chicken and egg? Perhaps without an available intake they were not selling enough 270 heads to justify producing the intake. confused shruggy.
I really need a pounding head against the wall emoji.
Re: Max Wedge 440RB Intake [Re: GomangoCuda] #3058564
07/12/22 12:53 PM
07/12/22 12:53 PM
So. Burlington, Vt.
So. Burlington, Vt.
Another option for something that is flat hood friendly is the MP 337 manifold(part number P4876337).
They haven’t been made for several years, but pop up for sale on various sites from time to time.
It’s a fairly low profile single plane, with a 4150 carb flange and MW ports.
