For those of us that put away their Mopars in October, then bring them back out sometime during the spring (more like summer in MI), what steps do you like to check/perform before turning it over?
I connect the negative battery terminal, turn the key to "run", let the fuel pump fill the carburetor,
pump the throttle a few times and fire it up.
Sometimes I might get fancy and pump the throttle from under the hood, with the air cleaner off, or might hook up
a battery charger for a few minutes.
Did this with the flat tappet iron head 440 that served me well 1990 to 2001. Pulled to upgrade with nothing wrong with it.
