Drag Week is around the corner.... #3056207
07/05/22 11:57 AM
07/05/22 11:57 AM
Tulsa OK
Bad340fish Offline OP
Tulsa OK
So it is time to take apart a perfectly good running car haha.
Actually tore it down to change cams, we had struggled to find bushed roller lifters but ended up going with some comp lifters that have pressure oiling and will fit the R1 block. Upon tear down I found a rocker arm shaft getting eaten up and the cam bearings are really bad. I had a spare for the rocker shaft and they have all been inspected and put back together. Now to find someone who can fit it in for the cam bearings and fitting the new cam. I had hoped to start putting it back together this coming weekend but that isn't looking good.
I don't have the specs handy but the new cam is another solid roller 4-7 swap custom grind from comp. We got it in 2020 but chose not to tear it down for fear of parts availability before drag week in 2021. I ordered all the parts for the swap in February of this year and they all came in just this last few weeks.
Its been 10.42@126.8X with a 1.42 60ft @3550lbs on 91 octane. Would love for it to make it down in the 10.20s but feel we are nearing the end of this motors capability with W2s and pump gas.
68 Barracuda Formula S 340
Re: Drag Week is around the corner.... [Re: Bad340fish] #3056219
07/05/22 12:22 PM
07/05/22 12:22 PM
an8sec70cuda Offline
Somewhere, someone just laid the first frame rail on the jig for a fresh drag week build. You are just changing a cam...WAYYYY ahead of schedule for most drag weekers, lol.
Seriously though, hope it goes smoothly and runs better. That car is impressive. beer
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Drag Week is around the corner.... [Re: an8sec70cuda] #3056235
07/05/22 12:46 PM
07/05/22 12:46 PM
Tulsa OK
Tulsa OK
At least at this moment I feel pretty good about my time line.
As I was explaining to my 8 year old son what I was doing his first question was "what if it doesn't go as fast?"
Re: Drag Week is around the corner.... [Re: an8sec70cuda] #3056453
07/05/22 08:19 PM
07/05/22 08:19 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Hahaha that's likely quite true
eBay-cdwmotorsports
Re: Drag Week is around the corner.... [Re: cdwmotorsports] #3056475
07/05/22 09:28 PM
07/05/22 09:28 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Ever tell you I had a car just like yours but Red? LOL. After this build be sure to check with MCrow for the next build. Im sure hed help you out on parts.
Re: Drag Week is around the corner.... [Re: ksj] #3056488
07/05/22 10:40 PM
07/05/22 10:40 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Good luck with it, Bad!
Coincidentally, I worked on the HemiCoupe today for the first time since drag week. Time to leakdown and compression test the Hemi, fix a few gremlins from last year, then start getting it ready to dyno tune, and then some drag strip testing.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Drag Week is around the corner.... [Re: ksj] #3056489
07/05/22 10:45 PM
07/05/22 10:45 PM
Tulsa OK
Tulsa OK
Next engine will likely have 16 spark plugs.
Or it might just be this engine with a cheater whistle on it.
Re: Drag Week is around the corner.... [Re: Bad340fish] #3056493
07/05/22 11:17 PM
07/05/22 11:17 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Sounds like a plan.
Re: Drag Week is around the corner.... [Re: Hemi_Joel] #3056527
07/06/22 06:07 AM
07/06/22 06:07 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
About time you stopped goofing around, and got some work done... And lets face it, The only Drag strip testing it will get, will be the test day at Drag Week. LOL.
69 GTX 68 Road Runner
Re: Drag Week is around the corner.... [Re: Bad340fish] #3056534
07/06/22 07:11 AM
07/06/22 07:11 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
How strong is the R1 block and crank/rods? You've already got the EFI, it is the perfect time to fab up a Wu Tang War Whistle kit!
Re: Drag Week is around the corner.... [Re: Blusmbl] #3056567
07/06/22 09:34 AM
07/06/22 09:34 AM
Tulsa OK
Tulsa OK
Everything is built for NA but from good parts. I would imagine the weakest link would be the eagle crank.
Re: Drag Week is around the corner.... [Re: Bad340fish] #3058118
07/11/22 07:07 AM
07/11/22 07:07 AM
Tulsa OK
Tulsa OK
Got the cam bearings changed on Saturday at a good friends shop. Expected to leave it and instead we jumped on it and did it right there. I thought it would be easy to do with the short block assembled, we did it but it wasn't as easy as it was in my head haha.
While the block was in the truck we took it to my Dad's place because it was 98* and his shop is air conditioned. The cam card and the emails where the cam was discussed have to different installed centerlines, one 108, one 113 and the associated timing numbers are also off that 5*. Waiting on an email from comp to see which one is right, I am assuming the 108 number is the correct one, it installed at 114 off.
Re: Drag Week is around the corner.... [Re: Bad340fish] #3058181
07/11/22 11:20 AM
07/11/22 11:20 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Do you use the hardened coated cam bearings? With heavy valve springs I have found them to be more reliable than the standard bearings.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Drag Week is around the corner.... [Re: Hemi_Joel] #3058187
07/11/22 11:38 AM
07/11/22 11:38 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
How many dyno pulls did you make this last weekend? Ready for track testing now? Or did you spot a shiny object?
Re: Drag Week is around the corner.... [Re: Hemi_Joel] #3058189
07/11/22 11:48 AM
07/11/22 11:48 AM
Tulsa OK
Tulsa OK
No I don't I wasn't aware they were available until just recently. I hate to change to something new when I am pressed for time so I didn't make the change. The regular style survived 3 drag weeks and had been in there since 2015 so I hope these can manage the same life.
Re: Drag Week is around the corner.... [Re: Bad340fish] #3058434
07/11/22 11:03 PM
07/11/22 11:03 PM
CA, USA
JcodeCharger Offline
CA, USA
It sneaks up on you fast! I pulled a rocker stand bolt out of my W5 and its out getting repaired. I decided to have look at the motor overall. It looks good so hopefully the head repair goes well. I hope to see you there!
68 twin turbo Dart 8.19 so far
70 Swinger 360
69 Roadrunner 383 4 speed
69 Mod Top Satellite 383 auto
69.5 A12 Super Bee 4 speed
70 T/A Challenger
70 FC7 Duster 340 4 speed
70 FJ5 Superbird
68 Hemi 4 speed Roadrunner
71 Duster W2 340
Re: Drag Week is around the corner.... [Re: JcodeCharger] #3065700
08/06/22 09:14 AM
08/06/22 09:14 AM
Tulsa OK
Tulsa OK
It's all back together just waiting on pushrods. I pre oiled it last night and the comp 8043-16 lifters sure move a lot of oil out of the rollers. Way more than I expected. I am going to leave it on the stand until I get the pushrods in. I am debating installing it now and then putting all the rocker gear on or waiting for the pushrods to make the engine %100 ready. I honestly believe I can stab the engine faster than I can install the rockers with the engine in the car haha.
Smith Brothers said 4 weeks, I can't imagine how many pushrods it takes to create a 4 week back log.
Re: Drag Week is around the corner.... [Re: Bad340fish] #3072539
08/30/22 07:12 AM
08/30/22 07:12 AM
Tulsa OK
Tulsa OK
Car is back together and running, but after some inspection I got the pushrods a little long. They are going back to Smith Brothers this morning to be shortened. Should have them back the week before drag week. The Megasquirt EFI was able to wrangle the air fuel ratio to target before 7000RPM in first so the fuel isn't going to be too far off because it can only adjust 4% at wide open.
This "low shock" cam profile from comp sounds a little tamer at idle even with similiar duration but a good bit more lift. It lashes tighter than my old cam so the valvetrain is really quiet compared to the other setup.
