Re: Drag Week is around the corner....
[Re: Bad340fish]
#3056219
07/05/22 12:22 PM
07/05/22 12:22 PM
Posts: 13,368 Marion, South Carolina [><]
an8sec70cuda
Somewhere, someone just laid the first frame rail on the jig for a fresh drag week build. You are just changing a cam...WAYYYY ahead of schedule for most drag weekers, lol. Seriously though, hope it goes smoothly and runs better. That car is impressive.
[Re: an8sec70cuda]
#3056235
07/05/22 12:46 PM
07/05/22 12:46 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Somewhere, someone just laid the first frame rail on the jig for a fresh drag week build. You are just changing a cam...WAYYYY ahead of schedule for most drag weekers, lol. Seriously though, hope it goes smoothly and runs better. That car is impressive. At least at this moment I feel pretty good about my time line. As I was explaining to my 8 year old son what I was doing his first question was "what if it doesn't go as fast?"
68 Barracuda Formula S 340
[Re: an8sec70cuda]
#3056453
07/05/22 08:19 PM
07/05/22 08:19 PM
Posts: 1,451 Martinsville, IN
cdwmotorsports
Martinsville, IN
Somewhere, someone just laid the first frame rail on the jig for a fresh drag week build. You are just changing a cam...WAYYYY ahead of schedule for most drag weekers, lol. Seriously though, hope it goes smoothly and runs better. That car is impressive. Hahaha that's likely quite true
eBay-cdwmotorsports
[Re: ksj]
#3056488
07/05/22 10:40 PM
07/05/22 10:40 PM
Posts: 7,491 Minnesota
Hemi_Joel
Minnesota
Good luck with it, Bad!
Coincidentally, I worked on the HemiCoupe today for the first time since drag week. Time to leakdown and compression test the Hemi, fix a few gremlins from last year, then start getting it ready to dyno tune, and then some drag strip testing.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: ksj]
#3056489
07/05/22 10:45 PM
07/05/22 10:45 PM
Bad340fish
Tulsa OK
Ever tell you I had a car just like yours but Red? LOL. After this build be sure to check with MCrow for the next build. Im sure hed help you out on parts. Next engine will likely have 16 spark plugs. Or it might just be this engine with a cheater whistle on it.
[Re: Hemi_Joel]
#3056527
07/06/22 06:07 AM
07/06/22 06:07 AM
Posts: 10,029 MN
JERICOGTX
MN
About time you stopped goofing around, and got some work done... And lets face it, The only Drag strip testing it will get, will be the test day at Drag Week. LOL.
69 GTX
68 Road Runner
[Re: Bad340fish]
#3056534
07/06/22 07:11 AM
07/06/22 07:11 AM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
Ever tell you I had a car just like yours but Red? LOL. After this build be sure to check with MCrow for the next build. Im sure hed help you out on parts. Next engine will likely have 16 spark plugs. Or it might just be this engine with a cheater whistle on it. How strong is the R1 block and crank/rods? You've already got the EFI, it is the perfect time to fab up a Wu Tang War Whistle kit!
[Re: Blusmbl]
#3056567
07/06/22 09:34 AM
07/06/22 09:34 AM
Bad340fish
Tulsa OK
Everything is built for NA but from good parts. I would imagine the weakest link would be the eagle crank.
[Re: Bad340fish]
#3058118
07/11/22 07:07 AM
07/11/22 07:07 AM
Bad340fish
Tulsa OK
Got the cam bearings changed on Saturday at a good friends shop. Expected to leave it and instead we jumped on it and did it right there. I thought it would be easy to do with the short block assembled, we did it but it wasn't as easy as it was in my head haha.
While the block was in the truck we took it to my Dad's place because it was 98* and his shop is air conditioned. The cam card and the emails where the cam was discussed have to different installed centerlines, one 108, one 113 and the associated timing numbers are also off that 5*. Waiting on an email from comp to see which one is right, I am assuming the 108 number is the correct one, it installed at 114 off.
[Re: Bad340fish]
#3058181
07/11/22 11:20 AM
07/11/22 11:20 AM
Hemi_Joel
Minnesota
Do you use the hardened coated cam bearings? With heavy valve springs I have found them to be more reliable than the standard bearings.
[Re: Hemi_Joel]
#3058187
07/11/22 11:38 AM
07/11/22 11:38 AM
Posts: 10,029 MN
JERICOGTX
MN
Do you use the hardened coated cam bearings? With heavy valve springs I have found them to be more reliable than the standard bearings. How many dyno pulls did you make this last weekend? Ready for track testing now? Or did you spot a shiny object?
69 GTX
68 Road Runner
[Re: Hemi_Joel]
#3058189
07/11/22 11:48 AM
07/11/22 11:48 AM
Bad340fish
Tulsa OK
Do you use the hardened coated cam bearings? With heavy valve springs I have found them to be more reliable than the standard bearings. No I don't I wasn't aware they were available until just recently. I hate to change to something new when I am pressed for time so I didn't make the change. The regular style survived 3 drag weeks and had been in there since 2015 so I hope these can manage the same life.
[Re: Bad340fish]
#3058434
07/11/22 11:03 PM
07/11/22 11:03 PM
Posts: 263 CA, USA
JcodeCharger
CA, USA
It sneaks up on you fast! I pulled a rocker stand bolt out of my W5 and its out getting repaired. I decided to have look at the motor overall. It looks good so hopefully the head repair goes well. I hope to see you there!
68 twin turbo Dart 8.19 so far 70 Swinger 360 69 Roadrunner 383 4 speed 69 Mod Top Satellite 383 auto 69.5 A12 Super Bee 4 speed 70 T/A Challenger 70 FC7 Duster 340 4 speed 70 FJ5 Superbird 68 Hemi 4 speed Roadrunner 71 Duster W2 340
[Re: JcodeCharger]
#3065700
08/06/22 09:14 AM
08/06/22 09:14 AM
Bad340fish
Tulsa OK
It's all back together just waiting on pushrods. I pre oiled it last night and the comp 8043-16 lifters sure move a lot of oil out of the rollers. Way more than I expected. I am going to leave it on the stand until I get the pushrods in. I am debating installing it now and then putting all the rocker gear on or waiting for the pushrods to make the engine %100 ready. I honestly believe I can stab the engine faster than I can install the rockers with the engine in the car haha.
Smith Brothers said 4 weeks, I can't imagine how many pushrods it takes to create a 4 week back log.
[Re: Bad340fish]
#3072539
08/30/22 07:12 AM
08/30/22 07:12 AM
Bad340fish
Tulsa OK
Car is back together and running, but after some inspection I got the pushrods a little long. They are going back to Smith Brothers this morning to be shortened. Should have them back the week before drag week. The Megasquirt EFI was able to wrangle the air fuel ratio to target before 7000RPM in first so the fuel isn't going to be too far off because it can only adjust 4% at wide open.
This "low shock" cam profile from comp sounds a little tamer at idle even with similiar duration but a good bit more lift. It lashes tighter than my old cam so the valvetrain is really quiet compared to the other setup.
