New to me d100 truck #3054736
06/30/22 06:21 PM
06/30/22 06:21 PM
houston texas
gremlinsteve Offline OP
houston texas
Fell in love with this 80 model d100
Brought her home last night
383/727 combo runs well
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: New to me d100 truck [Re: gremlinsteve] #3054737
06/30/22 06:27 PM
06/30/22 06:27 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Nice. I have been looking for a decent and decently priced short bed for a while!
My Monster are real!
Living within your means makes life pretty easy.
Re: New to me d100 truck [Re: 67vertman] #3054824
06/30/22 11:21 PM
06/30/22 11:21 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
that's very nice. up
Re: New to me d100 truck [Re: gremlinsteve] #3054880
07/01/22 09:44 AM
07/01/22 09:44 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
Tease! more pics please. Nice score.
1981 Dodge D150 360 auto
Re: New to me d100 truck [Re: basketcase] #3055086
07/01/22 10:41 PM
07/01/22 10:41 PM
houston texas
houston texas
Pics
Re: New to me d100 truck [Re: gremlinsteve] #3055125
07/02/22 06:37 AM
07/02/22 06:37 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Re: New to me d100 truck [Re: gremlinsteve] #3055245
07/02/22 01:22 PM
07/02/22 01:22 PM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
Very Nice
Re: New to me d100 truck [Re: gremlinsteve] #3055246
07/02/22 01:22 PM
07/02/22 01:22 PM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
Very Nice
Re: New to me d100 truck [Re: Webster] #3055330
07/02/22 07:30 PM
07/02/22 07:30 PM
South-east Mn
blaze Offline
blaze  Offline
South-east Mn
drool
Re: New to me d100 truck [Re: blaze] #3055342
07/02/22 08:44 PM
07/02/22 08:44 PM
houston texas
houston texas
Pic
Re: New to me d100 truck [Re: gremlinsteve] #3055351
07/02/22 09:00 PM
07/02/22 09:00 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: New to me d100 truck [Re: gremlinsteve] #3055367
07/02/22 09:53 PM
07/02/22 09:53 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Nice truck. Talk to Alex much anymore? shruggy
Re: New to me d100 truck [Re: Hugh Jorgan] #3055370
07/02/22 10:01 PM
07/02/22 10:01 PM
houston texas
houston texas
Oh yes. All the time
Re: New to me d100 truck [Re: gremlinsteve] #3055708
07/04/22 04:33 AM
07/04/22 04:33 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Sweet. up
Re: New to me d100 truck [Re: gremlinsteve] #3055757
07/04/22 11:41 AM
07/04/22 11:41 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
Nice reminds me of the 73 D-100 i had with a slightly built 360,use give the mustangs Hell up
Re: New to me d100 truck [Re: racerx] #3056421
07/05/22 05:59 PM
07/05/22 05:59 PM
San Diego
JP8 Offline
JP8  Offline
San Diego
Beautiful stance. What are the wheels and tire specs?
Instagram : @5_points_racing
Re: New to me d100 truck [Re: JP8] #3059546
07/15/22 10:31 PM
07/15/22 10:31 PM
houston texas
houston texas
295/50/15 on the rear
235/50/15 on the front I think
The wheels are unknown other than the rears are ten inch wide.
This is the way I purchased it
I just blew out the fuel pump
At least I hope that’s what it is
The fuel no Getty to carb so I can only assume it’s the pump
If not the pump I’ll be needing to research the issue more from the pump back
I also received my Cvf racing kit in today
This kit mounts the ac compressor I’ve bought. I also received my ac underdash system
So I should be don’t with this by Monday
I’d like then to try my converter install. This stock converter works great but I’m wanting to rid myself of two issues. The massive rpm drop from park to drive. And the truck trying to push through the brakes while idling in gear
Which me luck
Re: New to me d100 truck [Re: gremlinsteve] #3059951
07/17/22 03:05 PM
07/17/22 03:05 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Which me luck
As far as the fuel pump goes, I have had rubber lines at the tank crack before so the pump couldn't pick up the fuel. When you disconnect the tank line from the pump, put a little air pressure in it and crawl under to listen for a possible leak. Since you are taking that line loose either way, it doesn't take long to check.
Re: New to me d100 truck [Re: mgoblue9798] #3059974
07/17/22 04:22 PM
07/17/22 04:22 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
had one where the metal line coming out of the fuel sender rotted so it was sucking air.
Re: New to me d100 truck [Re: basketcase] #3060020
07/17/22 08:09 PM
07/17/22 08:09 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
A agree with both of the above. I've repaired the steel line coming through the sending unit, as well as between the tank and the frame. I have also seen both the rubber hoses at each end of the steel lines cracked enough they didn't leak fuel, but could suck air. Look the fuel lines and the rubber in them over carefully. Probably wouldn't hurt to at least change the hoses.
Lets not forget that some carbs have a brass filter at the fuel inlet (especially if someone swapped a GM carb onto your truck), or an inline filter that could also be plugged.
