Procedure to start a vehicle after sitting for approx. 1yr? #3054571
06/30/22 06:22 AM
06/30/22 06:22 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
For those of us that put away their Mopars in October, then bring them back out sometime during the spring (more like summer in MI), what steps do you like to check/perform before turning it over?
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: vinnyd76] #3054601
06/30/22 09:32 AM
06/30/22 09:32 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've had my vehicles sit as long as 5 yrs (garaged)....I change the oil/filter, antifreeze,fresh gas, fill the carbs with gas thru the vent tubes, and I fill the engine with oil just before I light it off, so as to flood the cam/lifter valley area....never had an issue with the 10 vehicles I've owned over the last few decades .... I just started up my daughter's "new" to her, 1961 Fury/Bev that sat for 20 yrs in the owner's garage untouched, last year, granted it needed a new tank/lines/fuel pump/carb,....but the motor turned and fired right up with zero issues with a new oil/filter/ and antifreeze after a generous block flush..zero issues for the motor.
MikeG
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: vinnyd76] #3054615
06/30/22 10:02 AM
06/30/22 10:02 AM
North Tonawanda
Checker Offline
Checker  Offline
North Tonawanda
I put Mine away in late October with drygas run through the system..take out the battery...lower the visors..put some decon on the carpets and all around the garage and cover. Come April I install battery and fire the beast up. Run until warm and then change oil and filter. Same with snowblower and lawn mower. Never a problem.
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: Checker] #3054619
06/30/22 10:08 AM
06/30/22 10:08 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I put mine away in Oct...got it out in May. Check oil and anti-freeze, install charged battery and fire it up. Done it like that for well over 25 years...zero issues.
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: Checker] #3054620
06/30/22 10:10 AM
06/30/22 10:10 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I just charge up the battery, check the fluids I can, put some fresh gas in, put a splash of gas down the carb and fire it up.
Of course that assumes you stored it properly, which is what the question ought to have been.
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: Sniper] #3054685
06/30/22 01:22 PM
06/30/22 01:22 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Put some gas in a Coke bottle, dump in carb, start. One more time if it stalls
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: cudaman1969] #3054700
06/30/22 01:57 PM
06/30/22 01:57 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Thank you for the feedback thus far.
Wanted to ask the form about removing coil plug from distributor and cranking a couple times, then reinstalling plug. I'm told this step helps to bring some oil up before actually starting, but does that cause engine engine/system damage? Thoughts?
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: vinnyd76] #3054701
06/30/22 02:03 PM
06/30/22 02:03 PM
Kirkland, Washington
Pacnorthcuda Offline
I’m not a big fan of that as the engine is still fighting compression. Taking the plugs out and spinning it without compression is beneficial, but more work. With the plugs in I want it to fire as soon as possible.
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: Pacnorthcuda] #3054705
06/30/22 02:37 PM
06/30/22 02:37 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ Agree.
A couple other quick light-off tricks are carb cleaner or starting fluid sprayed into the carb.
With a remote starter switch & key in run, you can light the car off standing next to it.
Don't look into the carb while doing this, though...
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: DAYCLONA] #3054706
06/30/22 02:46 PM
06/30/22 02:46 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
When mine has sat for a while I like to pull the distributor and intermediate shaft (I take quick pics of location of both with cell phone for quick re-assembly) and use a hex priming tool with a drill to get oil throughout the engine first.
'63 Dodge 330
11.19 @ 121 mph
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: vinnyd76] #3054777
06/30/22 09:02 PM
06/30/22 09:02 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
NONE! Some will say a bit of cranking may help by priming the oiling system but other will say it's going to take the same number of revolutions whether it's running or not.
However then again the lower end is not under the same load while cranking as it is running, but the lifter to cam interface is not getting lubed,
So, the correct answer depends on whether you are a democrat or republican? LOL
On a more serious side I don't know anyone that has done anything other than hit the electric pump, give it 2 or 3 pumps and hit the key, or crank till it gets fuel while pumping until it starts. twocents beer
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: TJP] #3054802
06/30/22 10:17 PM
06/30/22 10:17 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
You forgot a very important step as some have already mentioned, check and CHARGE the battery wink grin
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: A12] #3054905
07/01/22 11:43 AM
07/01/22 11:43 AM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
I check the charge by turning the key. If it turns and fires, charge good. If it don't turn, charge the battery. thumbs
Kevin
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: A12] #3054922
07/01/22 12:25 PM
07/01/22 12:25 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I disconnectthe batteries when parking for extended periods. Current one in my 38 I believe is about done after ~ 12 years wink
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: TJP] #3054990
07/01/22 06:34 PM
07/01/22 06:34 PM
PA
70Duster Offline
70Duster  Offline
PA
I don't do anything except reconnect the negative battery cable and fire it up. Never a problem in over 40 years.
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: 70Duster] #3055072
07/01/22 10:11 PM
07/01/22 10:11 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: TJP] #3056306
07/05/22 02:22 PM
07/05/22 02:22 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
I like to prime with a drill on a nice engine. If it’s and older hi miler just start it up. Yes charge batt and fill the float bowls first.
Cranking with coil wire off to get oil pressure is counter productive, just start it is a better idea. More RPM and quicker oil pressure.
Next time you have the intake off, pour 5 quarts of oil in the usual valve cover filler. It does not flood the lifter valley, it runs down in a few areas and the rest of it is dry. Along with most of the cam lobes.
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: NANKET] #3056315
07/05/22 02:40 PM
07/05/22 02:40 PM
moparx Offline
moparx  Offline
if you are changing the oil anyway, i have a pressure tank i fill with oil and 45psi, then attach the outlet hose to the oil pressure switch/gauge tap, then push the needed quantity of oil through there.
it seems to work, as there is instant oil pressure upon start up. as i always do, the filter is filled before installing it.
however, i have often wondered just how the oil goes through the engine passage[s] using this method, and if it works like i hope it should.
beer
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: moparx] #3056485
07/05/22 10:26 PM
07/05/22 10:26 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
It won't unless the engine is rotating. Even then you're still lacking the splash oiling for the cam lobes and lifters frown beer
Re: Procedure to start a vehicle after sitting for approx. 1yr? [Re: TJP] #3056637
07/06/22 12:23 PM
07/06/22 12:23 PM
moparx Offline
moparx  Offline
i forgot to add, i rotate the engine with a ratchet and socket on the crank damper bolt.
you are correct about the splash oiling on the cam and lifters.
next engine i have on the stand, i'll have to remember to try this with the intake off, to see what happens.
beer
