Re: fuel bowl gaskets help
[Re: CMcAllister]
#3053129
06/24/22 07:51 PM
06/24/22 07:51 PM
Posts: 1,118 Loudoun County, VA
Brad_Haak
Loudoun County, VA
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3053134
06/24/22 07:57 PM
06/24/22 07:57 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I had some BLP carb kits that came with gaskets that only had the one acc pump hole....... but they were interchangeable with the typical ones with two holes.
