fuel bowl gaskets help #3053081
06/24/22 05:41 PM
06/24/22 05:41 PM
Sacramento
morgdavex Offline OP
Sacramento
I need one like this but cant find it. look it only has one hole punch for acc pump.
Re: fuel bowl gaskets help [Re: morgdavex] #3053096
06/24/22 06:14 PM
06/24/22 06:14 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
There’s no pic. Call Greg at superformance.
Re: fuel bowl gaskets help [Re: rickraw] #3053110
06/24/22 07:06 PM
06/24/22 07:06 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Carb List # will help.
Re: fuel bowl gaskets help [Re: CMcAllister] #3053129
06/24/22 07:51 PM
06/24/22 07:51 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
And a pic...
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: fuel bowl gaskets help [Re: Brad_Haak] #3053134
06/24/22 07:57 PM
06/24/22 07:57 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I had some BLP carb kits that came with gaskets that only had the one acc pump hole....... but they were interchangeable with the typical ones with two holes.
