Preferred brake line vendor? #3049004
06/08/22 09:00 PM
06/08/22 09:00 PM
NW/Indiana - Chi town
ricomondo Offline OP
Seems to be a plethora of brake line vendors;
Fine Lines -
Right Stuff -
InLine tube -
Is there one vendor with a better product than most?
I'll be replacing front/rear brake lines, fuel and the emission line on 71' Demon.
GY3 71 Demon 340
Re: Preferred brake line vendor? [Re: ricomondo] #3049015
06/08/22 09:34 PM
06/08/22 09:34 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Fine Lines -
Right Stuff -
InLine tube -
I've used all 3 over the decades, and I would go to them in the order that you listed them, with Fine lines being your best choice.....
Re: Preferred brake line vendor? [Re: DAYCLONA] #3049152
06/09/22 03:43 PM
06/09/22 03:43 PM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
We had issues with new distribution blocks leaking a few years back. I can't remember which company had the issue, bit it was a PITA.
Re: Preferred brake line vendor? [Re: ricomondo] #3049191
06/09/22 06:38 PM
06/09/22 06:38 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Inline tube
1969 Hemi Roadrunner 2nd owner
Re: Preferred brake line vendor? [Re: 69hemibeep] #3049238
06/09/22 08:56 PM
06/09/22 08:56 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ive used all 3.
Cant say ive ever had a major issue with any of them
But my primary is Fine Lnes
But just got trans and fuel lines from inline . No complaints
Re: Preferred brake line vendor? [Re: ricomondo] #3049523
06/10/22 10:10 PM
06/10/22 10:10 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
"Right Stuff" brake lines for my Cuda we're the "wrong stuff", not even close to fitting. I can see having to tweak, they were short and off in areas you couldn't tweak. I went to inline.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Preferred brake line vendor? [Re: A39Coronet] #3050492
06/14/22 01:42 PM
06/14/22 01:42 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
I have had issues with all of them. The latest with Inline:
1) Received someone else's order. I ordered a 7 piece brake line kit and a return fuel line. I got some transmission lines
2) Got the re order. Brake lines were sent. Got the wrong return fuel line.
3) Received the correct return fuel line. Tried to install the front to rear brake line. Took off the rubber cap and had this flare (pic below) Waiting for the replacement.
Re: Preferred brake line vendor? [Re: belv2vert66] #3050500
06/14/22 01:51 PM
06/14/22 01:51 PM
moparx Online content
moparx  Online Content
how much do you have in return shipping costs ?
beer
Re: Preferred brake line vendor? [Re: moparx] #3050749
06/15/22 01:46 PM
06/15/22 01:46 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
beer
Thank goodness none. They sent me a label for the incorrect order. The rest they said I could keep........
Re: Preferred brake line vendor? [Re: ricomondo] #3050790
06/15/22 05:21 PM
06/15/22 05:21 PM
Alabama
W
WarEagle1 Offline
WarEagle1  Offline
W
Alabama
I just used a set for a '72 Road Runner from Right Stuff and they were spot-on perfect. Perfect fit and no leaks.
Re: Preferred brake line vendor? [Re: belv2vert66] #3050976
06/16/22 01:46 PM
06/16/22 01:46 PM
beer
beer
Re: Preferred brake line vendor? [Re: belv2vert66] #3052184
06/21/22 01:46 PM
06/21/22 01:46 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
Well here is number 4. Received another front to rear return fuel line. Not even stainless........
Another try for the brake line is on the way now.
Re: Preferred brake line vendor? [Re: belv2vert66] #3118013
01/31/23 10:38 PM
01/31/23 10:38 PM
eastern L.I. ,NYC
K
kingdragon Offline
kingdragon  Offline
K
eastern L.I. ,NYC
Inline tube fuel line set for my 71 R/T is not even close. 3' short on the return line and all three have bends that are off by 6". All three lines are intended from the factory to run parallel to their destination, not the inline tube set. Worst part is their short so I can't even alter two out of the three.
No gravel guard like factory set either. I should've bent them all myself like I've always done.
I only buy MADE IN USA.
Re: Preferred brake line vendor? [Re: WarEagle1] #3118096
02/01/23 12:53 PM
02/01/23 12:53 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
I bought trans lines from right stuff. Never again.
67 Hemi auto. The long line for the rear of the trans was hanging down 4” below the trans pan. Why? It would have hit the ground on speed bumps and driveways.
Idiots made that one. The front cooler stuff was close but all had to be reshaped to fit and look decent.
Re: Preferred brake line vendor? [Re: NANKET] #3118215
02/02/23 12:10 AM
02/02/23 12:10 AM
Washington, MI
Ashsdad Offline
Whatever you call me, my wife has called me worse.
Ashsdad  Offline
Washington, MI
Not for my Challenger (that is yet to come), but I put a full set of stainless lines from Inline in my '02 Silverado. The job was a PIA, but it wasn't because of the lines. They fit just fine. Only issue was getting them to seal on the ABS controller. One line didn't want to play nice. I wrote that off to them being stainless. Finally got it to seal. Fit to the chassis was almost perfect.
Advantage for me is that they are local so I can pick up or exchange in person if necessary.
Re: Preferred brake line vendor? [Re: Ashsdad] #3118586
02/03/23 12:47 PM
02/03/23 12:47 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
Fine Lines. They custom made a Holley DP set up for me in a matter of days!
