What kind of break-in oil to use? #3052100
06/20/22 11:08 PM
06/20/22 11:08 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
In the next week or two I'll be looking to fire up my rebuilt 383 (hydraulic flat tappet) . What break-in oil, or additive, and weight do you prefer?
Re: What kind of break-in oil to use? [Re: VITC_GTX] #3052134
06/21/22 08:49 AM
06/21/22 08:49 AM
White Plains, NY
VCODE Online boogie
VCODE  Online Boogie
White Plains, NY
I like Penn1 30 Break in oil. Old name Brad Penn.
Spoke with tech just the other day about the high zinc and was told it's the same oil and has not been changed.
Bob.
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: What kind of break-in oil to use? [Re: VCODE] #3052146
06/21/22 10:12 AM
06/21/22 10:12 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Penn, Lucas, Gibbs...all good.
I'm sure you know the procedure.
Re: What kind of break-in oil to use? [Re: topside] #3052240
06/21/22 08:01 PM
06/21/22 08:01 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
GM E.O.S. is what I used years ago.
Re: What kind of break-in oil to use? [Re: VITC_GTX] #3052242
06/21/22 08:03 PM
06/21/22 08:03 PM
Valvoline VR10x30 with a bottle of zinc additive up twocents
Re: What kind of break-in oil to use? [Re: Cab_Burge] #3052267
06/21/22 09:22 PM
06/21/22 09:22 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks guys.
Van
Re: What kind of break-in oil to use? [Re: VITC_GTX] #3052274
06/21/22 09:46 PM
06/21/22 09:46 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Last 2 solid cam engines I built were broken in with Gibbs break in oil and are both still going strong 10 years later up
Gus beer
64 Plymouth Savoy
Dana 60
Re: What kind of break-in oil to use? [Re: VITC_GTX] #3052370
06/22/22 11:36 AM
06/22/22 11:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What make cam? At least one cam maker sells their own labeled break in additive.
Re: What kind of break-in oil to use? [Re: fourgearsavoy] #3052608
06/23/22 08:12 AM
06/23/22 08:12 AM
an8sec70cuda Offline
I've used Joe Gibbs Driven break-in oil in the most recent flat tappet motors I've built and haven't had any issues. No need for any additive.
About 4 years ago I used Valvoline VR1 race oil w/ Comp Cams break-in additive on a 440 hyd. flat tappet build. No problems w/ that one either.
These were all fairly mild hydraulic flat tappet cam street engines. Anything aggressive, I prefer a roller. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What kind of break-in oil to use? [Re: an8sec70cuda] #3052641
06/23/22 10:02 AM
06/23/22 10:02 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Cam builder's break-in lube on all rubbing surfaces and Valvoline VR1 10-30 (for my clearances) and no problems here either.
Joe
Re: What kind of break-in oil to use? [Re: jlatessa] #3052697
06/23/22 12:18 PM
06/23/22 12:18 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
For every brand of break in oil and additive that’s available........ it’s someones favorite.
My favorite is the Driven “BR”, which is 15/50.
