Electric water pumps
#3051973
06/20/22 12:32 PM
06/20/22 12:32 PM
Posts: 11,578 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Pulling the old Moroso heater motor kit from a Stocker project for an electric unit.
Leaning Meziere. Who makes the best one these days? Reliable, flow, pressure. Cost is not an issue. Failing in late rounds is.
Re: Electric water pumps
[Re: CMcAllister]
#3051977
06/20/22 12:52 PM
06/20/22 12:52 PM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
Most people will say Meziere I would guess, but in 20 odd years now running the billet Moroso electric water pumps on small block’s I have never had a failure . Cool well between rounds, 12 or 16 volt, pump plenty of water even for street use which I often do. So sold on the reliability at this point you couldn’t give me anything else
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#3051991
06/20/22 01:45 PM
06/20/22 01:45 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Failed to mention, going on a BB Ferd. Weight is also a consideration.
[Re: CMcAllister]
#3052035
06/20/22 03:57 PM
06/20/22 03:57 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Still running the same Meziere pump on my hemi that I put on it in 2008. The Camaro had a CSI/CSR on it that was around 12 years old before it died. Replaced it w/ a Meziere that's now 8 years old or so and still going strong.
[Re: jwb123]
#3052040
06/20/22 04:23 PM
06/20/22 04:23 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Mezziere here as well, I did have a problem with it when it was 15 or so years old. I sent to to them, they inspected it, called it dead, and had me a new one shipped within an hour of my UPS tracking notifying me that they received it. It of course was out of warranty at that age but they were quick to diagnose it and get one heading back my way.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3052048
06/20/22 05:11 PM
06/20/22 05:11 PM
Posts: 2,923 A shed in England
Tig
A shed in England
Been using a Meziere WP 105 successfully for some time (the one that fits in the stock pump housing) It's been in 3 engines, likely over 15 years old now I think about it. I have a S/H spare just in case. Gets my vote
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Sammy]
#3052147
06/21/22 10:15 AM
06/21/22 10:15 AM
Posts: 47 S.E. Michigan
TruPerformance
S.E. Michigan
Does the Meziere WP105S fit in the stock type aluminum housing? I assume that the aluminum is the same as a stock cast housing, but just checking before ordering....
1963 Belvedere (mine) 1969 Roadrunner (wife's)
[Re: CMcAllister]
#3052148
06/21/22 10:16 AM
06/21/22 10:16 AM
Bad340fish
Tulsa OK
Sold. Meziere in the mail. If you have never had your hands on one you will be impressed, they are a beautiful piece.
[Re: TruPerformance]
#3052152
06/21/22 10:40 AM
06/21/22 10:40 AM
Tig
A shed in England
Does the Meziere WP105S fit in the stock type aluminum housing? I assume that the aluminum is the same as a stock cast housing, but just checking before ordering.... No issues on mine, old M/P aluminum one. D/S inlet. HTH's
[Re: Tig]
#3052169
06/21/22 12:12 PM
06/21/22 12:12 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
IMO you made the right choice. i have one thats been in one of my hoopties since 2000.Only had an issue once and as stated they had it fixed and back to me the next week.
