Moved Centerline Mopars #3051625
06/18/22 10:53 PM
06/18/22 10:53 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Who offers MC heads, and then where do you get a MC block.....How big can you go?
Re: Moved Centerline Mopars [Re: Dragula] #3051664
06/19/22 09:05 AM
06/19/22 09:05 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I think Indy did some 4.84 maybe for the 600-13 heads?
2011 Drag Pak Challenger
Re: Moved Centerline Mopars [Re: Dragula] #3051671
06/19/22 10:19 AM
06/19/22 10:19 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
B1 MC do not require a special block, but I think the smallest bore they work on is 4.5 due to the 2.4 intake valve.
Joe
Without Data, you’re just another guy with an opinion.
Re: Moved Centerline Mopars [Re: sr4440] #3051703
06/19/22 12:39 PM
06/19/22 12:39 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Indy 4.84 bore space block is 4.563 bore. Mopar made 5" bore space Pro stock Hemi heads and blocks. New Century blocks makes a 4.900 bore space block that they will put various head bolt patterns on. I thought about having one made with the Pro Stock Hemi bolt pattern on. You would need to put the lifter bores in the correct locations. None are easy or cheap.
Re: Moved Centerline Mopars [Re: Dragula] #3051707
06/19/22 12:52 PM
06/19/22 12:52 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Are you talking MC(moved centerine of the valves)thats only B1 stuff and the MC head.If oyu are talking spread bore then Indy make a 4.84 BS block that uses a 600-13 head. You can also get spread bore stuff in the form of B1 TS on a Donovan or KB block. they come in 4.8, 4.84and 4.9bore space varieties. Then as mentioned there is the pro stock stuff with is 4.9, and 5" stuff
Re: Moved Centerline Mopars [Re: Al_Alguire] #3051736
06/19/22 02:35 PM
06/19/22 02:35 PM
Dragula Offline OP
Dragula  Offline OP
Moved bore center line...
Re: Moved Centerline Mopars [Re: Dragula] #3051752
06/19/22 03:31 PM
06/19/22 03:31 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Indy or Kb block for cast, water blocks
You want new ?
Brad Anderson is where u need to be looking .
Re: Moved Centerline Mopars [Re: FastmOp] #3052053
06/20/22 05:24 PM
06/20/22 05:24 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
So spread bore..The choices are listed and only work with the spread bore head options, which are very limited. FWIW I run a 4.84" borespace Indy block
Re: Moved Centerline Mopars [Re: Al_Alguire] #3052058
06/20/22 05:34 PM
06/20/22 05:34 PM
Dragula Offline OP
Dragula  Offline OP
Which heads do you run with it?
