Re: Moved Centerline Mopars
[Re: Dragula]
#3051671
06/19/22 10:19 AM
06/19/22 10:19 AM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
B1 MC do not require a special block, but I think the smallest bore they work on is 4.5 due to the 2.4 intake valve.
Joe
Without Data, you’re just another guy with an opinion.
[Re: Dragula]
#3051707
06/19/22 12:52 PM
06/19/22 12:52 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Are you talking MC(moved centerine of the valves)thats only B1 stuff and the MC head.If oyu are talking spread bore then Indy make a 4.84 BS block that uses a 600-13 head. You can also get spread bore stuff in the form of B1 TS on a Donovan or KB block. they come in 4.8, 4.84and 4.9bore space varieties. Then as mentioned there is the pro stock stuff with is 4.9, and 5" stuff
[Re: FastmOp]
#3052053
06/20/22 05:24 PM
06/20/22 05:24 PM
Al_Alguire
Las Vegas
So spread bore..The choices are listed and only work with the spread bore head options, which are very limited. FWIW I run a 4.84" borespace Indy block
[Re: Al_Alguire]
#3052058
06/20/22 05:34 PM
06/20/22 05:34 PM
Posts: 12,388 Taxes & Virus's R-US, NY
Dragula
So spread bore..The choices are listed and only work with the spread bore head options, which are very limited. FWIW I run a 4.84" borespace Indy block Which heads do you run with it?
