Re: 563ci build specs, what will it make?
[Re: J_BODY]
#3051212
06/17/22 10:08 AM
06/17/22 10:08 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I’m sickened by this…. this hobby serves up such a beat down sometimes When you get in the ring with a serious contender , you know that you're going to be hit. You can still win the fight. I've had parallel experiences , though not at this price or power level. But the bruises to the psyche sure seem to last. I hope it isn't too severe , or difficult to pin down.
[Re: tubtar]
#3051457
06/18/22 09:48 AM
06/18/22 09:48 AM
Posts: 8,163 Plymouth, MI
Blusmbl
Plymouth, MI
I'm so sorry Jeff, this is brutal. I hope it's a relatively easy repair and you're only out time.
[Re: birdtracker]
#3058725
07/12/22 10:15 PM
07/12/22 10:15 PM
Posts: 10,021 MN
JERICOGTX
MN
Update: After running the engine on the dyno for only a couple minutes, we found water in the oil. Pulled the engine off the dyno right away, and once it was back in my garage, I pressure tested the cooling system, and immediately found the leak. The water was coming from in between the block casting, and sleeve. A good friend helped me tear everything down, so I could get the block back to the machinist right away. Once it was back at his shop we discussed what happened, and where to go from there. He called this last Saturday, and said he has the sleeve out and pressure tested the block, and found a crack at the bottom of the bore. Today, I brought the block home, and prepared the block to be welded tomorrow, and then I bring the block back, to have the sleeve reinstalled. Before anyone goes off, I’m not blaming anyone. Sh!t happens. This was a used, damaged block, that I bought extremely cheap. I have less into this thing than the fully prepared 400 block I had done nearly 20 years ago. It’s just the risk you take. It’s being taken care of. Time to move forward.
69 GTX
68 Road Runner
[Re: Cab_Burge]
#3058776
07/13/22 07:06 AM
07/13/22 07:06 AM
Posts: 10,021 MN
JERICOGTX
MN
I try to make the best of all my experiences, if I don't have the bad ones now and then I don't really enjoy the good one. Sounds like you have a bunch of good times in front of you You have to take the not so good experiences in stride. For myself, it makes me learn about the problem, and how to go about fixing it. A couple years ago, I was having an issue with my Jerico trans. and was getting ready to load the car up in the trailer, when the racer next to me came walking over. He said, "It sucks having stuff go wrong, but do you see all these people walking into the gate, and into the stands? They wish they could be doing what you're doing now, instead of being a spectator. You'll get it fixed, and be back out again."
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3058781
07/13/22 07:27 AM
07/13/22 07:27 AM
Posts: 25,900 United Socialist States of Ame...
tboomer
I try to make the best of all my experiences, if I don't have the bad ones now and then I don't really enjoy the good one. Sounds like you have a bunch of good times in front of you You have to take the not so good experiences in stride. For myself, it makes me learn about the problem, and how to go about fixing it. A couple years ago, I was having an issue with my Jerico trans. and was getting ready to load the car up in the trailer, when the racer next to me came walking over. He said, "It sucks having stuff go wrong, but do you see all these people walking into the gate, and into the stands? They wish they could be doing what you're doing now, instead of being a spectator. You'll get it fixed, and be back out again." And Jeff. That fella was right! You have the knowledge and desire to get it fixed and be back out there! I have not been down the track in my car in ten years and it sits in my garage. I can't even bring myself to go spectate anymore. I will watch for updates on your progress and I wish you nothing but the best! Good luck Jeff!
[Re: JERICOGTX]
#3058786
07/13/22 08:09 AM
07/13/22 08:09 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I try to make the best of all my experiences, if I don't have the bad ones now and then I don't really enjoy the good one. Sounds like you have a bunch of good times in front of you You have to take the not so good experiences in stride. For myself, it makes me learn about the problem, and how to go about fixing it. A couple years ago, I was having an issue with my Jerico trans. and was getting ready to load the car up in the trailer, when the racer next to me came walking over. He said, "It sucks having stuff go wrong, but do you see all these people walking into the gate, and into the stands? They wish they could be doing what you're doing now, instead of being a spectator. You'll get it fixed, and be back out again." Glad it is moving forward again, and I look forward to seeing you in September if Joel gets his car finished.
68 Barracuda Formula S 340
[Re: JERICOGTX]
#3058787
07/13/22 08:14 AM
07/13/22 08:14 AM
Posts: 4,045 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
[quote=Cab_Burge]..................... You'll get it fixed, and be back out again." This was a Jedi mind trick! Either way you are in a good state of mind! Thanks for sharing the ups and downs, it makes the report more real and helps everyone put into perspective all the crap that happens behind the scenes, maybe it inspires us. Best wishes.
[Re: Bad340fish]
#3058831
07/13/22 10:47 AM
07/13/22 10:47 AM
Posts: 10,021 MN
JERICOGTX
MN
I try to make the best of all my experiences, if I don't have the bad ones now and then I don't really enjoy the good one. Sounds like you have a bunch of good times in front of you You have to take the not so good experiences in stride. For myself, it makes me learn about the problem, and how to go about fixing it. A couple years ago, I was having an issue with my Jerico trans. and was getting ready to load the car up in the trailer, when the racer next to me came walking over. He said, "It sucks having stuff go wrong, but do you see all these people walking into the gate, and into the stands? They wish they could be doing what you're doing now, instead of being a spectator. You'll get it fixed, and be back out again." Glad it is moving forward again, and I look forward to seeing you in September if Joel gets his car finished. I think Joel will have been to the track at LEAST a half dozen times by the time Drag Week rolls around. Everything should be sorted out, and proven.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3058836
07/13/22 10:58 AM
07/13/22 10:58 AM
Bad340fish
Tulsa OK
I try to make the best of all my experiences, if I don't have the bad ones now and then I don't really enjoy the good one. Sounds like you have a bunch of good times in front of you You have to take the not so good experiences in stride. For myself, it makes me learn about the problem, and how to go about fixing it. A couple years ago, I was having an issue with my Jerico trans. and was getting ready to load the car up in the trailer, when the racer next to me came walking over. He said, "It sucks having stuff go wrong, but do you see all these people walking into the gate, and into the stands? They wish they could be doing what you're doing now, instead of being a spectator. You'll get it fixed, and be back out again." Glad it is moving forward again, and I look forward to seeing you in September if Joel gets his car finished. I think Joel will have been to the track at LEAST a half dozen times by the time Drag Week rolls around. Everything should be sorted out, and proven. I feel like Joel typed that. lol
[Re: Bad340fish]
#3058871
07/13/22 12:47 PM
07/13/22 12:47 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
Older Indy blocks are notorious for leaking there. The material there is almost tin foil thickness in many spots. FWIW a partial fill might be a good thing to consider. Been down this road many times.
[Re: Al_Alguire]
#3058949
07/13/22 03:52 PM
07/13/22 03:52 PM
Posts: 10,021 MN
JERICOGTX
MN
Older Indy blocks are notorious for leaking there. The material there is almost tin foil thickness in many spots. FWIW a partial fill might be a good thing to consider. Been down this road many times. It's over a 1/4' thick there. Just happens to be where the rod broke. At first it didn't look like much damage there. It is going to get a partial fill, just to help stabilize things more. Block is welded, and turned out nice. It will be back at the machinists, less than 2 hours from me typing this. We pressure tested it, and the leak is gone. It just needs to be machined, and drop in a new sleeve, and I can put it all back together.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3058989
07/13/22 05:15 PM
07/13/22 05:15 PM
birdtracker
[Re: birdtracker]
#3058994
07/13/22 06:01 PM
07/13/22 06:01 PM
Posts: 7,480 Minnesota
Hemi_Joel
Minnesota
on the rock block, best stuff out there. Jeff that's great news! I hope you got your motorvation back. Now I better get busy so I don't lose another bet.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: birdtracker]
#3059098
07/14/22 06:07 AM
07/14/22 06:07 AM
Posts: 10,021 MN
JERICOGTX
MN
Thank you for that. Got it on order.
69 GTX
68 Road Runner
[Re: birdtracker]
#3059132
07/14/22 09:41 AM
07/14/22 09:41 AM
Hemi_Joel
Minnesota
