Fast ratio steering box.
#3051402
06/17/22 09:55 PM
06/17/22 09:55 PM
Posts: 2,505 God's Country Maryland
GODSCOUNTRY340
I was checking the steering box turns on my '69 'Cuda and came up with 3 1/2 turns lock to lock. I suspect this is a fast ratio manual steering box, were these boxes standard on '69 A-bodies or only on certain cars?
Re: Fast ratio steering box.
[Re: GODSCOUNTRY340]
#3051412
06/17/22 10:20 PM
06/17/22 10:20 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
I was checking the steering box turns on my '69 'Cuda and came up with 3 1/2 turns lock to lock. I suspect this is a fast ratio manual steering box, were these boxes standard on '69 A-bodies or only on certain cars? Optional on A-bodies only 1966 to 1969. Possibly 1964 and 1965 too, with the introduction of the V-8 A-bodies
[Re: autoxcuda]
#3051432
06/18/22 02:23 AM
06/18/22 02:23 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Option S75 Steering - Fast Manual $14.45. Kinda nifty most of the time, but makes parallel parking a very muscular session. With a 340 in the engine bay, the tires absolutely must be turning to do any steering at all. If there's a big block in the engine bay, a bus-sized steering wheel might be needed.
[Re: kentj340]
#3051451
06/18/22 08:55 AM
06/18/22 08:55 AM
GODSCOUNTRY340
Thanks, It's a 383 car but it's got an aluminum intake, aluminum water pump housing and headers to help lighten the front end weight.
[Re: kentj340]
#3051452
06/18/22 09:09 AM
06/18/22 09:09 AM
Posts: 6,246 nowhere
Sniper
nowhere
I keep hearing that. Both my cars have manual steering, 65 Cuda, 51 Plymouth. Now the Cuda has standard ratio, the 51 is 18.2:1. Neither is a muscular effort to parallel park. Even with oversized tires on them. Cuda has a 273, the 51 has it's original, and heavier than an LA, flathead. My 16 yo son drives the 51, though I haven't had him try parallel parking, yet. lol. Well, I thought about it and if having to use more than one finger to park is muscular, then yeah they both are that. But by no means do you need to turn green and hulk out.
#3051456
06/18/22 09:48 AM
06/18/22 09:48 AM
Posts: 31,029 Oregon
AndyF
I was checking the steering box turns on my '69 'Cuda and came up with 3 1/2 turns lock to lock. I suspect this is a fast ratio manual steering box, were these boxes standard on '69 A-bodies or only on certain cars? Yes, 3.5 turns would be fast ratio. There are not any external markings that I'm aware of so no way to verify if it is original or not. The fast ratio boxes aren't fun driving at slow speeds but they are nice for canyon carving. We tried one in a road race car and it was too stiff for the driver. I had one in my street car for a bit and it was way too stiff for daily driving. Almost impossible to go around a sharp corner at low speeds. I eventually switched over to a 20:1 ratio box which was easier to drive and then after a few years I switched to PS.
[Re: Sniper]
#3051495
06/18/22 12:48 PM
06/18/22 12:48 PM
Posts: 15,357 Omaha Ne
TJP
Omaha Ne
Well, I thought about it and if having to use more than one finger to park is muscular, then yeah they both are that. But by no means do you need to turn green and hulk out. I believe he is referring to the fast ratio requiring more effort. I had no issues with several small block cars and the fast ratio manual box
[Re: TJP]
#3051627
06/18/22 11:36 PM
06/18/22 11:36 PM
kentj340
Cut and Shoot, TX
This '69 fast manual box has a green paint daub and is stamped with E0919G.
[Re: ro23_j]
#3051759
06/19/22 03:59 PM
06/19/22 03:59 PM
AndyF
It was an definitely an option on 68 A-bodies. One of my best friends in high school "helped" his mom and dad order a 68 Dart GT. He couldn't convince them to order the 340, but he was able to check the boxes for fast ratio steering and H.D. suspension. I was able to buy the car two years later because his mom couldn't drive it because of the hard steering. It was tough to drive at low speeds. Bet your friend's dad was mad about the "help". If mom isn't happy then nobody is happy!
[Re: ro23_j]
#3051914
06/20/22 09:07 AM
06/20/22 09:07 AM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I have the fast ratio on a 69 Dart...
The regular box on a 72 Duster...
Both are small blocks and the fast ratio is much better to drive than the slower box...
Maybe it is the skinny Firestone bias ply tires but it is also much better to park with...
I'd be interested in another fast ratio box for the Duster if someone has one to sell at Carlisle...
...FAFO...
