Page 5 of 8 1 2 3 4 5 6 7 8
Re: 563ci build specs, what will it make? [Re: J_BODY] #3050966
06/16/22 01:24 PM
06/16/22 01:24 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Well should make enough to run an 8 smile That should be plenty to keep you ahead in the "steak dinner" races for awhile.
Re: 563ci build specs, what will it make? [Re: Al_Alguire] #3050967
06/16/22 01:27 PM
06/16/22 01:27 PM
MN
JERICOGTX Offline OP
MN
Well… I’ll keep this short and to the point. Never made any pulls today. Have water in the oil. Not sure where from, and honestly, I don’t even want to look at it right now. Pretty disappointed, and took the wind out of my sail.
69 GTX 68 Road Runner
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3050968
06/16/22 01:31 PM
06/16/22 01:31 PM
Dang, Dude that suck, sorry for your problem.
Aluminum block, water in the oil, maybe a leaky sleeve or two scope
The first aluminum motor I assembled ( Older 1998 casting, KB Hemi) had sleeves installed to high allowing water to leak from the head gasket water passages over to the sleeve and drain around the sleeve into a pushrod hole down into the cam valley work scope
Sleeves should be no higher than.004 max at room temperatures on the older KB blocks, call Indy and ask them what sleeve height they want on theirs scope twocents
Look for the simple stuff first up
You can find and fix this up wrench grin luck
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3050982
06/16/22 01:59 PM
06/16/22 01:59 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Dangit. Sorry to hear that man.
Rich H.
Esse Quam Videri
Re: 563ci build specs, what will it make? [Re: J_BODY] #3050984
06/16/22 02:05 PM
06/16/22 02:05 PM
an8sec70cuda Offline
Alright Jeff, it's after 2 PM now. What'd it make????? smoke
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 563ci build specs, what will it make? [Re: an8sec70cuda] #3050987
06/16/22 02:13 PM
06/16/22 02:13 PM
MN
MN
It made a mess…
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3050990
06/16/22 02:16 PM
06/16/22 02:16 PM
moparx Offline
moparx  Offline
It made a mess…
oh no ! eek
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3050992
06/16/22 02:20 PM
06/16/22 02:20 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Wow...... sucks big time!!
My suggestion will be to not take it too far apart without pressure testing it as is.
Hopefully it’s as simple as a leaking head gasket.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3051011
06/16/22 03:03 PM
06/16/22 03:03 PM
It made a mess…
Damm, I hate to hear that! What happened man?
CHIP
Re: 563ci build specs, what will it make? [Re: an8sec70cuda] #3051012
06/16/22 03:05 PM
06/16/22 03:05 PM
tboomer Offline
tboomer  Offline
Yeah...Sorry something happened...But I know you will get it found and fixed!
Re: 563ci build specs, what will it make? [Re: tboomer] #3051053
06/16/22 05:59 PM
06/16/22 05:59 PM
Sticky South
Rodenteliminator Offline
Sticky South
Hopefully it’s nothing serious or expensive.
Sorry honey I spent the rent
Re: 563ci build specs, what will it make? [Re: Rodenteliminator] #3051056
06/16/22 06:04 PM
06/16/22 06:04 PM
Las Vegas
Las Vegas
As much a I hate to say this I am not all that surprised and older Indy block is leaking especially if it had any repairs in its past. I have seen a few here that have done the same. Hopefully something simple. You may have some options if it is a leaky block however. Hope its not that bad and yes pressure test it before you tear it to far down. Seen a few of the old blocks leak around the bottom of the bore.....
Re: 563ci build specs, what will it make? [Re: Al_Alguire] #3051071
06/16/22 06:36 PM
06/16/22 06:36 PM
gregsdart Offline
gregsdart  Offline
Sorry to hear this Jeff! Bummer.
Re: 563ci build specs, what will it make? [Re: gregsdart] #3051073
06/16/22 06:41 PM
06/16/22 06:41 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Sorry, Jeff. Hopefully, it’s minor.
Re: 563ci build specs, what will it make? [Re: Leigh] #3051095
06/16/22 08:16 PM
06/16/22 08:16 PM
birdtracker Offline
birdtracker  Offline
well Al has seen this because this is what mine did also. So I had my block pressure tested COLD 3 times by 3 different high end machine shops before any machining and a 4th time once my sleeves were installed. Initial fire up was water in the oil. And lots of it. 1st tear down I looked at everything known to man, pulled my hair out. Tried 3 or 4 ceramic sealers but still got water in the oil, 2nd tear down I took the block to Indy and had them test it HOT, They can warm it to 200 degrees. I was told it was bad and leaking every where. So I run E-85 and I took the water out of it.. Jeff if you private message me I will help you as much as I can. Birdtracker
Re: 563ci build specs, what will it make? [Re: birdtracker] #3051100
06/16/22 08:42 PM
06/16/22 08:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Sorry to see. Better on the dyno than in the car. Hope it's a easy fix. Had a friend dyno a motor this week that had oiling issues. If it was cheap and easy anyone could do it. Keep your head up . When it rips down the track you'll forget this.
Doug
Re: 563ci build specs, what will it make? [Re: dvw] #3051131
06/16/22 10:28 PM
06/16/22 10:28 PM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
I’m sickened by this…. this hobby serves up such a beat down sometimes frown
Re: 563ci build specs, what will it make? [Re: J_BODY] #3051160
06/17/22 04:51 AM
06/17/22 04:51 AM
birdtracker Offline
birdtracker  Offline
like DVW said if this stuff was easy everyone would have one. It only takes one very small thing to wreck everything. Birdtracker
Re: 563ci build specs, what will it make? [Re: J_BODY] #3051196
06/17/22 09:17 AM
06/17/22 09:17 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
x2!
Re: 563ci build specs, what will it make? [Re: HardcoreB] #3051209
06/17/22 09:59 AM
06/17/22 09:59 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I can relate; my 451 split #5 for no apparent reason in May. After sonic testing 3 blocks we finally found a decent one. Hopefully starting assy next week.
Keep your head up and try not to let disappointment cloud your end goals. I think we are all excited to see you rip some gears in that car!
