Page 6 of 8 1 2 3 4 5 6 7 8
Re: 563ci build specs, what will it make? [Re: J_BODY] #3051212
06/17/22 10:08 AM
06/17/22 10:08 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Originally Posted by J_BODY
I’m sickened by this…. this hobby serves up such a beat down sometimes frown
When you get in the ring with a serious contender , you know that you're going to be hit.
You can still win the fight.
I've had parallel experiences , though not at this price or power level.
But the bruises to the psyche sure seem to last.
I hope it isn't too severe , or difficult to pin down.
Re: 563ci build specs, what will it make? [Re: tubtar] #3051457
06/18/22 09:48 AM
06/18/22 09:48 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I'm so sorry Jeff, this is brutal. I hope it's a relatively easy repair and you're only out time.
Re: 563ci build specs, what will it make? [Re: Blusmbl] #3051462
06/18/22 10:32 AM
06/18/22 10:32 AM
birdtracker Offline
birdtracker  Offline
I had 5 major experiences like this right in a row. Its tough getting past one when you have that much time and mental work into it. It just shows you one small thing can have a effect on the whole project. Birdtracker
Re: 563ci build specs, what will it make? [Re: birdtracker] #3058725
07/12/22 10:15 PM
07/12/22 10:15 PM
MN
JERICOGTX Offline OP
MN
Update: After running the engine on the dyno for only a couple minutes, we found water in the oil. Pulled the engine off the dyno right away, and once it was back in my garage, I pressure tested the cooling system, and immediately found the leak. The water was coming from in between the block casting, and sleeve. A good friend helped me tear everything down, so I could get the block back to the machinist right away. Once it was back at his shop we discussed what happened, and where to go from there. He called this last Saturday, and said he has the sleeve out and pressure tested the block, and found a crack at the bottom of the bore. Today, I brought the block home, and prepared the block to be welded tomorrow, and then I bring the block back, to have the sleeve reinstalled.
Before anyone goes off, I’m not blaming anyone. Sh!t happens. This was a used, damaged block, that I bought extremely cheap. I have less into this thing than the fully prepared 400 block I had done nearly 20 years ago. It’s just the risk you take. It’s being taken care of. Time to move forward.
69 GTX 68 Road Runner
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3058733
07/12/22 11:09 PM
07/12/22 11:09 PM
I try to make the best of all my experiences, if I don't have the bad ones now and then I don't really enjoy the good one.
Sounds like you have a bunch of good times in front of you grin up
Re: 563ci build specs, what will it make? [Re: Cab_Burge] #3058741
07/12/22 11:51 PM
07/12/22 11:51 PM
gregsdart Offline
gregsdart  Offline
Good luck with it Jeff!
Re: 563ci build specs, what will it make? [Re: Cab_Burge] #3058776
07/13/22 07:06 AM
07/13/22 07:06 AM
MN
MN
You have to take the not so good experiences in stride. For myself, it makes me learn about the problem, and how to go about fixing it. A couple years ago, I was having an issue with my Jerico trans. and was getting ready to load the car up in the trailer, when the racer next to me came walking over. He said, "It sucks having stuff go wrong, but do you see all these people walking into the gate, and into the stands? They wish they could be doing what you're doing now, instead of being a spectator. You'll get it fixed, and be back out again."
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3058781
07/13/22 07:27 AM
07/13/22 07:27 AM
tboomer Offline
tboomer  Offline
And Jeff. That fella was right! You have the knowledge and desire to get it fixed and be back out there! I have not been down the track in my car in ten years and it sits in my garage. I can't even bring myself to go spectate anymore. I will watch for updates on your progress and I wish you nothing but the best! Good luck Jeff! wave
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3058786
07/13/22 08:09 AM
07/13/22 08:09 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Glad it is moving forward again, and I look forward to seeing you in September if Joel gets his car finished.
68 Barracuda Formula S 340
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3058787
07/13/22 08:14 AM
07/13/22 08:14 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
[quote=Cab_Burge]..................... You'll get it fixed, and be back out again."
This was a Jedi mind trick! Either way you are in a good state of mind! Thanks for sharing the ups and downs, it makes the report more real and helps everyone put into perspective all the crap that happens behind the scenes, maybe it inspires us. Best wishes.
Re: 563ci build specs, what will it make? [Re: Bad340fish] #3058831
07/13/22 10:47 AM
07/13/22 10:47 AM
MN
MN
I think Joel will have been to the track at LEAST a half dozen times by the time Drag Week rolls around. Everything should be sorted out, and proven.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3058836
07/13/22 10:58 AM
07/13/22 10:58 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I feel like Joel typed that. lol
Re: 563ci build specs, what will it make? [Re: Bad340fish] #3058871
07/13/22 12:47 PM
07/13/22 12:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Older Indy blocks are notorious for leaking there. The material there is almost tin foil thickness in many spots. FWIW a partial fill might be a good thing to consider. Been down this road many times.
Re: 563ci build specs, what will it make? [Re: Al_Alguire] #3058903
07/13/22 01:53 PM
07/13/22 01:53 PM
birdtracker Offline
birdtracker  Offline
I resemble that remark! Birdtracker
Re: 563ci build specs, what will it make? [Re: Al_Alguire] #3058949
07/13/22 03:52 PM
07/13/22 03:52 PM
MN
MN
It's over a 1/4' thick there. Just happens to be where the rod broke. At first it didn't look like much damage there. It is going to get a partial fill, just to help stabilize things more.
Block is welded, and turned out nice. It will be back at the machinists, less than 2 hours from me typing this. We pressure tested it, and the leak is gone. It just needs to be machined, and drop in a new sleeve, and I can put it all back together.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3058989
07/13/22 05:15 PM
07/13/22 05:15 PM
birdtracker Offline
birdtracker  Offline
here is the best block filler I have found now. Its a synthetic. https://www.competitionproducts.com...ler-25-lbs/productinfo/ROK/#.Ys81soTMLIV
Birdtracker
Re: 563ci build specs, what will it make? [Re: birdtracker] #3058994
07/13/22 06:01 PM
07/13/22 06:01 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
iagree on the rock block, best stuff out there.
Jeff that's great news! beer I hope you got your motorvation back. beer Now I better get busy so I don't lose another bet. wrench
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 563ci build specs, what will it make? [Re: birdtracker] #3059098
07/14/22 06:07 AM
07/14/22 06:07 AM
MN
MN
Birdtracker
Thank you for that. Got it on order.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3059111
07/14/22 07:54 AM
07/14/22 07:54 AM
birdtracker Offline
birdtracker  Offline
When Al and I filled mine, I got 2 clean buckets, a electric drill and a heavy duty paint stir tool , and a clean funnel. Measured everything out , got the first side level both ways then stirred really good. It took a person to hold the funnel while I poured. Went lots better with 2 people. Birdtracker
Re: 563ci build specs, what will it make? [Re: birdtracker] #3059132
07/14/22 09:41 AM
07/14/22 09:41 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Make sure the core plugs are in before you pour! Don't ask me how I know. blush bawling laugh2
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
