Re: 563ci build specs, what will it make?
[Re: Al_Alguire]
#3043336
05/18/22 04:58 PM
05/18/22 04:58 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
Jeff's new secret weapon!
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Al_Alguire]
#3043360
05/18/22 05:56 PM
05/18/22 05:56 PM
Posts: 10,049 MN
JERICOGTX
MN
Heck I'd kill for 3300 ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) Sounds like you have a good combo getting ready to make some noise. Im sure it will keep you ahead for that steak dinner race for awhile Yeah someone has been slacking, but that’s Standard Operating Procedure, for him, and keeps saying he has PLENTY of time. LOL.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3043376
05/18/22 06:47 PM
05/18/22 06:47 PM
Posts: 2,937 A shed in England
Tig
A shed in England
I'd put the cam in earlier unless you're tire limited. I'd guess about 870-880 hp I let my machinist pick out the cam. He wants the cam set 107-108, which is where it’s at now. We run the Indy CM3 cam. .768/.720" 284/300 on a 580 motor. It absolutely ran the best on a 108 centre line (intake). Motor makes over 900 in good air.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: 440Jim]
#3043479
05/19/22 06:13 AM
05/19/22 06:13 AM
Posts: 10,049 MN
JERICOGTX
MN
Jeff, Just stick to your work and run a good number. No need to answer the jive talkers.... I usually have it coming. LOL.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3043486
05/19/22 06:59 AM
05/19/22 06:59 AM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
Jeff, Just stick to your work and run a good number. No need to answer the jive talkers.... I usually have it coming. LOL. No way? lol
68 Barracuda Formula S 340
[Re: Bad340fish]
#3043491
05/19/22 07:14 AM
05/19/22 07:14 AM
Posts: 10,049 MN
JERICOGTX
MN
Jeff, Just stick to your work and run a good number. No need to answer the jive talkers.... I usually have it coming. LOL. No way? lol LOL!!!
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3045047
05/25/22 08:18 AM
05/25/22 08:18 AM
Posts: 10,049 MN
JERICOGTX
MN
Have been making slow progress with the engine. After mocking up a cylinder head to check for pushrod length, I noticed that the pushrods were going to hit the block. INDY casts one block for Wedge, and HEMI's. If the block is designated for a Wedge head, the boss for the HEMI head bolt is machined off. While this is a used block, the previous owner had SR heads, with 1.5 rockers. 440-1 heads with offset intake rockers, and 1.6 rockers changed the pushrod location. I taped everything off, and took my die grinder to the areas that need to be clearanced. Nothing too major, just takes time. A buddy of mine turned down the mandrel for my vacuum pump. Didn't want any more hanging out than was necessary.
Over the last weekend, I was able to get the rear end setup. A friend had a set of 4.30 Pro Gears with a few passes on them. I also think I have my RacePak driveshaft senor issue figured out. The graph has always been messed up after a pass, and never "clean". Doing some reading and it was mentioned that the bracket holding the sensor needs to be nonferrous. My was made of steel. Guessing the sensor was grounding out? That is now fixed, hopefully.
![Name: 563front.jpg
ID: 457121 563front.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/457121/filename/563front.jpg)
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3050654
06/15/22 08:29 AM
06/15/22 08:29 AM
Posts: 10,049 MN
JERICOGTX
MN
Dyno session is scheduled for tomorrow morning. Engine is ready. Not sure my nerves are. LOL. I did get my 1150 Thumper carb from Dom, since the last time I posted on this thread. Looks awesome! I don't really have too many things to test. Will start out with Hooker 5209 headers, and my old 1050 for break in, then switch to Dom's carb, and bigger headers that fit my car. I did make the decision to run Sunoco Supreme 112 gas, instead of the Renegade 110.
69 GTX
68 Road Runner
[Re: gregsdart]
#3050680
06/15/22 10:30 AM
06/15/22 10:30 AM
Posts: 10,049 MN
JERICOGTX
MN
Jeff, i predict 910 hp at 7100 rpm. Dynoing at R&R? Good luck with it! Not R&R. The dyno is in Eden Valley. Craig's Machine & Dyno. He is good friends with my machinist.
69 GTX
68 Road Runner
[Re: tboomer]
#3050719
06/15/22 12:48 PM
06/15/22 12:48 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Best of luck hopefully it does all you want it to do.....Refresh my memory any big changes other than the block from the old set up?
[Re: tboomer]
#3050727
06/15/22 01:02 PM
06/15/22 01:02 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Good luck Jeff! Can't wait for the results! ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) What he said!!!
[Re: Al_Alguire]
#3050756
06/15/22 02:17 PM
06/15/22 02:17 PM
Posts: 10,049 MN
JERICOGTX
MN
Best of luck hopefully it does all you want it to do.....Refresh my memory any big changes other than the block from the old set up? The only thing I used from the old engine, is the distributor, and oil pan. SR heads vs 440-1 345CNC's, 499ci vs, 563ci, Bigger headers, bigger carb, and WAY bigger cam.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3050772
06/15/22 03:50 PM
06/15/22 03:50 PM
Al_Alguire
Las Vegas
Should make plenty more power...Did you ever dyno the old combo?
I wish we could get some parts. Love to share the build stuff but its just sitting collecting dust
[Re: Al_Alguire]
#3050774
06/15/22 04:04 PM
06/15/22 04:04 PM
Posts: 10,049 MN
JERICOGTX
MN
I wish we could get some parts. Love to share the build stuff but its just sitting collecting dust The old engine made 732hp with a flat tappet cam. Not sure what happened to the dyno sheets, as that was 19 years ago.
69 GTX
68 Road Runner
