More stroke? #3049883
06/12/22 11:24 AM
06/12/22 11:24 AM
gregsdart Offline OP
On my current 550 cube 572-13 motor project, i may consider going bigger if it makes sense . Monday i am going to pick up a Callies 4.5 stroke crank with 2.375 rod pins. I can offset grind it to 4.650 to use a 2.200 rod bearing. My pistons on order have a compression height of 1.452 to match my Molnar 7.1 h beams and 4. 315 stroke crank. I would gain about 43 cubes , or 593 cu in.
Pros -
43 cubes , more torque.
30 more HP?
Cons-
Cost, lose the center counter weights i have on the 4.315 stroke crower.
Higher rod angle
Rebalance, find 7.0 rods, or go aluminum rods if they will fit
Re: More stroke? [Re: gregsdart] #3049886
06/12/22 11:32 AM
06/12/22 11:32 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I like it better the way you are. Too much work to go the other way.
2011 Drag Pak Challenger
Re: More stroke? [Re: rickseeman] #3049913
06/12/22 12:46 PM
06/12/22 12:46 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
If you plan ongoing that route I suggest you call the aluminum rod suppliers. You might not like the answer. Our dragster engine will miss this entire year due to parts lead times....If you really want bigger start buying parts now for another engine, block and al. trust me you will have plenty f time to get the money together. I have threeengines going right now and all in various stages of hurry up and wait.
Re: More stroke? [Re: Al_Alguire] #3049926
06/12/22 01:24 PM
06/12/22 01:24 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
They may have caught up but ??? I used to get Alum rods within a week, the set I just got in mid march were ordered the end of Dec. Even then I had to order through someone who orders a lot of rods. So as Al stated check and see.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: More stroke? [Re: gregsdart] #3049949
06/12/22 02:45 PM
06/12/22 02:45 PM
Cab_Burge Online work
Cab_Burge  Online Work
Wil your current heads support the bigger C.I. well at the higher RPM at WOT? work
I'm thinking of having a 4.0 inch stroke crank made for one of my B1 headed race motors in a after market iron block work shruggy Can you say "rev the snot out of it " devil work realcrazyshruggy
Re: More stroke? [Re: Cab_Burge] #3049984
06/12/22 05:01 PM
06/12/22 05:01 PM
I could use this new ( to me) crank in the megablock i have. I would need to find a set of 2.375 rod bearing h beams 6.80 long. 572 cubes, would use the pistons and rings that were 8n the first 550 (megablock) motor. Or i could grind the crank to 4.625 with 2.2 bearings and have a 588.
Re: More stroke? [Re: gregsdart] #3049989
06/12/22 05:42 PM
06/12/22 05:42 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Seems to me the key to going faster is better heads, or weight.
You have -1 heads, correct?
Sell them and buy better heads if you want to go faster, otherwise your peeling a peanut
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: More stroke? [Re: gregsdart] #3049990
06/12/22 05:45 PM
06/12/22 05:45 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Not sure on 4.625 stroke but you get into rod / cam clearance issues with steel rods with a 4.750 stroke with a wedge, with any decent cam, (unless you have a raised cam block). I'm guessing you may have more of an issue with an aluminium rod. Something to be aware of.
Re: More stroke? [Re: B3422W5] #3050022
06/12/22 08:09 PM
06/12/22 08:09 PM
572-13 will be on the aluminum block motor, 385cnc and finish ported to get some more flow. Vern l, member here, made 1065 hp with 572-13 heads. It probably was a 604.
Re: More stroke? [Re: gregsdart] #3050049
06/12/22 10:10 PM
06/12/22 10:10 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Nice upgrade. Predators?
1.41 best 60 foot
6.60 at 103.90 1/8
Re: More stroke? [Re: B3422W5] #3050303
06/13/22 08:14 PM
06/13/22 08:14 PM
The 1065 hp was with 572-13s.
Re: More stroke? [Re: gregsdart] #3050336
06/13/22 10:55 PM
06/13/22 10:55 PM
I went and got the crank today. Used Callies, 2.375 rod pins, 4.5 stroke. If i can find a set of good, strong 6.76 or 6.8 h beams with . 990 small end, 2.375 big end. I had planned to use it in the aluminum block, but it makes more sense to put it in the megablock for now as a spare motor. i can end up at -.027 (below) to +. 013 (above) piston to deck hight with a good crank that has rounded leading edges on the counter weights and double keyways.
The down side is the large 2.375 bearings. But i will have to find another set of 440-1 castings to put the megablock back together.
Re: More stroke? [Re: gregsdart] #3050383
06/14/22 08:00 AM
06/14/22 08:00 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
If your 572-13's have steel valves the extra CID won't hurt one bit! Good luck.
Re: More stroke? [Re: gregsdart] #3051149
06/16/22 11:49 PM
06/16/22 11:49 PM
NY
B1duster Offline
B1duster  Offline
NY
I was recently looking for 6.7 or 6.8 rods with mopar big end and couldn’t find anything
Re: More stroke? [Re: B1duster] #3051155
06/17/22 02:15 AM
06/17/22 02:15 AM
Try Scat scope up twocents
Re: More stroke? [Re: Cab_Burge] #3051197
06/17/22 09:19 AM
06/17/22 09:19 AM
NY
B1duster Offline
B1duster  Offline
NY
You have a link or part # ? I can’t find them
Re: More stroke? [Re: B1duster] #3051242
06/17/22 11:48 AM
06/17/22 11:48 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
The only rods with the mopar big end are going to be in mopar lengths. 6.76, 6.86.
Unless you want custom.
Re: More stroke? [Re: B1duster] #3051277
06/17/22 01:37 PM
06/17/22 01:37 PM
Phone #310-370-5501 scope
Re: More stroke? [Re: Cab_Burge] #3051662
06/19/22 08:56 AM
06/19/22 08:56 AM
Cab, what power level would you trust scat rods to? Lets guess 2250 bob wieght, 8000 rpm cieling.
