More stroke?
#3049883
06/12/22 11:24 AM
06/12/22 11:24 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
On my current 550 cube 572-13 motor project, i may consider going bigger if it makes sense . Monday i am going to pick up a Callies 4.5 stroke crank with 2.375 rod pins. I can offset grind it to 4.650 to use a 2.200 rod bearing. My pistons on order have a compression height of 1.452 to match my Molnar 7.1 h beams and 4. 315 stroke crank. I would gain about 43 cubes , or 593 cu in. Pros - 43 cubes , more torque. 30 more HP? Cons- Cost, lose the center counter weights i have on the 4.315 stroke crower. Higher rod angle Rebalance, find 7.0 rods, or go aluminum rods if they will fit
Re: More stroke?
[Re: rickseeman]
#3049913
06/12/22 12:46 PM
06/12/22 12:46 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
If you plan ongoing that route I suggest you call the aluminum rod suppliers. You might not like the answer. Our dragster engine will miss this entire year due to parts lead times....If you really want bigger start buying parts now for another engine, block and al. trust me you will have plenty f time to get the money together. I have threeengines going right now and all in various stages of hurry up and wait.
Re: More stroke?
[Re: Al_Alguire]
#3049926
06/12/22 01:24 PM
06/12/22 01:24 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
They may have caught up but ??? I used to get Alum rods within a week, the set I just got in mid march were ordered the end of Dec. Even then I had to order through someone who orders a lot of rods. So as Al stated check and see.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: More stroke?
[Re: gregsdart]
#3049949
06/12/22 02:45 PM
06/12/22 02:45 PM
Posts: 43,237 Bend,OR USA
Cab_Burge
Re: More stroke?
[Re: Cab_Burge]
#3049984
06/12/22 05:01 PM
06/12/22 05:01 PM
gregsdart
I could use this new ( to me) crank in the megablock i have. I would need to find a set of 2.375 rod bearing h beams 6.80 long. 572 cubes, would use the pistons and rings that were 8n the first 550 (megablock) motor. Or i could grind the crank to 4.625 with 2.2 bearings and have a 588.
Re: More stroke?
[Re: gregsdart]
#3049989
06/12/22 05:42 PM
06/12/22 05:42 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
I could use this new ( to me) crank in the megablock i have. I would need to find a set of 2.375 rod bearing h beams 6.80 long. 572 cubes, would use the pistons and rings that were 8n the first 550 (megablock) motor. Or i could grind the crank to 4.625 with 2.2 bearings and have a 588. Seems to me the key to going faster is better heads, or weight. You have -1 heads, correct? Sell them and buy better heads if you want to go faster, otherwise your peeling a peanut
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: More stroke?
[Re: gregsdart]
#3049990
06/12/22 05:45 PM
06/12/22 05:45 PM
Posts: 2,926 A shed in England
Tig
A shed in England
Not sure on 4.625 stroke but you get into rod / cam clearance issues with steel rods with a 4.750 stroke with a wedge, with any decent cam, (unless you have a raised cam block). I'm guessing you may have more of an issue with an aluminium rod. Something to be aware of.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: More stroke?
[Re: B3422W5]
#3050022
06/12/22 08:09 PM
06/12/22 08:09 PM
gregsdart
I could use this new ( to me) crank in the megablock i have. I would need to find a set of 2.375 rod bearing h beams 6.80 long. 572 cubes, would use the pistons and rings that were 8n the first 550 (megablock) motor. Or i could grind the crank to 4.625 with 2.2 bearings and have a 588. Seems to me the key to going faster is better heads, or weight. You have -1 heads, correct? Sell them and buy better heads if you want to go faster, otherwise your peeling a peanut 572-13 will be on the aluminum block motor, 385cnc and finish ported to get some more flow. Vern l, member here, made 1065 hp with 572-13 heads. It probably was a 604.
Re: More stroke?
[Re: gregsdart]
#3050049
06/12/22 10:10 PM
06/12/22 10:10 PM
B3422W5
Portage,michigan
I could use this new ( to me) crank in the megablock i have. I would need to find a set of 2.375 rod bearing h beams 6.80 long. 572 cubes, would use the pistons and rings that were 8n the first 550 (megablock) motor. Or i could grind the crank to 4.625 with 2.2 bearings and have a 588. Seems to me the key to going faster is better heads, or weight. You have -1 heads, correct? Sell them and buy better heads if you want to go faster, otherwise your peeling a peanut 572-13 will be on the aluminum block motor, 385cnc and finish ported to get some more flow. Vern l, member here, made 1065 hp with 572-13 heads. It probably was a 604. Nice upgrade. Predators?
Re: More stroke?
[Re: gregsdart]
#3050336
06/13/22 10:55 PM
06/13/22 10:55 PM
gregsdart
I went and got the crank today. Used Callies, 2.375 rod pins, 4.5 stroke. If i can find a set of good, strong 6.76 or 6.8 h beams with . 990 small end, 2.375 big end. I had planned to use it in the aluminum block, but it makes more sense to put it in the megablock for now as a spare motor. i can end up at -.027 (below) to +. 013 (above) piston to deck hight with a good crank that has rounded leading edges on the counter weights and double keyways. The down side is the large 2.375 bearings. But i will have to find another set of 440-1 castings to put the megablock back together.
Re: More stroke?
[Re: B1duster]
#3051242
06/17/22 11:48 AM
06/17/22 11:48 AM
Posts: 1,996 Apollo, PA.
B1MAXX
Apollo, PA.
The only rods with the mopar big end are going to be in mopar lengths. 6.76, 6.86. Unless you want custom.
Re: More stroke?
[Re: Cab_Burge]
#3051662
06/19/22 08:56 AM
06/19/22 08:56 AM
gregsdart
I was recently looking for 6.7 or 6.8 rods with mopar big end and couldn’t find anything Try Scat Cab, what power level would you trust scat rods to? Lets guess 2250 bob wieght, 8000 rpm cieling.
