Vinyl Dye? #3049011
06/08/22 09:27 PM
06/08/22 09:27 PM
Bowling Green KY / Nashville, ...
300by500 Offline OP
300by500  Offline OP
Doing a color change on my 1969 Barracuda fastback, interior will be going from dark green metallic to blue metallic.
I was going to order a complete new interior, but it appears these parts won’t be available for possibly up to two years!
I guess my only option right now is vinyl dye, Anyone have brand preferences or advice?
Re: Vinyl Dye? [Re: 300by500] #3049036
06/08/22 11:51 PM
06/08/22 11:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
SEM.
Re: Vinyl Dye? [Re: topside] #3049051
06/09/22 05:47 AM
06/09/22 05:47 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
X2! Also get the prep/cleaner before applying it.
Re: Vinyl Dye? [Re: Moparite] #3049072
06/09/22 08:45 AM
06/09/22 08:45 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I've used SEM paints quite a bit and they are really nice. I'm not sure if they offer the correct blue though. Herb's Parts has a line of interior paints. I've used their 68 pearl white and it's really nice. They might have the correct shade of blue you need. You can still use SEM paint as a base coat for the Herb's paint if you need to. I sprayed some bucket seat hinge covers with SEM white and then top coated them with the Pearl White.
Make sure you clean clean clean and use SEM Adhesion Promotor on any plastics.
Re: Vinyl Dye? [Re: burdar] #3049080
06/09/22 09:30 AM
06/09/22 09:30 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Local SEM distributor color matches bulk product same as regular paint. They can put it into spray cans or sell it by the pint or quart.
Re: Vinyl Dye? [Re: John Brown] #3049861
06/12/22 10:18 AM
06/12/22 10:18 AM
300by500 Offline OP
300by500  Offline OP
Thanks for the info! Sounds like SEM is the unanimous choice!
Re: Vinyl Dye? [Re: 300by500] #3049868
06/12/22 10:36 AM
06/12/22 10:36 AM
Canada
demon Offline
demon  Offline
Canada
I use SEM products a lot. Also look at the OER interior colors sold by Classic Industries. They have original 68-73 era Mopar interior colors. I have used them a lot too, and had equal results.
Like anything, prep is important. On the plastic pieces use an adhesion promoter. The soft pieces like vinyl seats, armrests and visors re color very well.
Re: Vinyl Dye? [Re: 300by500] #3055272
07/02/22 03:05 PM
07/02/22 03:05 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
I dyed a black dash pad red in my 67 Barracuda almost 40 years ago , and it is still beautiful ! I used all ditzier prep material and I am not sure if the dye was Ditzler or Sem at that time , but I have used SEM on other things in more recent times . If you do proper prep , the dye will work well ! Kool
------------------------ It doesn't matter what you do.........As long as you look good doing it !
