Re: A518 speedo gear
[Re: trw1982]
#3048345
06/06/22 03:58 PM
06/06/22 03:58 PM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
I'm pretty sure the different housing types can be swapped between transmissions. Cable is different though. I found a an a500 in a late 80's Dakota with cruise control. The speedometer gear housing in it used the old style gear and has a VSS built into it. I've used that same housing on three different transmissions since then with the latest being an a518 from 1994.
[Re: 440newport]
#3048406
06/06/22 07:20 PM
06/06/22 07:20 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
I thought that sometime in the late 70's they went to a totally different plastic housing and gear? I know I had a '79 727 that had a completely different setup and cable end. The earlier style gear and housings fit fine though in it's place.
Like this style:
That is a 1965 and older gear. 1966-1993 is the same gear and housing.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#3048599
06/07/22 12:43 PM
06/07/22 12:43 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The later pinion resembles the '62-'65 (bottom pic) but is different.
[Re: John_Kunkel]
#3048611
06/07/22 01:25 PM
06/07/22 01:25 PM
moparmarks
The later pinion resembles the '62-'65 (bottom pic) but is different. My 90's A518, A500 and Getrac 360 as well as my 1987 833OD all take the long shaft. Lower one shown in your pic.
