adj timing control
#3046902
05/31/22 09:21 PM
05/31/22 09:21 PM
RapidRobert
where can I find one, that you turn the knob to adj? I had one way back that connected in series to one of the electronic wires & delayed that "trigger" to alter the advance amount. MSD has an 8680 but it requires their "box". thank you for your time.
Re: adj timing control
[Re: duspan]
#3047307
06/02/22 09:00 AM
06/02/22 09:00 AM
RapidRobert
was it an 8782? I finally got ahold of a tech & he said it is a universal one that will work on a chrysler std dist tho it says HEI & the ebay seller says it requires an external coil. its coming my way.
[Re: rebel]
#3047761
06/03/22 10:30 PM
06/03/22 10:30 PM
RapidRobert
I had one before & they definitely work as described. I'm assuming it delays the triggering from the reluctor/magnet to the coil so you bump the timing up then slow it down with the knob so you have a range to work with. this one has a 15 deg range. My 8782 came in the mail today.
