Re: Anybody running a GenIII with a 727 and a gear vendors?
[Re: scoutsr2]
#3046241
05/29/22 07:26 PM
05/29/22 07:26 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
How about a 46rh or 46re to use instead of the 727 w/gv?
Carl Kessel
[Re: dart4forte]
#3046555
05/30/22 07:31 PM
05/30/22 07:31 PM
Posts: 4,405 Michigan
MarkZ
Worthy
Worthy
Is the OD ratio on a Gear Vendors even worth it? If you don't mind the fabrication work to the tunnel 518 is the way to go. Hell of a lot cheaper too.
[Re: scoutsr2]
#3046577
05/30/22 08:39 PM
05/30/22 08:39 PM
Posts: 3,069 Michigan
A727Tflite
I'm building a 71 Roadrunner with a Gen III Hemi and I am deciding upon transmission. I have looked at the 4L60E conversions and prefer to keep a 727 but want an overdrive. Curious for input from anyone using a gear vendors overdrive setup. If you have pics of your finished install, that would be great. What are you expecting for HP and torque ?
[Re: MarkZ]
#3046657
05/31/22 07:10 AM
05/31/22 07:10 AM
Posts: 21,641 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
Is the OD ratio on a Gear Vendors even worth it? If you don't mind the fabrication work to the tunnel 518 is the way to go. Hell of a lot cheaper too. Agree. The $3300+ cost would be better off with an upgraded factory transmission that already has overdrive built in. There are now lots of options if someone is willing to do the work.
