Anybody running a GenIII with a 727 and a gear vendors? #3046209
05/29/22 05:01 PM
05/29/22 05:01 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
I'm building a 71 Roadrunner with a Gen III Hemi and I am deciding upon transmission. I have looked at the 4L60E conversions and prefer to keep a 727 but want an overdrive. Curious for input from anyone using a gear vendors overdrive setup. If you have pics of your finished install, that would be great.
Re: Anybody running a GenIII with a 727 and a gear vendors? [Re: scoutsr2] #3046241
05/29/22 07:26 PM
05/29/22 07:26 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
How about a 46rh or 46re to use instead of the 727 w/gv?
Carl Kessel
Re: Anybody running a GenIII with a 727 and a gear vendors? [Re: CKessel] #3046243
05/29/22 07:29 PM
05/29/22 07:29 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I have a 46RE
Abe Lincoln
Re: Anybody running a GenIII with a 727 and a gear vendors? [Re: dart4forte] #3046555
05/30/22 07:31 PM
05/30/22 07:31 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Is the OD ratio on a Gear Vendors even worth it? If you don't mind the fabrication work to the tunnel 518 is the way to go. Hell of a lot cheaper too.
Re: Anybody running a GenIII with a 727 and a gear vendors? [Re: scoutsr2] #3046577
05/30/22 08:39 PM
05/30/22 08:39 PM
A727Tflite Offline
A727Tflite  Offline
What are you expecting for HP and torque ?
Re: Anybody running a GenIII with a 727 and a gear vendors? [Re: MarkZ] #3046657
05/31/22 07:10 AM
05/31/22 07:10 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Agree. The $3300+ cost would be better off with an upgraded factory transmission that already has overdrive built in. There are now lots of options if someone is willing to do the work.
Re: Anybody running a GenIII with a 727 and a gear vendors? [Re: A727Tflite] #3046658
05/31/22 07:16 AM
05/31/22 07:16 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I am currently in the middle of a gv od unit on a 69 charger 4 speed car. I slotted the crossmember .100 like they said and it still would not fit. I had to clearance the tunnel slightly AND install smaller bolts (3/8”) instead of the 7/16 that are factory in 69 cars. It’s still very close. We may have to do some more clearancing. I had a friend that dropped his crossmember about 1/2” total plus beat the tunnel in on his 70 chevelle . They say don’t drop it that much but his works fine.
Re: Anybody running a GenIII with a 727 and a gear vendors? [Re: scoutsr2] #3046732
05/31/22 01:10 PM
05/31/22 01:10 PM
New Braunfels, TX
416challenger Offline
New Braunfels, TX
I am running a 5.7 hemi with 727 and gear vendor in an E body. Everything fits great. While the overdrive is not as much as a factory overdrive I still really like it. I cruise at about 2800 rpm at 78 mph on the highway in overdrive. Way better than the 3600 rpm I use to turn. I ended up getting the gear vendor for free, just traded labor.
Re: Anybody running a GenIII with a 727 and a gear vendors? [Re: CKessel] #3046786
05/31/22 04:04 PM
05/31/22 04:04 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
That may be an option. I’m trying to avoid cutting the tunnel too much and not sure what electronics would be needed.
Re: Anybody running a GenIII with a 727 and a gear vendors? [Re: scoutsr2] #3046956
06/01/22 02:25 AM
06/01/22 02:25 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If you have a choice, use a short 727, truck or motorhome. It puts the overall length slightly longer than stock so it doesn't make driveline angles as much of an issue. They advertise a Shorty version but I'm not sure if it uses the above mentioned trans or if it uses a 4x4 case. If it uses a 4x4 case it would be really short and probably would not work with a factory rear mount system.
The GV does have the advantage of being able to split gears so you wind up with a close ratio 6 speed auto, something a 5.7 could take advantage of.
Kevin
