Page 2 of 3 1 2 3
Re: Pretty sure my converter died [Re: Hot 340] #3041861
05/12/22 07:54 PM
05/12/22 07:54 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Ok got it plumbed to the proper port this time. Same result. No line pressure at all in any gear. Fluid moves on the stick tho. shruggy
Re: Pretty sure my converter died [Re: Hot 340] #3041879
05/12/22 09:19 PM
05/12/22 09:19 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
It's been many years ago, but I broke a converter just like what you describe. It was a GER piece, (but we won't get into that) in my race car. Running fine all night, but in the semi's, when I pulled it into high gear, nothing. Rev limiter caught the engine, but I had all neutrals. No forward, no reverse. I got it home that night about 10 pm, pulled the trans out, set the converter aside and splattered the transmission all over the work bench (I was supose to race the next day 100 miles away)., Couldn't find anything wrong with the trans and FINALLY decided to look at the converter. When I looked into the input hole, I could see the splined part was sheared in two. Put the trans back together, stuck my spare converter in and everything worked fine. Except no sleep that night, but I was still young then.
Brian
Re: Pretty sure my converter died [Re: Hot 340] #3041884
05/12/22 09:41 PM
05/12/22 09:41 PM
A727Tflite Offline
A727Tflite  Offline
What port are you using. Some valve bodies don’t send psi to the center line pressure port on the passenger side.
To be sure you don’t have any psi use the rear servo with a 300 gauge. Check in manual low and reverse.
Or simply pull the front cooler line and place in a pan and start it in neutral.
You say fluid moves. Down the stick after starting or ?
Re: Pretty sure my converter died [Re: A727Tflite] #3042069
05/13/22 06:21 PM
05/13/22 06:21 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
I checked the middle port. And the front by accident. No pressure in either. I doubt I can get to the back, got big headers. I think I need to yank it anyway. And yes the fluid moves when it's started and shut off
Re: Pretty sure my converter died [Re: Hot 340] #3046502
05/30/22 04:29 PM
05/30/22 04:29 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Pump gear tangs broke off. What pump gear you guys recommend?
Re: Pretty sure my converter died [Re: Hot 340] #3046505
05/30/22 04:33 PM
05/30/22 04:33 PM
New good pump kit, not the cheap ones tsk
Re: Pretty sure my converter died [Re: Hot 340] #3046507
05/30/22 04:44 PM
05/30/22 04:44 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
http://www.tcsproducts.com/products/product/tf727-max-lug-pump-gear-set/
I went this route after I got a box full of neutrals after my burnout….
They also have a stock style one for way cheaper
Re: Pretty sure my converter died [Re: Cab_Burge] #3046510
05/30/22 04:54 PM
05/30/22 04:54 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
agree Cab, too hard yanking this trans. Nightmare
Re: Pretty sure my converter died [Re: J_BODY] #3046511
05/30/22 04:56 PM
05/30/22 04:56 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
🤣 box of neutrals🤣🤣 thanks Jay, I'll get that gear setup
Re: Pretty sure my converter died [Re: Hot 340] #3046516
05/30/22 05:10 PM
05/30/22 05:10 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
I'm guessing the converter will need flushed....how you guys doing that?
Re: Pretty sure my converter died [Re: Hot 340] #3046528
05/30/22 05:51 PM
05/30/22 05:51 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Have to find someone with a machine. If it has a drain plug u could dump some parts fluid in it then blow out with compressed air. How much damage in the pump?
Re: Pretty sure my converter died [Re: rickraw] #3046533
05/30/22 06:08 PM
05/30/22 06:08 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
not sure how bad it is. I'll gotta get into the pump yet.
Re: Pretty sure my converter died [Re: Hot 340] #3046534
05/30/22 06:10 PM
05/30/22 06:10 PM
A727Tflite Offline
A727Tflite  Offline
If both lugs are in the pump with no missing pieces and no damage to the pump pocket or reaction shaft support then no need to flush.
Re: Pretty sure my converter died [Re: A727Tflite] #3046549
05/30/22 07:16 PM
05/30/22 07:16 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
both pieces are there. But they tore up pretty bad. The babbitt bushing even feels rough. So I think it's gonna need gone through
Re: Pretty sure my converter died [Re: Hot 340] #3046552
05/30/22 07:21 PM
05/30/22 07:21 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
One lugs is so rounded it almost looks like a ball bearing. I don't think it is tho
Re: Pretty sure my converter died [Re: Hot 340] #3046580
05/30/22 08:46 PM
05/30/22 08:46 PM
A727Tflite Offline
A727Tflite  Offline
You need to pull the valve body first and see how things are in there. And remove the return cooler line (at the back of the main case) and blow the fluid in to a clear plastic bottle and see how much if any debris comes out.
Check the TC regulator valve in the valve body too for debris or stickyness.
Re: Pretty sure my converter died [Re: A727Tflite] #3046587
05/30/22 09:04 PM
05/30/22 09:04 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
I'll check that...you think the clutches need to come out?
Re: Pretty sure my converter died [Re: Hot 340] #3046601
05/30/22 09:50 PM
05/30/22 09:50 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I'm going to write that one down... haha
Kevin
Re: Pretty sure my converter died [Re: Hot 340] #3046630
05/30/22 11:22 PM
05/30/22 11:22 PM
A727Tflite Offline
A727Tflite  Offline
Once the pump failed you lost line pressure. The clutchs should be fine, it’s not like they we’re slipping because of “low” line pressure.
You had none. But since you have it down I would look at the geartrain, look the thrust washers over real good since you may have pumped very small debris through the system.
Re: Pretty sure my converter died [Re: A727Tflite] #3046633
05/30/22 11:38 PM
05/30/22 11:38 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I freshened the pump and let er eat! Measure the new gear, they’re not all created equal.
Page 2 of 3 1 2 3
