Re: How close is too close.
[Re: rebel]
#3046061
05/29/22 07:54 AM
05/29/22 07:54 AM
Posts: 2,516 PA
moparacer
PA
I ran an engine like that one time and didn't cause an issue until piston rock came into play. I think mine was closer than that though because it lightly scuffed the valve relief area exactly like yours is showing, but never hurt anything. Ran it for a couple years till we pulled it down I found it.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: rebel]
#3046106
05/29/22 11:02 AM
05/29/22 11:02 AM
Posts: 16,928 NC
440Jim
NC
... the edge of ghe fave face only misses the valve pocket side wall by 0.045. Would you consider that too close? Maybe I should advance the cam half a degree? Whats your call? I would just chamfer (bevel) the top edge of the valve relief to give insurance against piston rocking.
[Re: 440Jim]
#3046162
05/29/22 01:44 PM
05/29/22 01:44 PM
Posts: 9,525 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
This would be my fix also. I would just chamfer (bevel) the top edge of the valve relief to give insurance against piston rocking. ... the edge of ghe fave face only misses the valve pocket side wall by 0.045. Would you consider that too close? Maybe I should advance the cam half a degree? Whats your call? I would just chamfer (bevel) the top edge of the valve relief to give insurance against piston rocking.
STOP POTATO HATE!
[Re: Stanton]
#3046302
05/29/22 11:13 PM
05/29/22 11:13 PM
Posts: 4,647 aotearoa
rebel
aotearoa
What's your quench ?? Thicker head gasket would work. Quench is 0.039, right on the money i'm thinking. I dont think piston rock would take up the 0.045 side clearance I have. I think the fact that the block is Aluminium, the gap should increase as the heat expands everything. maybe?
[Re: rebel]
#3046320
05/30/22 12:07 AM
05/30/22 12:07 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
Wouldn't you need to retard the cam to gain intake valve clearance?
Knowing nothing else I wouldn't be concerned but also inclined to use lighter weight/smaller diameter parts and higher spring pressures. My opinion may change with heavy parts, marginal pressures and aggressive ramps.
[Re: INTMD8]
#3046341
05/30/22 01:59 AM
05/30/22 01:59 AM
Posts: 711 California
BigDaddy440
California
I'd be fearful of running an engine with .045" clearance, especially if it were the exhaust valve which gets hotter an expands more. I've gone by the basic rule of .080" on the intake and .100" on the exhaust, but on occasion have run them slightly tighter than that. When it comes to advancing or retarding the camshaft, it depends on which valve you're having insufficient clearance on. In most problematic cases the the piston is chasing the opened intake valve and hits it before it can fully shut or hits it as the valve "bounces shut". To help reduce the risk of this situation you can retard the camshaft some and it will provide additional intake valve clearance as well as reduce your dynamic compression slightly. If your exhaust valve is the concern, retarding will only make that situation worse, and you'd want to advance the camshaft a few degrees to pick up some extra clearance on the exhaust valve. So you really need to know how much clearance you have on both valves before knowing if you have the room to advance or retard the cam -it's not always an option as it's a bit of a balancing act.
Different head gaskets vs optimal quench have been discussed here already.
You can also choose a camshaft that has a different intake closing or exhaust opening point to help improve your situation.
-Dan
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: 440Jim]
#3046664
05/31/22 07:54 AM
05/31/22 07:54 AM
Posts: 4,074 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
... the edge of ghe fave face only misses the valve pocket side wall by 0.045. Would you consider that too close? Maybe I should advance the cam half a degree? Whats your call? I would just chamfer (bevel) the top edge of the valve relief to give insurance against piston rocking. X2!
