How close is too close. #3046048
05/29/22 04:50 AM
05/29/22 04:50 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
Im doing a rdbuild on a motor & was doing the plastercine sqwish test to confirm clearences, everything is fine except that intake valve is real close. The valve dips into the relief by 0.060, but the edge of ghe fave face only misses the valve pocket side wall by 0.045. Wohld you consider that too close? Maybe I should advance the cam half a degree? Whats your call?
Re: How close is too close. [Re: rebel] #3046061
05/29/22 07:54 AM
05/29/22 07:54 AM
PA
moparacer Offline
moparacer  Offline
PA
I ran an engine like that one time and didn't cause an issue until piston rock came into play. I think mine was closer than that though because it lightly scuffed the valve relief area exactly like yours is showing, but never hurt anything. Ran it for a couple years till we pulled it down I found it.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: How close is too close. [Re: moparacer] #3046096
05/29/22 10:04 AM
05/29/22 10:04 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
You could use some off set head dowels and increase the clearance.
Re: How close is too close. [Re: DavidDean] #3046099
05/29/22 10:27 AM
05/29/22 10:27 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I just had to cut mine. The general rule was .050" clearance.
Doug
Re: How close is too close. [Re: rebel] #3046106
05/29/22 11:02 AM
05/29/22 11:02 AM
NC
440Jim Offline
440Jim  Offline
NC
Originally Posted by rebel
... the edge of ghe fave face only misses the valve pocket side wall by 0.045. Would you consider that too close? Maybe I should advance the cam half a degree? Whats your call?
I would just chamfer (bevel) the top edge of the valve relief to give insurance against piston rocking.
Re: How close is too close. [Re: rebel] #3046155
05/29/22 01:28 PM
05/29/22 01:28 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I ruined a very nice block running .045 valve clearance. Probably the stupidest thing I have ever done.
It survived seven dyno pulls and a few runs down the track until it dropped an intake valve.
I would recommend much more.
Re: How close is too close. [Re: 440Jim] #3046162
05/29/22 01:44 PM
05/29/22 01:44 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
This would be my fix also.
STOP POTATO HATE!
Re: How close is too close. [Re: Mr PotatoHead] #3046231
05/29/22 06:46 PM
05/29/22 06:46 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What's your quench ?? Thicker head gasket would work.
Re: How close is too close. [Re: Stanton] #3046302
05/29/22 11:13 PM
05/29/22 11:13 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
Quench is 0.039, right on the money i'm thinking. I dont think piston rock would take up the 0.045 side clearance I have. I think the fact that the block is Aluminium, the gap should increase as the heat expands everything. maybe?
Re: How close is too close. [Re: rebel] #3046320
05/30/22 12:07 AM
05/30/22 12:07 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Wouldn't you need to retard the cam to gain intake valve clearance?
Knowing nothing else I wouldn't be concerned but also inclined to use lighter weight/smaller diameter parts and higher spring pressures. My opinion may change with heavy parts, marginal pressures and aggressive ramps.
Re: How close is too close. [Re: rebel] #3046332
05/30/22 01:11 AM
05/30/22 01:11 AM
Mock it up again with the clay and use a screw driver or some other narrow tool to push the piston top back and forth to rock it through the spark plug hole and see how much clearances you have after that wrench scope
Re: How close is too close. [Re: INTMD8] #3046341
05/30/22 01:59 AM
05/30/22 01:59 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
I'd be fearful of running an engine with .045" clearance, especially if it were the exhaust valve which gets hotter an expands more. I've gone by the basic rule of .080" on the intake and .100" on the exhaust, but on occasion have run them slightly tighter than that. When it comes to advancing or retarding the camshaft, it depends on which valve you're having insufficient clearance on. In most problematic cases the the piston is chasing the opened intake valve and hits it before it can fully shut or hits it as the valve "bounces shut". To help reduce the risk of this situation you can retard the camshaft some and it will provide additional intake valve clearance as well as reduce your dynamic compression slightly. If your exhaust valve is the concern, retarding will only make that situation worse, and you'd want to advance the camshaft a few degrees to pick up some extra clearance on the exhaust valve. So you really need to know how much clearance you have on both valves before knowing if you have the room to advance or retard the cam -it's not always an option as it's a bit of a balancing act.
Different head gaskets vs optimal quench have been discussed here already.
You can also choose a camshaft that has a different intake closing or exhaust opening point to help improve your situation.
-Dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: How close is too close. [Re: BigDaddy440] #3046351
05/30/22 06:56 AM
05/30/22 06:56 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
The 0.045 clearance is side clearance, not end on & it is the intake so it's closest when opening, so the piston is rapidly going away from the opening valve. I retarded the cam centerline 0.5* & retested it with new plasticine. The side clearance may have gained 0.010 but the depression barely went 0.030 deep. I think I can live with that, it just means the cam centerline is limited to 103*. with these pistons as they are. I had run this cam at 105* before & found clearance more than adequate, 102.5* is just a bit close for Peace of Mind
Re: How close is too close. [Re: rebel] #3046355
05/30/22 08:08 AM
05/30/22 08:08 AM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
Radial clearance should only be addressed by material removal. I would radius the top edge of the pocket. Its probably worth a few cfm also.
Re: How close is too close. [Re: rebel] #3046472
05/30/22 02:40 PM
05/30/22 02:40 PM
.045 radial clearances should be fine up twocents
Re: How close is too close. [Re: 440Jim] #3046664
05/31/22 07:54 AM
05/31/22 07:54 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
X2!
