Race Car Enclosed Trailer Wheels/Tires……from 15” to 16”
#3045905
05/28/22 02:15 PM
05/28/22 02:15 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
I was finally able to find a trailer to do the job that’s in great shape and didn’t cost a fortune. I always buy new tires regardless what the owner tells me when buying a used trailer. This trailer currently has 15” wheels. Since I’m about to buy new trailer-worthy tires I’m interested to know if I can just buy some 16” wheels/tires for it versus continuing to use 15” stuff. Anyone done this before? If so I’d like to hear about it, and which wheel/tires sizes you selected to use. Thanks!
Wes
"Any fool can know. The point is to understand"
- A. Einstein
Re: Race Car Enclosed Trailer Wheels/Tires……from 15” to 16”
[Re: EvilB1Dart]
#3045908
05/28/22 02:26 PM
05/28/22 02:26 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
I converted my old classic dominator from 15-in to 16-in. After blowing 22 Goodyear Marathon radials, I had had enough. I just bought some six lug, 16 in rims and then some good 16 in load range e tires. Everything worked out fine until I put a 5,500 lb car in the trailer. It caused enough deflection that the top of the tires cambered in and rubbed on the wheel wells. So I took a hammer and finessed the wheel wells where the rub marks were. Keeping that in mind, I would get the narrowest 16 in tires you can. Something like a 215/85R16. By the way there's nothing wrong with putting a truck tire on the trailer.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3045912
05/28/22 02:39 PM
05/28/22 02:39 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
I converted my old classic dominator from 15-in to 16-in. After blowing 22 Goodyear Marathon radials, I had had enough. I just bought some six lug, 16 in rims and then some good 16 in load range e tires. Everything worked out fine until I put a 5,500 lb car in the trailer. It caused enough deflection that the top of the tires cambered in and rubbed on the wheel wells. So I took a hammer and finessed the wheel wells where the rub marks were. Keeping that in mind, I would get the narrowest 16 in tires you can. Something like a 215/85R16. By the way there's nothing wrong with putting a truck tire on the trailer. All great info, Joel! Will pay attention to backspacing and wheel width. Hopefully I can find the same backspacing and width for the 16” wheels that the 15” wheels have, and go from there. Moving forward. Thank you.
- A. Einstein
[Re: EvilB1Dart]
#3045926
05/28/22 03:28 PM
05/28/22 03:28 PM
Posts: 19,405 north of coder
moparx
as has been noted, truck tires work good, but be forewarned. some states DOT's frown heavily on doing this. lots of unknown DOT rules from state to state, so make sure you bone up on them before you travel. that can save you from having a very bad day !
[Re: Hemi_Joel]
#3045928
05/28/22 03:38 PM
05/28/22 03:38 PM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
235/85/16 on our trailer. Stepping up to the “G” rated Greenball Towmasters the best tire I’ve ever had here in tire he77! I’m actually on my 4th season on these, but I have cheated and stored them inside from May until Sept. prior to these I’d never gotten through the 3rd season on any E rated tire we ran. I’d guess we have probably 15k miles on them with two SoDak trips, and numerous Phoenix and Famoso treks. Ours is a leaf spring trailer and I think they put a longer hanger on the frame to accommodate. 6 lug 5k axle.
Wes…. Maybe you could get one of many RV places down there to accept a cash deposit to borrow a tire wheel assy and mock things up. I’d bring one of mine down that way but they’re pretty big.
[Re: moparx]
#3046014
05/28/22 09:57 PM
05/28/22 09:57 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
as has been noted, truck tires work good, but be forewarned. some states DOT's frown heavily on doing this. lots of unknown DOT rules from state to state, so make sure you bone up on them before you travel. that can save you from having a very bad day ! Thanks man, I appreciate the info!
- A. Einstein
[Re: J_BODY]
#3046016
05/28/22 10:02 PM
05/28/22 10:02 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
Wes…. Maybe you could get one of many RV places down there to accept a cash deposit to borrow a tire wheel assy and mock things up. I’d bring one of mine down that way but they’re pretty big. Thanks Jay. I'll check into it. I think if I stay close to current 15" width/backspacing I should be okay, but I'll definitely measure everything up before buying. Not too worried about the 1" upgrade, but will have to choose the right tire size, and right tires for doing the job.
- A. Einstein
[Re: EvilB1Dart]
#3046364
05/30/22 08:58 AM
05/30/22 08:58 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
If you want a GOOD trailer tire, track down a set of Goodyear ENDURANCE tires. The ONLY USA made 15" trailer tire out there. I run them on all of my trailers, 205/75-15, 225/75-15 and 235/80-16, and have never blown one out. Every chinese tire I've run has eventually failed by either blowing out or separating at the edge where the sidewall meets the tread. There are quite hard to find, but Amazon found me 4 last month for my car trailer. I was running Goodyer Longtrail truck tires (225/75-15) until I aged them out at 10+ years and some growing sidewall cracks. I threw some chinese ones on since they were all I could get on short notice, but I had to replace them after a year for sidewall separations.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: 67Charger]
#3046392
05/30/22 10:50 AM
05/30/22 10:50 AM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
If you want a GOOD trailer tire, track down a set of Goodyear ENDURANCE tires. The ONLY USA made 15" trailer tire out there. I run them on all of my trailers, 205/75-15, 225/75-15 and 235/80-16, and have never blown one out. Every chinese tire I've run has eventually failed by either blowing out or separating at the edge where the sidewall meets the tread. There are quite hard to find, but Amazon found me 4 last month for my car trailer. I was running Goodyer Longtrail truck tires (225/75-15) until I aged them out at 10+ years and some growing sidewall cracks. I threw some chinese ones on since they were all I could get on short notice, but I had to replace them after a year for sidewall separations. Thank you! Also good to know IF I stay with 15” tires/wheels. My current wheels are 15x5, 5-lug, and 205/75-15 garbage tires on their last trip. I still want to upgrade to 16” but will look into the Goodyear Endurance tires either way. I always ran Carlisle tires on my trailers (open and enclosed).
- A. Einstein
[Re: justinp61]
#3046393
05/30/22 10:53 AM
05/30/22 10:53 AM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
I too run Goodyear Endurance tires on my trailer and keep them covers at all times unless I'm pulling it.
The only reasons I'd with a 16 over a 15 would be if the load rating was greater (and I needed it), or the tires were tall enough to reduce bearing speed. My trailer has 15's on it and the Goodyears on it now are somewhat shorter than the previous bias tires that were on it, but I've never had any issues with heat in the tires or hubs. Thank you. I really don’t need to, but I assumed the 16” tire choices would be better, maybe same or cheaper price, and plentiful. I’m going to check out the Goodyear Endurance tires.
- A. Einstein
[Re: EvilB1Dart]
#3046425
05/30/22 12:23 PM
05/30/22 12:23 PM
birdtracker
I thought China bought Carlisle due to poor ratings in the last 5 years but maybe they are still made here in the states. Birdtracker
[Re: birdtracker]
#3046431
05/30/22 12:31 PM
05/30/22 12:31 PM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
Dealt with my last tire failure. Going to a LT truck tire. Really don’t care what the states think.
Abe Lincoln
[Re: dart4forte]
#3046445
05/30/22 01:36 PM
05/30/22 01:36 PM
J_BODY
aZLiViN
Dealt with my last tire failure. Going to a LT truck tire. Really don’t care what the states think. As long as the rating is equal or better than OE knock yourself out! My limited research prior to going to a G rated tire (max load single 4400lb @ 110psi) was that people were seeing about the same rate of tire failure with the LT as the ST. My G rated tires have L rating up to 75mph speed. Wes I see they have a 15” 12 ply….. https://www.greenballtires.com/brands/greenball/tow-master-asc
[Re: J_BODY]
#3046693
05/31/22 10:09 AM
05/31/22 10:09 AM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
Dealt with my last tire failure. Going to a LT truck tire. Really don’t care what the states think. As long as the rating is equal or better than OE knock yourself out! My limited research prior to going to a G rated tire (max load single 4400lb @ 110psi) was that people were seeing about the same rate of tire failure with the LT as the ST. My G rated tires have L rating up to 75mph speed. Wes I see they have a 15” 12 ply….. https://www.greenballtires.com/brands/greenball/tow-master-asc Thanks, Jay! Sweet!
- A. Einstein
[Re: EvilB1Dart]
#3046716
05/31/22 12:22 PM
05/31/22 12:22 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
I have Goodyear Endurance tires on all three of my trailers. One set has been on since 2016 and still looking good and thats say a LOT in the desert. They just went on a 2500 mile round trip to Texas and back with no issues. They are 15" tires as well.
[Re: Al_Alguire]
#3046897
05/31/22 08:55 PM
05/31/22 08:55 PM
Posts: 9,835 MI, usa
dvw
MI, usa
Everything I've ever read points to 16". I upgraded to load E Carlisle (still 15") a few years ago. Zero issues since. The load D's failed a few. I keep the tires covered. Tri axle 32' carrying close to 10,000lbs loaded. Doug
[Re: Al_Alguire]
#3047060
06/01/22 01:02 PM
06/01/22 01:02 PM
Posts: 3,510 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I have Goodyear Endurance tires on all three of my trailers. One set has been on since 2016 and still looking good and thats say a LOT in the desert. They just went on a 2500 mile round trip to Texas and back with no issues. They are 15" tires as well. I too have the Goodyear Endurance tires on my 24ft enclosed trailer. I got them on the recommendation of another racer and I liked I could get tham at Discount Tire and have warranty service in many parts of the country. I have not used them enough to make a solid recommendation. However I did notice they are noticeably heavier than my past trailer tires.
