Page 2 of 3 1 2 3
Re: how long will a battery last? [Re: an8sec70cuda] #3043582
05/19/22 12:49 PM
05/19/22 12:49 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
My Optima yellow-top is at least 10 years old and still going. Still starts after sitting for months with no tender.
China is the enemy.
Re: how long will a battery last? [Re: Sniper] #3043724
05/19/22 07:57 PM
05/19/22 07:57 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Originally Posted by Sniper
Originally Posted by a12rag
Ok . . . so maybe I am the outlier here . . . I have the FACTORY batteries in my 2002 Cummins ! Both still show the 'green" eye, and test good ! . . . I have always made sure to check the fluid level and top up with distilled water. Also, have had battery maintainer on then when I am not driving the truck. I generally only use the truck in the spring/summer/fall, and even then it is for towing the travel trailer or the car trailer . . . it sits with the battery maintainer on there - I do check to make sure all is good, and have changed battery maintainers over the years. I also have the factory battery in my 2004 Crossfire & 2006 Magnum. Yup, when not in use, I put battery maintainer on them.
So, 20 years from original batteries . . . never heard of, but I can prove it can be done !
Like anything, it is how it gets utilized, maintained . . . figure if I can pop caps off to check fluid level, then I check it !
Best of luck to all !
Cheers
Batteries have date codes stamped on them, sometimes it's a sticker.
https://batteryglobe.com/how-to-read-car-battery-date-codes/
Post pictures.
Here are pics of the truck batteries . . . 2002 Cummins, 135k km (81k miles) on truck.
Re: how long will a battery last? [Re: a12rag] #3043725
05/19/22 07:58 PM
05/19/22 07:58 PM
a12rag Offline
a12rag  Offline
Here is OE battery from 2006 Magnum, 231k km (144k miles) . . .
Re: how long will a battery last? [Re: a12rag] #3043739
05/19/22 08:53 PM
05/19/22 08:53 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Cheers
Post pictures.
Apparently I needed to spell out POST PICTURES OF THE DATE CODES
Re: how long will a battery last? [Re: Sinitro] #3043747
05/19/22 09:17 PM
05/19/22 09:17 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Originally Posted by Sinitro
Battery Tenders do have issues...
I had 1 that shorted out and melted the case...
I took a picture and sent a message back to their corporate headquarters, but they didn't want the unit returned but they did sent me a replacement.
But a week later, their head of engineering called me and requested I see back the defective unit for their inspection and failure analysis...
Too late it was already tossed into the dumpster.
Note that 1 drawback of a battery tender that it does not address sulphate buildup which adds resistance and can destroy a unit.
So I started using a battery minder product, that sends a high voltage spike every 5 seconds to burn off the sulphate buildup.
5 years later using the battery minder, to date no problems and unit remains cool....
Just my $0.02... wink
I read somewhere that to charge a battery right it needs at least 16 volts at first then taper back to eat the sulphate.
My great grandfather made up his own set of batteries to run the lights on the farm (30s) had a lot of them in a shed that he maintained with acid and lead plates. He charged them with steam generator during the day. Only farm in Rock Hill that had lights. Mom said he was a smart guy.
Re: how long will a battery last? [Re: Sniper] #3043851
05/20/22 10:35 AM
05/20/22 10:35 AM
a12rag Offline
a12rag  Offline
Cheers
Post pictures.
Uh . . . that is all that is on the factory batteries - labels on the top. . . . if you think I am making it all up, whatever. I know my machines and what I do to look after them. I was only posting this out of information for all to see what could be done. Why would I post something that is not true ?? Not here to spread disinformation. Merely stating my experience, sorry that you doubt my words . . .
Cheers
Re: how long will a battery last? [Re: a12rag] #3044266
05/22/22 11:28 AM
05/22/22 11:28 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
My 05 300C is still sporting the original battery. Not my usual experience tho, more like 6-8 years.
My big trucks run 4 Type 31, usually 1000 CCA. Anything much over 3 years is a gift because at least one of them will give up the ghost. Rinse repeat .
Kevin
Re: how long will a battery last? [Re: a12rag] #3044281
05/22/22 12:02 PM
05/22/22 12:02 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Cheers
If you want everyone to believe you have the original 20 year old batteries in your truck and aren't mistaken about having replaced it you are going to have to post a shot of the date code. I posted a link on where to find those date codes.
Re: how long will a battery last? [Re: Sniper] #3044299
05/22/22 12:46 PM
05/22/22 12:46 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Years ago, for my 49 Plymouth convert I bought a new 6 volt original style battery from Newcastle. The first one lasted less than a year, and they exchanged it under warranty. The next one failed fairly promptly as well and again they warranted it. The third one was still going strong after 12 years. When I took it out of the car to get another car that was lacking a battery started, it slipped out of my hands and cracked open on the floor. Who knows how long that battery may have lasted? It's too bad I wrecked it. It's puzzling how it's siblings died so young, but it was able to attain geezer status. confused
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: how long will a battery last? [Re: cudaman1969] #3044326
05/22/22 02:26 PM
05/22/22 02:26 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The battery minder sends a 4KV(low current) spike every 10 seconds...
This supposedly burns off any sulphate buildup...
Re: how long will a battery last? [Re: rhad] #3044744
05/23/22 11:37 PM
05/23/22 11:37 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
The worst battery I have ever had is an optima red top. Purchased 8/25/20 and I just replaced it for the third time. Most batteries give me 7-8 years in daily drivers, thought the optima would be better, parts store said they are not what they used to be, lots of issues. Interstate batteries were always junk for me also.
Re: how long will a battery last? [Re: 4406bbl] #3044802
05/24/22 10:53 AM
05/24/22 10:53 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have had excellent luck with both Optima and Interstate batteries.
Re: how long will a battery last? [Re: 4406bbl] #3044804
05/24/22 10:58 AM
05/24/22 10:58 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Something with your situation is strange, or your supplier has old product. That is not a normal problem.
68 Barracuda Formula S 340
Re: how long will a battery last? [Re: a12rag] #3044805
05/24/22 11:00 AM
05/24/22 11:00 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Cheers
Post pictures.
Those batteries would probably test bad if you load tested them. But you have a cummins, and they start super easy so you get by. Your situation would never happen with a ford diesel lol.
Re: how long will a battery last? [Re: Bad340fish] #3044832
05/24/22 01:40 PM
05/24/22 01:40 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I hope you are right, and this new one lasts. The Optimas were not old, they were within 2 months of sale date. Both died right after winter in 2 separate caravans, almost exactly the same month. One day it starts fine, the next flat dead, would not charge. Both vans were fine with traditional batteries, getting 7-8 years out of them. When they tested them they said they were junk and would not accept a charge.
Re: how long will a battery last? [Re: a12rag] #3044836
05/24/22 01:54 PM
05/24/22 01:54 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Cheers
Post pictures.
Have a 2000 Cummins, changed the original batteries in 2020, both group 27 mopar originals, green eye still green, bought the truck new. I changed them because 1 barely passed a load test, figured I did not want to wait and fry the alternator or wiring. 85,000 miles never driven in winter, heated garage kept, so it sat 6 months out of the year, always started right up.
Re: how long will a battery last? [Re: 4406bbl] #3044883
05/24/22 05:03 PM
05/24/22 05:03 PM
a12rag Offline
a12rag  Offline
Cheers
Post pictures.
Sounds like our trucks are similar - mine sits through the winter also. I have LOAD TESTED both batteries, separately of course, all still ok . . .
Re: how long will a battery last? [Re: rhad] #3044884
05/24/22 05:25 PM
05/24/22 05:25 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
my CarQuest guy handles Harris Batteries. I've gotten 11+ years out of them.
1981 Dodge D150 360 auto
Re: how long will a battery last? [Re: basketcase] #3044892
05/24/22 05:54 PM
05/24/22 05:54 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I had never heard of Harris
https://www.harrisbattery.com/product-category/commercial-automotive/
interesting
review and overview
https://www.solarreviews.com/blog/harris-battery-review
Re: how long will a battery last? [Re: 360view] #3044934
05/24/22 08:26 PM
05/24/22 08:26 PM
BDW Offline
BDW  Offline
Since when is 33% (13.5 vs 10.2) more considered "slightly"........................
Harris ReLi24-10.2 Generac PWRcell LG RESU10H Prime Tesla Powerwall
Cost* $7,000-$8,500. $10,000 $7,000-$8,000 $8,500
Capacity 10.2 kWh. 9 kWh. 9.6 kWh 13.5 kwh
*Cost before installation
Cost
The Harris battery with 10.2 kWh capacity costs between $7,000 and $8,500 before installation.
This price is better than the Generac PWRcell with 9 kWh capacity at $10,000. The Harris battery is roughly within the same price range as the LG RESU10H Prime with 9.6 kWh capacity, which costs between $7,000 and $8,000. The Tesla Powerwall with 13.5 kWh capacity costs $8,500, but comes with slightly higher capacity than the others.
Page 2 of 3 1 2 3
