Page 4 of 4 1 2 3 4
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: cudaman1969] #3044733
05/23/22 10:35 PM
05/23/22 10:35 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
proto top with 2x4 made of wood then a cast aluminum proto by Don Dulmage.
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: R/T1968R/T] #3044745
05/23/22 11:44 PM
05/23/22 11:44 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I’d say 90% sure that lid was not cast from that plyboard lid, holes are in the lid with 1/2” spacers used to get linkage up off the lid.
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: cudaman1969] #3044826
05/24/22 01:19 PM
05/24/22 01:19 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
The first attempt was the plywood. Then a mold was made for cast aluminum. two different animals
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: R/T1968R/T] #3044891
05/24/22 05:50 PM
05/24/22 05:50 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Yes, I read the article too.
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: R/T1968R/T] #3074387
09/05/22 07:43 AM
09/05/22 07:43 AM
Louisiana
BiomedTechGuy Offline
Louisiana
I actually have what I consider one of the finest examples of the Weiand P3690982 6bbl intakes available. It is completely stock other than the intake runners have already been nicely radiused to remove the sharp 90° corners where they meet the floor of the plenum.
I would do the mods 6BBL FLASH did that are pictured and explained in the Victory Library post by him.
The problems with me using that on my BMP 572 as I see them are:
I'm trying to keep my N96 hood, and it definitely won't fit.
I'd have to get someone like Wilson Manifolds to mod the runners to match the Max Wedge port size of the TF270s.
From what Rossi said, that intake is over at 6,500 RPMs, not that that would be the biggest problem.
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: autoxcuda] #3074388
09/05/22 07:48 AM
09/05/22 07:48 AM
Louisiana
Louisiana
You would need the Weiand manifold to make more power and a set of mechanical carbs. It doesnt run great on the street unless you do the DC mods.
Tests done for DC and mods
I have the Chrysler Performance book that details the specs and mods for both the Weiand and the Edelbrock 6bbl aftermarket intakes.
I've never seen the jet recommendations drawing or some of the details in the docs you posted. Thanks.
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: JohnRR] #3074390
09/05/22 07:56 AM
09/05/22 07:56 AM
Louisiana
Louisiana
I won't know how it fits until it's in my 70 V-code Roadrunner.
I'm going with the Indy ModMan intake, CNC'd to MW port size by Indy, and my Promax modded Holley carbs, which I will rejet (I have 2 kits with 2 jets each size per kit from the #60s into the #90s). The rejet will be a best guess so the builder can run it before I pick it up or have it shipped to me. Once I have it installed, I have an Innovate Motorsports dual wideband O2 sensor system that I can fine tune with.
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: BiomedTechGuy] #3074758
09/06/22 12:35 PM
09/06/22 12:35 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
This 6bbl set up spun out 684hp on my 493" RB and fit under the factory Shaker. The build and dyno run are still on Hughes website. I'm switching over to the Wilson ported EFI intake on the left in the photo. My shaker hides it anyway.
https://www.hughesengines.com/TechArticles/1dynotest684hp500cid6pack4bbljcross012007.php
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: jbc426] #3075020
09/07/22 06:30 AM
09/07/22 06:30 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
I did about the same with stroker 6 pack
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: jbc426] #3075700
09/09/22 08:24 AM
09/09/22 08:24 AM
Louisiana
Louisiana
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: jbc426] #3075765
09/09/22 11:58 AM
09/09/22 11:58 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Hughes spent over a week porting the intake to the limit of their abilities. Dave Hughes said its the most flow and port equalization they have gotten out of one yet. If anyone is interested in the intake and carbs, let me know.
Page 4 of 4 1 2 3 4
