Re: Indy 383-13
[Re: twayne24365]
#3044144
05/21/22 02:55 PM
05/21/22 02:55 PM
Posts: 1,189 Loudoun County, VA
Brad_Haak
Loudoun County, VA
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/2978815/Searchpage/1/Main/243926/Words/%2B383-13/Search/true/indy-383-13.html#Post2978815
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Indy 383-13
[Re: Streetwize]
#3044560
05/23/22 11:05 AM
05/23/22 11:05 AM
Posts: 2,937 A shed in England
Tig
A shed in England
Pretty sure they have smaller valves than the 4.50" bore 572-13's. Did there also used to be a another version of the 572-13 ?, it had a smaller intake runner volume (365cc v's 390cc ?? ) and could be used on a smaller bore ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) .
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: Indy 383-13
[Re: twayne24365]
#3045041
05/25/22 07:25 AM
05/25/22 07:25 AM
Posts: 1,841 NW Indiana
fbs63
NW Indiana
IIRC the valve centerline is moved to the bore center. Look closely at the head pics posted. They have a 1/2" wide ledge right below the bottom row of head studs. The 440-1 does not have this. Thats roughly the amount the valves are moved. Even if it's not the 13 degree valve angle would require custom pistons. Stock is 15 degree.
Re: Indy 383-13
[Re: fbs63]
#3045060
05/25/22 09:37 AM
05/25/22 09:37 AM
Brad_Haak
Loudoun County, VA
IIRC the valve centerline is moved to the bore center. Look closely at the head pics posted. They have a 1/2" wide ledge right below the bottom row of head studs. The 440-1 does not have this. Thats roughly the amount the valves are moved. Even if it's not the 13 degree valve angle would require custom pistons. Stock is 15 degree. Maybe if you have pistons that are cut for significantly larger valves than 2.19/1.81 you could get away without custom pistons, but I'd think the steeper valve angle would be problematic otherwise.
Re: Indy 383-13
[Re: Brad_Haak]
#3048458
06/06/22 10:18 PM
06/06/22 10:18 PM
Posts: 181 Maryland
twayne24365
Maryland
So got a chance to go look at the heads, they deffinately are Very ported,and they are a water version which I’m glad of. Indy aluminum block, custom pistons with aluminum rods, has a fogger setup, engine is complete in parts minus the crank, so looking forward to making a project out of this thing!
540 aluminum low deck coming soon
