Indy 383-13 #3044093
05/21/22 10:41 AM
05/21/22 10:41 AM
Maryland
twayne24365 Offline OP
Maryland
Hi, just wondering if anybody has any information on these heads. Thanks
Re: Indy 383-13 [Re: twayne24365] #3044144
05/21/22 02:55 PM
05/21/22 02:55 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/2978815/Searchpage/1/Main/243926/Words/%2B383-13/Search/true/indy-383-13.html#Post2978815
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Indy 383-13 [Re: Brad_Haak] #3044213
05/21/22 11:45 PM
05/21/22 11:45 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Pm Hardcore B
Doug
Re: Indy 383-13 [Re: dvw] #3044240
05/22/22 09:13 AM
05/22/22 09:13 AM
Maryland
Maryland
Thanks guys
Re: Indy 383-13 [Re: twayne24365] #3044524
05/23/22 09:15 AM
05/23/22 09:15 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I never understood the 383 designation, is it because it's designed around a smallish bore/intake valve?
If 4.25" is considered small....but since BB Wedge valves don't open on the bore centerline....
WIZE
In Car:
Re: Indy 383-13 [Re: Streetwize] #3044560
05/23/22 11:05 AM
05/23/22 11:05 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Pretty sure they have smaller valves than the 4.50" bore 572-13's.
Did there also used to be a another version of the 572-13 ?, it had a smaller intake runner volume (365cc v's 390cc ?? ) and could be used on a smaller bore shruggy .
Re: Indy 383-13 [Re: Tig] #3044647
05/23/22 04:25 PM
05/23/22 04:25 PM
Maryland
Maryland
We’ll see, 2 weekends I’m going to look at a set
Re: Indy 383-13 [Re: twayne24365] #3044727
05/23/22 10:08 PM
05/23/22 10:08 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Here are some pictures of my old ones. The nitrous was some of Monte Smith's fine work when he worked at applies Nitrous Technology.
Re: Indy 383-13 [Re: NITROUSN] #3044732
05/23/22 10:34 PM
05/23/22 10:34 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Here is the Indy sales brochure.
Re: Indy 383-13 [Re: NITROUSN] #3044819
05/24/22 12:07 PM
05/24/22 12:07 PM
Maryland
Maryland
It says stock valve location but I thought they required a custom piston?
Re: Indy 383-13 [Re: NITROUSN] #3044820
05/24/22 12:08 PM
05/24/22 12:08 PM
Maryland
Maryland
Do you recall any flow numbers?
Re: Indy 383-13 [Re: twayne24365] #3045041
05/25/22 07:25 AM
05/25/22 07:25 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
IIRC the valve centerline is moved to the bore center. Look closely at the head pics posted. They have a 1/2" wide ledge right below the bottom row of head studs. The 440-1 does not have this. Thats roughly the amount the valves are moved. Even if it's not the 13 degree valve angle would require custom pistons. Stock is 15 degree.
Re: Indy 383-13 [Re: fbs63] #3045060
05/25/22 09:37 AM
05/25/22 09:37 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Maybe if you have pistons that are cut for significantly larger valves than 2.19/1.81 you could get away without custom pistons, but I'd think the steeper valve angle would be problematic otherwise.
Re: Indy 383-13 [Re: Brad_Haak] #3048458
06/06/22 10:18 PM
06/06/22 10:18 PM
Maryland
Maryland
So got a chance to go look at the heads, they deffinately are Very ported,and they are a water version which I’m glad of.
Indy aluminum block, custom pistons with aluminum rods, has a fogger setup, engine is complete in parts minus the crank, so looking forward to making a project out of this thing!
540 aluminum low deck coming soon
Re: Indy 383-13 [Re: twayne24365] #3053551
06/26/22 03:45 PM
06/26/22 03:45 PM
Maryland
Maryland
Picked all this stuff up, deciding on keeping it a nitrous motor or doing a NA tunnel ram deal, but here’s a few pics
This was originally built for the KOS series in a cuda, not sure who owned it
Re: Indy 383-13 [Re: twayne24365] #3053553
06/26/22 03:49 PM
06/26/22 03:49 PM
Maryland
Maryland
Few more
Re: Indy 383-13 [Re: twayne24365] #3053569
06/26/22 04:54 PM
06/26/22 04:54 PM
Chesterfield Twp. Mi.
John Burdine Offline
NC. on the valve cover, KOS Cuda, Bowman's black Cuda possibly?
Re: Indy 383-13 [Re: John Burdine] #3053592
06/26/22 05:40 PM
06/26/22 05:40 PM
Maryland
Maryland
I’d be interested if anyone had info on it, I’ll ask the guy I bought it from if he knows anything more
Re: Indy 383-13 [Re: twayne24365] #3053599
06/26/22 05:51 PM
06/26/22 05:51 PM
birdtracker Offline
birdtracker  Offline
I would be interested in knowing if there is any numbers on the camshaft. Birdtracker
Re: Indy 383-13 [Re: birdtracker] #3053603
06/26/22 05:58 PM
06/26/22 05:58 PM
Maryland
Maryland
There is and I haven’t had a chance to get lift/duration numbers but there’s some on the cam I’ll post when I get home
