Power Steering Pump Belt Alignment #3043113
05/17/22 04:03 PM
05/17/22 04:03 PM
Chicago, IL
P
PLUM_72 Offline OP
PLUM_72  Offline OP
P
Chicago, IL
Can someone post a picture or two of their power steering pump brackets for a Saginaw PS pump on a 70 or later small block.
I am dealing with a very slight misalignment of the PS pump to the crank pulley on my 72 Challenger with a 340. If I put a straight edge along the PS pulley to the crank pulley, seems I am off about an 1/8-inch. Wondering If I am missing a washer some place or a bracket is slightly bent. In looking at my set up, I think everything is right, but I do notice some side-to-side movement on the pivot bolt that runs through the spacer, but only if the bolt is loose. It's like everything somewhat aligns loose, but when you tighten it up, the pump seems to skew the belt alignment just a bit. Below is a pic I found off the Mancini website showing what I have minus the alignment issue.
1972 Dodge Challenger
Re: Power Steering Pump Belt Alignment [Re: PLUM_72] #3043120
05/17/22 04:43 PM
05/17/22 04:43 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Post some pics of yours. Are you sure the pulleys are correct?
Re: Power Steering Pump Belt Alignment [Re: mopars4ever] #3043234
05/18/22 08:32 AM
05/18/22 08:32 AM
Chicago, IL
P
PLUM_72 Offline OP
PLUM_72  Offline OP
P
Chicago, IL
have some pictures... Standard Sag pump with the non-windowed or solid pulley. The offset has been this way for a long time, so it will run, just not right. It came up again as I replaced the belts on the car.
Re: Power Steering Pump Belt Alignment [Re: PLUM_72] #3043256
05/18/22 10:00 AM
05/18/22 10:00 AM
N
NITROUSN Offline
NITROUSN  Offline
N
For what it is worth I have seen many like that with no issues. Seems to be the nature of the beast.
Re: Power Steering Pump Belt Alignment [Re: NITROUSN] #3043265
05/18/22 10:25 AM
05/18/22 10:25 AM
A727Tflite Offline
A727Tflite  Offline
If you want to improve the alignment try loosening up the triangle bracket bolts (the bracket to the block or chain cover) then move it up in your situation then tighten them. Then try different sequences of tightening the adjustment bolts.
Re: Power Steering Pump Belt Alignment [Re: PLUM_72] #3043282
05/18/22 11:24 AM
05/18/22 11:24 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I have used Grade 8 washers to shim my pump forward to align the pulleys. I also shimmed the water pump pulley forward using water pump pulley shims from Hughes.
Re: Power Steering Pump Belt Alignment [Re: jbc426] #3043325
05/18/22 04:12 PM
05/18/22 04:12 PM
md
mopars4ever Offline
mopars4ever  Offline
md
The mounting looks correct to me. As stated they never seem to look perfectly aligned. For what it`s worth I just put my pump back on the other day and there isn`t any wiggle room as far as aligning the brackets into a better position..
Re: Power Steering Pump Belt Alignment [Re: mopars4ever] #3043544
05/19/22 11:16 AM
05/19/22 11:16 AM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Also wanted to add that v-belts will tolerate a certain amount of mis-alignement. The amount depends on a few variable's with length between pulleys being one.
here is a good read
GATES BELT ALIGNMENT INFO
Re: Power Steering Pump Belt Alignment [Re: PLUM_72] #3043803
05/20/22 07:20 AM
05/20/22 07:20 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I had this same exact issue on my BB so the solution may be a little different. I put a washer between the pump bracket and water pump and it straightened it out really well. Had to do this in 2 locations, on the pivot bolt and on the adjusting bolt.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
