Re: BELL HOUSING ALIGNMENT HELP
[Re: AndyF]
#3043430
05/18/22 10:02 PM
05/18/22 10:02 PM
Posts: 15,350 Omaha Ne
TJP
Omaha Ne
[Re: AndyF]
#3043502
05/19/22 08:36 AM
05/19/22 08:36 AM
Posts: 10,713 North Dakota
6PakBee
North Dakota
Looks like you are 0.007 out. Move it back 7 so the the +7 goes to zero and the -7 goes to zero. Agreed. If this is the first time you've done this, pull the stock dowel pins and just snug the bell up on the block. That way you can shift the bell around and get a feel for how it responds.
[Re: Stanton]
#3043541
05/19/22 11:04 AM
05/19/22 11:04 AM
TJP
Omaha Ne
Loosen the bolts and hit the +7 side with a rubber mallet. Tighten the bolts and check again. if you get all readings under .007 leave things alone.
.007 + or - ? or did you mean .007 total ? He currently is .014 out total. Installing .007 offset pins and moving the housing to the left, should get him in almost perfect alignment. Most recommend being within .004 - .005 total. BTW if any of you think this is a b--ch try dialing in a cast iron torqueflite converter. And If I remember correctly their spec is .003 total
[Re: dustemup]
#3043570
05/19/22 12:13 PM
05/19/22 12:13 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Don't forget to also verify that the pad the transmission bolts to on the face of the bellhousing is square with the crank centerline, so that the transmission and the crankshaft are on the same centerline and not cocked in relation to each other.
Once you get the opening of the bellhousing centered in relation to the centerline of the crank, you can securely bolt the bellhousing down and drill to small holes for two locator dowels to make lining it back up in the future easier.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: John_Kunkel]
#3043608
05/19/22 02:15 PM
05/19/22 02:15 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
X2. The Robbmc dowels are the correct size. Other aftermarket dowels say Mopar but are actually Ford size and fit way to tight. . But the Robbmc dowels. They are pricey but well worth it,
[Re: TJP]
#3043660
05/19/22 04:55 PM
05/19/22 04:55 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
.007 + or - ? or did you mean .007 total ? He currently is .014 out total. Installing .007 offset pins and moving the housing to the left, should get him in almost perfect alignment. Most recommend being within .004 - .005 total. BTW if any of you think this is a b--ch try dialing in a cast iron torqueflite converter. And If I remember correctly their spec is .003 total Probably as fun as dialing in a JW ultra bell .
[Re: JohnRR]
#3043663
05/19/22 04:57 PM
05/19/22 04:57 PM
Posts: 3,075 Michigan
A727Tflite
.007 + or - ? or did you mean .007 total ? He currently is .014 out total. Installing .007 offset pins and moving the housing to the left, should get him in almost perfect alignment. Most recommend being within .004 - .005 total. BTW if any of you think this is a b--ch try dialing in a cast iron torqueflite converter. And If I remember correctly their spec is .003 total Probably as fun as dialing in a JW ultra bell . You need s torch on the old A-466.
[Re: GomangoCuda]
#3044080
05/21/22 09:14 AM
05/21/22 09:14 AM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
X2. The Robbmc dowels are the correct size. Other aftermarket dowels say Mopar but are actually Ford size and fit way to tight. . But the Robbmc dowels. They are pricey but well worth it, X3 on the mopar vs Ford dowels. Do NOT use Ford ones, and the MR Gasket ones which are labeled for Mopar and Ford are indeed Ford ones. The Robbmc dowels are the way to go: great product.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: AndyF]
#3044429
05/22/22 08:18 PM
05/22/22 08:18 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Yeah you really need a solid mount to get repeatable results. Had this one made by another member about 15 years ago and it works great. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: AndyF]
#3044458
05/22/22 10:19 PM
05/22/22 10:19 PM
Posts: 958 MN
Droop69
MN
Looks like you are 0.007 out. Move it back 7 so the the +7 goes to zero and the -7 goes to zero. So moving the housing .0035 to the left should get it well within tolerance?
