Page 2 of 3 1 2 3
Re: BELL HOUSING ALIGNMENT HELP [Re: Droop69] #3044876
05/24/22 04:26 PM
05/24/22 04:26 PM
moundsview mn usa
dustemup Offline OP
dustemup  Offline OP
moundsview mn usa
so it needs to go to the right?
Re: BELL HOUSING ALIGNMENT HELP [Re: dustemup] #3044941
05/24/22 08:36 PM
05/24/22 08:36 PM
AndyF Offline
AndyF  Offline
I don't know, you didn't tell us which direction it was out. You'll have to look at your numbers and figure out what + and - mean in terms of direction.
Re: BELL HOUSING ALIGNMENT HELP [Re: AndyF] #3045228
05/25/22 09:06 PM
05/25/22 09:06 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I think what confuses most is the = and - readings.
You have to remember for example, + .007 and -.007 Mathematically total a difference of .014"
Example: If you zero your indicator at the -.007
Then run the motor around again you will find that the +.007 has now become +.014
if you zero at the +.007, run the motor around you'll find that the -.007 is now -.014
So a .007 offset dowel properly located will get you half way to zero with + / - .0035
A .014 dowel properly located should get you to zero but may impact your top and bottom readings.
So you have to rob Peter to pay Paul and hope Judas isn't hanging out around the corner LOL beer
Re: BELL HOUSING ALIGNMENT HELP [Re: dustemup] #3045243
05/25/22 10:44 PM
05/25/22 10:44 PM
I shoot for no more run out total than .0070, it is doable, take your time and get it right wrench up
Re: BELL HOUSING ALIGNMENT HELP [Re: EWJ] #3045244
05/25/22 10:46 PM
05/25/22 10:46 PM
Originally Posted by EWJ
Originally Posted by GomangoCuda
Originally Posted by John_Kunkel
Originally Posted by TJP
Notice that video says Ford and Mopar use the same dowel; Ford is .500" and Mopar is .496".
https://www.robbmcperformance.com/products/dowels.html
X2. The Robbmc dowels are the correct size. Other aftermarket dowels say Mopar but are actually Ford size and fit way to tight. hammer. But the Robbmc dowels. They are pricey but well worth it,
X3 on the mopar vs Ford dowels. Do NOT use Ford ones, and the MR Gasket ones which are labeled for Mopar and Ford are indeed Ford ones. The Robbmc dowels are the way to go: great product.
iagree up scope grin
Re: BELL HOUSING ALIGNMENT HELP [Re: dustemup] #3045273
05/26/22 07:59 AM
05/26/22 07:59 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
You are overthinking this. Just step back and think about what you are seeing:
Dial mounted on crank, dial button on bell housing. If the dial indicator reading is increasing, the button is being depressed, the bell housing is getting closer to the crank centerline. Conversely if the reading is deceasing, the button is extending and the bell housing is moving away from the crank centerline. At the maximum reading or minimum reading, look at what the button on the dial indicator would have to do to bring the reading to zero and that's the way the bell has to be shifted. The amount is half of the total indicator reading (TIR) or in your case 0.014 (+.007 to -0.007).
I hate to throw in this caviate but the + and - readings do not have to be equal. In your case you could have +0.004 and -0.010 which would still give you a TIR of 0.014 and 0.007 offset.
Re: BELL HOUSING ALIGNMENT HELP [Re: 6PakBee] #3045326
05/26/22 12:14 PM
05/26/22 12:14 PM
A727Tflite Offline
A727Tflite  Offline
Well put.
Re: BELL HOUSING ALIGNMENT HELP [Re: TJP] #3045690
05/27/22 05:17 PM
05/27/22 05:17 PM
moundsview mn usa
dustemup Offline OP
dustemup  Offline OP
moundsview mn usa
confusing is an understatement, to start off it had a weird noise when hammered in 3rd gear like it was trying to go into reverse 3500miles on the whole drivetrain, I pulled the tranny out and had it checked out by Darrin from this site he said the tranny is perfect and asked what b housing was on it I said it was a Lakewood he said if its not a drag car anymore put a stock back on as the Lakewood tolerances are wacky from the getgo then run a dial around the b housing so I took the Lakewood off and got a used stock one from brewers used the old stock dowels and I had a-26 at 12 I talked to the people at robmc and they recommended .014 offsets so that is whats currently in it now and I've turned them dowels every which way but loose I have at least 18 different pics of the readings and which way I've been turning the dowels, the directions that came with the offsets say the dowels have to be positioned at the same offset angle I've tried that way at 12, 3, ,6 and 9 and the bell does not even fit on, and the 340 was line bored so I'm sure bell needs to go up, the closest I've been is from the picture I've posted
Re: BELL HOUSING ALIGNMENT HELP [Re: TJP] #3045704
05/27/22 07:05 PM
05/27/22 07:05 PM
moundsview mn usa
dustemup Offline OP
dustemup  Offline OP
moundsview mn usa
so if I understand correctly the sum of the horizontal numbers = a sum, and the sum of the vertical numbers = a sum and if both of those reading separately = .008 or less it should be in spec,? the book I have says that TIR should be .008 or less
Re: BELL HOUSING ALIGNMENT HELP [Re: dustemup] #3045812
05/28/22 10:13 AM
05/28/22 10:13 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
This is what I hear you saying. And yes, 0.008 TIR is the factory specification but I would shoot for less. It looks different than your original post but I am going by what you said.
Re: BELL HOUSING ALIGNMENT HELP [Re: 6PakBee] #3045827
05/28/22 10:58 AM
05/28/22 10:58 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Once you are done getting the opening for the transmission centered to the crankshaft/transmission centerline, don't forget to make sure the face of the bellhousing is square to the block too. I had to use shims on my Lakewood scatter shield to get mine to sit square to the crank/transmission centerline.
Re: BELL HOUSING ALIGNMENT HELP [Re: jbc426] #3045848
05/28/22 11:37 AM
05/28/22 11:37 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Just an FYI for any reading this, we have found the Qucik time SS to be a lot closer than Lakewood's are out of the box. But they are more $$. Maybe that's why Quick time is now owned by the same company whistling beer
Re: BELL HOUSING ALIGNMENT HELP [Re: dustemup] #3045855
05/28/22 12:02 PM
05/28/22 12:02 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
To the OP
Sounds like you could benefit from the Browell tool
https://board.moparts.org/ubbthread...ad/Board/19/main/145127/type/thread.html
You don't need to even turn the engine over.
Gus beer
64 Plymouth Savoy
Dana 60
Re: BELL HOUSING ALIGNMENT HELP [Re: fourgearsavoy] #3046062
05/29/22 07:58 AM
05/29/22 07:58 AM
moundsview mn usa
dustemup Offline OP
dustemup  Offline OP
moundsview mn usa
I like that tool, I found that surfing by accident, wondering if anybody on moppets would rent one out
Re: BELL HOUSING ALIGNMENT HELP [Re: dustemup] #3046181
05/29/22 02:44 PM
05/29/22 02:44 PM
Rittman Ohio
Rittman Ohio
Hmmm... Maybe I should buy one and rent it out at $30 a pop and it would pay for itself in about 5 rentals work
I use this tool another member made for me from a drawing I made. It mounts the indicator solid to a 6 bolt crank and it has been used on cars from coast to coast. Shoot me a PM with your info and I'll send it to you.
Gus beer
64 Plymouth Savoy
Dana 60
Re: BELL HOUSING ALIGNMENT HELP [Re: TJP] #3050031
06/12/22 08:59 PM
06/12/22 08:59 PM
moundsview mn usa
dustemup Offline OP
dustemup  Offline OP
moundsview mn usa
I had to take a break from the frustration I think this is going to work, any thoughts?
Re: BELL HOUSING ALIGNMENT HELP [Re: dustemup] #3050038
06/12/22 09:16 PM
06/12/22 09:16 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Those numbers indicate you are within .003 which is well within spec. Great JOB up
I do have to ask though, you're indicator is preloaded at the 0 position correct? if so call that one DONE!!!! beer
Re: BELL HOUSING ALIGNMENT HELP [Re: TJP] #3050253
06/13/22 04:26 PM
06/13/22 04:26 PM
moundsview mn usa
dustemup Offline OP
dustemup  Offline OP
moundsview mn usa
yes and talk about frustration, thanks everyone for the help
Re: BELL HOUSING ALIGNMENT HELP [Re: dustemup] #3050259
06/13/22 04:42 PM
06/13/22 04:42 PM
moundsview mn usa
dustemup Offline OP
dustemup  Offline OP
moundsview mn usa
still confusing is the total reading .005 then? or half of that reading?
Re: BELL HOUSING ALIGNMENT HELP [Re: dustemup] #3050314
06/13/22 09:09 PM
06/13/22 09:09 PM
Rittman Ohio
Rittman Ohio
Well to me that would be the total. I try to get the total under .007 and that would be measured from 3-9 or 6-12 positions on the bore. I would stab the transmission and send it twocents
Gus beer
64 Plymouth Savoy
Dana 60
Page 2 of 3 1 2 3
