How do you trim the nylon braided line? #3041864
05/12/22 08:10 PM
05/12/22 08:10 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I'm building ptfe lines for the 541. The hose ends are quick and easy to pop together. However, it seems to take longer to trim the stinkin nylon braid than to assemble the rest of the line.
Is it always a pain or is it just the DW line I'm using?
I tape the cut line and shear the hose. Then, I use a razor or X-acto knife to cut around the nylon. It's easy to feel the blade cut the nylon and drag against the steel braid.
That's where the fun starts. The blade cuts down to the steel but doesn't get in the lows of the steel braid and I end up taking 10 minutes twisting and turning the hose while trying to get the rest of the nylon cut. After trying several different approaches, I settled on a tiny pair of fingernail scissors to get the resistant strands cut.
What method do you guys use?
- Stu Harmon
Re: How do you trim the nylon braided line? [Re: feets] #3041875
05/12/22 09:04 PM
05/12/22 09:04 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
A small cut off wheel works well. Clean cut and straight. Or a chop saw works good, but kinda over kill.
Brian
Re: How do you trim the nylon braided line? [Re: '72CudaRacer] #3041878
05/12/22 09:18 PM
05/12/22 09:18 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Brian
I think you missed the issue.
1) chop hose off.
2) slide female end over hose.
3) trim back nylon braid <~~~issue
4) expand steel braid.
5) slip ferrule over inner hose.
6) poke male end into hose.
7) screw pieces together.
- Stu Harmon
Re: How do you trim the nylon braided line? [Re: feets] #3041880
05/12/22 09:20 PM
05/12/22 09:20 PM
Mooresburg, Tn
Mooresburg, Tn
Yes I did, different kind of fitting. Sorry.
Brian
Re: How do you trim the nylon braided line? [Re: feets] #3041889
05/12/22 10:09 PM
05/12/22 10:09 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I just use a small cut off wheel on my flex shaft grinder to cut off the excess steel braid. Add a little lube and slap the fitting together. Takes me about 1 minute.
Re: How do you trim the nylon braided line? [Re: feets] #3041894
05/12/22 10:40 PM
05/12/22 10:40 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
Do you think you could get the next size bigger olive jammed in between the nylon braid and the stainless braid and then use a razor knife to cut the nylon braid trapping against the olive? I just dumped a bunch of $$ on Fragola Race-rite PTFE hose and ends and plan to redo my fuel supply and return lines so I'm interested in how your PTFE hose assembly goes.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: How do you trim the nylon braided line? [Re: feets] #3041896
05/12/22 10:51 PM
05/12/22 10:51 PM
How about some black heat shrink over the ends? scope wrench
Works good, last along time and looks good also wrench scope twocents
Re: How do you trim the nylon braided line? [Re: Cab_Burge] #3041916
05/12/22 11:46 PM
05/12/22 11:46 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I have no experience with your particular hose/fittings so can't speak to that.
Will say, if you are open to using a ptfe hose with kevlar outer braid instead of stainless I've never assembled anything easier than Goodridge 910.
Cut hose with a razor, assemble easily. There's no ferrule.
Re: How do you trim the nylon braided line? [Re: feets] #3041937
05/13/22 08:35 AM
05/13/22 08:35 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I have never used nylon wrapped PTFE hose so I just flare the SS braid. Maybe you could cut a small relief cut at the end on the nylon and peel back the nylon from the stainless?.
Could you leave the nylon on?
Re: How do you trim the nylon braided line? [Re: RTSE4ME] #3041940
05/13/22 08:40 AM
05/13/22 08:40 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I"ve made heaps of nylon braided hose. I wrap the end with tape & then cut thru it with my battery 5" grinder with the thin cutoff wheel on it. Makes perfect ends, just have to blow out the rubber filings before you fit the hose ends.
Re: How do you trim the nylon braided line? [Re: rebel] #3041948
05/13/22 08:59 AM
05/13/22 08:59 AM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
I use the hose cutter Jegs sells part number 555-80586. Nice clean cuts no problem putting hose ends on.
Re: How do you trim the nylon braided line? [Re: rebel] #3042233
05/14/22 11:32 AM
05/14/22 11:32 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Cutting the hose is easy. No worries there.
The hose consists of:
Inner PTFE hose.
Middle steel braid for structure.
Outer nylon braid for abrasion prevention.
Cutting the nylon back to install the fitting is the problem.
Mind you, this is an offcut I was playing with. The nylon is blasted out on this piece instead of the nicely taped and trimmed ends I used. The pic shows the type of hose I'm working with.
- Stu Harmon
Re: How do you trim the nylon braided line? [Re: feets] #3042280
05/14/22 03:01 PM
05/14/22 03:01 PM
langley b.c. canada
don miller Offline
don miller  Offline
langley b.c. canada
Kevin, you might try using a hot knife to trim the nylon
Re: How do you trim the nylon braided line? [Re: feets] #3042362
05/14/22 07:44 PM
05/14/22 07:44 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Inner PTFE hose.
Ok, youre using a different kind d of black nylon braided hose. I use this type of hose for fuel & oils. It has a steel sleeve inside the rubber. I changed to this type of hose about a decade ago as it was considerably lighter & the hose ends were easier to fit, not stabbing with stray braid wire. Your hose looks like the std braided hose with a black sleeve on top. I cut my hose with a cutoff wheel in my 5" grinder, makes for a real nice edge to start with.
Re: How do you trim the nylon braided line? [Re: don miller] #3042417
05/15/22 12:19 AM
05/15/22 12:19 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Fair suggestion. I tried using heat on the section shown above. It was real easy to get little lumps of melted nylon.
When I run the lines on the car side I'll switch brands of hose to see how it goes.
Other than the nylon braid the PTFE hose is far easier and quicker to assemble than the old steel braided rubber hose.
- Stu Harmon
Re: How do you trim the nylon braided line? [Re: feets] #3043254
05/18/22 09:48 AM
05/18/22 09:48 AM
Motor City
6PKRTSE Online content
6PKRTSE  Online Content
Motor City
I used all black fittings and black nylon hoses on my car for that stock factory appearing look. Well, sort of..... much easier and no pricking of the fingers like stainless steel braided. Also alot lighter.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: How do you trim the nylon braided line? [Re: 6PKRTSE] #3043829
05/20/22 09:42 AM
05/20/22 09:42 AM
Georgia
66coronet Offline
66coronet  Offline
Georgia
I use a pvc cutter for the nylon braided. It cuts clean and smooth. I am not sure if it would work for that double braided deal or not.
