Page 1 of 8 1 2 3 4 5 6 7 8
563ci build specs, what will it make? #3041995
05/13/22 02:09 PM
05/13/22 02:09 PM
MN
JERICOGTX Offline OP
MN
I picked up my new engine build from the machinist today. Time to get busy, and bolt everything together.
Here are the specs of the build:
INDY RB Aluminum block
Molnar 4.375 crank
Molnar 7.100 rods
Diamond pistons 4.524 bore
INDY 440-1 345CNC heads, finished by Dwayne Porter. Flow numbers attached.
Compression ratio is 13.5:1
T&D 1.6 rockers
INDY 4403X intake manifold
Erson roller cam specs:
Lift Intake= .768 Exhaust= .760
Duration@ .050 =288/302
LSA= 111
Jesel belt drive
MSD Crank trigger
Moroso 4 vane vacuum pump
Thumper 1150cfm 4500 carb
Headers are 2.125-2.250 with 4” collectors.
I’m hoping to have everything together, and dyno test it in a few weeks. Anyone want to take a guess at what it will make for HP/TRQ?
Jeff
69 GTX 68 Road Runner
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3042011
05/13/22 03:03 PM
05/13/22 03:03 PM
AndyF Offline
AndyF  Offline
Something close to 900 hp at 7000 rpm. If the dyno shop has a bigger carb try it if you get the time. That engine would most likely make more power on the dyno with a 1250 carb, but it might go down the track faster with a slightly smaller one.
Re: 563ci build specs, what will it make? [Re: AndyF] #3042015
05/13/22 03:15 PM
05/13/22 03:15 PM
tboomer Online work
tboomer  Online Work
No help Jeff but I hope to see you at the track with it! wave
Re: 563ci build specs, what will it make? [Re: tboomer] #3042016
05/13/22 03:26 PM
05/13/22 03:26 PM
MN
MN
As of right now, the only race I’m planning on attending this year, is Brainerd for 4th of July. Money is extremely tight right now, and with Diesel prices climbing every day, I won’t be making any long hauls.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3042020
05/13/22 03:35 PM
05/13/22 03:35 PM
tboomer Online work
tboomer  Online Work
Cool! Can you remember what my 60' was when you drove my junker? Been meaning to ask that... up
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3042027
05/13/22 03:53 PM
05/13/22 03:53 PM
NC
440Jim Offline
440Jim  Offline
NC
I like that build. up
What length are the headers? A shorter length may make peak hp a couple hundred higher. You have the cam duration to do it.
Since Andy was so close to my initial thought, I'm going with 29-30" long headers and 910 hp at 7200 rpm.
I will guess the torque peak at 5650 rpm. (approximately ...)
Re: 563ci build specs, what will it make? [Re: 440Jim] #3042043
05/13/22 04:49 PM
05/13/22 04:49 PM
MN
MN
Primary tubes are 39” long. They step up from 2.125-2.250 after 6 “ from the header flange. I basically copied my Hooker 5209 headers, when I built them, only these actually fit the car without a hammer.
Re: 563ci build specs, what will it make? [Re: tboomer] #3042044
05/13/22 04:50 PM
05/13/22 04:50 PM
MN
MN
1.42 if I remember correctly.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3042046
05/13/22 04:52 PM
05/13/22 04:52 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The HP numbers could vary significantly between different dynos.
I’d expect to see 875-900 here.
A 572 with the same heads, 14:1, 282@.050 cam, 440-2 with 4500 adapter and a good working 1150, but no vacuum pump made 778tq.
That’s 1.36 lb/ft per ci.
At 563ci you’d be around 765tq.
Re: 563ci build specs, what will it make? [Re: fast68plymouth] #3042049
05/13/22 05:07 PM
05/13/22 05:07 PM
MN
MN
I’d be very happy if it made those numbers. Could possibly push the Road Runner into the 8’s on a good day, with a tail wind.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3042053
05/13/22 05:19 PM
05/13/22 05:19 PM
So. Burlington, Vt.
So. Burlington, Vt.
I’m thinking the 288/302-111 might cost a little bit of peak tq output........ and I don’t know if the vac pump will be enough to equal that out or not.
I guess we’ll find out.
Another 14:1 572 made 766tq. That one had bigger heads, the 3X intake, a little more cam, and a fairly ineffective vac pump(4”).
Even though the peak tq was less, it did end up making 40hp more.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3042072
05/13/22 06:33 PM
05/13/22 06:33 PM
If the cam is installed straight up at 111 ILC I would guess between 875 HP maybe up to 950 HP around 7600 RPM depending on the actual weather that day and fuel used, torque around 790 Ft lbs. around 5200 RPM luck
My guesses have no scientific input, pure speculation on my part shruggy
Re: 563ci build specs, what will it make? [Re: Cab_Burge] #3042123
05/13/22 11:33 PM
05/13/22 11:33 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I guess 891 @ 7300. Whatever it makes it's great to see it coming back together!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 563ci build specs, what will it make? [Re: Hemi_Joel] #3042140
05/14/22 12:32 AM
05/14/22 12:32 AM
Sticky South
Rodenteliminator Offline
Sticky South
I am going to be a little more generous and go 920 hp 790 tq range, comparing your specs and the 540 Todd just finished for me, I don’t have the numbers on my -1’s but I bet they wouldn’t flow quite that good and you have a little more lift, and of course the dyno operator.
Sorry honey I spent the rent
Re: 563ci build specs, what will it make? [Re: Rodenteliminator] #3042155
05/14/22 05:44 AM
05/14/22 05:44 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Is that 4spd going to go bye-bye?
Re: 563ci build specs, what will it make? [Re: quickd100] #3042158
05/14/22 05:56 AM
05/14/22 05:56 AM
MN
MN
Dave, the Jerico is gone, and a Liberty Equalizer is in its place.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3042192
05/14/22 08:51 AM
05/14/22 08:51 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
830-850 on an honest calibrated dyno.
Re: 563ci build specs, what will it make? [Re: fbs63] #3042689
05/16/22 06:11 AM
05/16/22 06:11 AM
MN
MN
Slowly going together. This is the first time I've set up a Jesel belt drive, so I'm taking my time. Should get the cam degreed in, in the next couple days, if I can find the time.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3042715
05/16/22 09:17 AM
05/16/22 09:17 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
What’ll it make?? A trek to that crispy cool fall air at Interstate Dragway to grab a trophy time slip in that low DA laugh2
Re: 563ci build specs, what will it make? [Re: J_BODY] #3042753
05/16/22 10:58 AM
05/16/22 10:58 AM
MN
MN
Anyone can get a trophy time slip at Interstate in the fall... Enough leaves blowing around to get a 380mph time slip... It's happened many times.
